Question about DeLonghi 6707E Oil Filled Radiator Heater
Oil refill Can I refill a Delonghi oil electric heater ? If yes, with which oil ?
  • Anonymous Jan 04, 2009
    All the all has drained from my heater over the years. I need to refill it.
    Please advise what oil to use.
  • Grams Kerns
    Grams Kerns Oct 09, 2012
    i have one that had water instead of oil .i too was wondering if i could refill it.
SOURCE: set time on delonghi oil filled portable heaters and set start and finish times
It was very tough to find the actual manual online for your modle in English. However, you can call Delonghi customer support:
DeLonghi Customer Support: (800) 322-3848
Delonghi does have manuals for some models on their site. Take a look at this link, the model might be similar enough to yours to be able to get the information you need.
http://www.delonghiusa.com/search_results.cfm?sp_q=oil+filled+heater&sp_p=all&sp_f=ISO-8859-1&sp_w_control=1&sp_w=alike&sp_a=sp1003e79d&sp_c=5
Hope this was helpful.
have a great day!
Posted on Oct 29, 2008
  • 79 Answers
SOURCE: Heater turned over and oil spilled out. What kind
if thats the heater im thinking of it is a closed system, you do not refill.
Posted on Apr 16, 2010
  • 736 Answers
SOURCE: DeLonghi oil heater model HMW2400TG
one of three things are common causes of this problem ...most likely, dust builds up enough to block air flow then the unit will overheat inside .. that will trip a thermal breaker .. the breaker will reset when the unit cools .. if that problem continues then it may trip a permanent breaker .. if that happens the unit will stop working .. take the unit outside and blow the dust out of it with air pressure.. .. another common problem is if the fan bearings start to freeze then the fan wont run fast enough to maintain proper air flow .. lubricate the fan front and back bearings with light machine oil or sewing machine oil .. don't use WD40 or oil containing teflon .. the lube life is about 5 years so yours is way overdue for oiling the bearings if you haven't done so yet.. a third problem that is common is the electrical connections inside the heater are made with crimped on rivets .. the rivets loosen sometimes with age and a hot spot is created at the loose connection (you might even see sparks there) .. that can also trip the thermal breaker and is generally not repairable at reasonable cost ...
Posted on Aug 15, 2010
SOURCE: I just bought a delonghi column heater from
no oil to add
Posted on Sep 23, 2010
  • 102366 Answers
SOURCE: need Manuel for DeLonghi Oil-filled
http://www.delonghiusa.com/downloadpdf.php?nid=25
Posted on May 04, 2011
How do I get the heating element out of a DeLonghi Electric Oil heater?
many times the sealant they use has to be heated with a torch to remove the element . and if not done properly all the oil in the heater makes a really big mess .
Aug 15, 2015 | DeLonghi Heating & Cooling
Do they need to be refilled?
No. The heating elements heat the oil. If all of the oil came out...the heater is no good.
Feb 13, 2011 | DeLonghi 6707E Oil Filled Radiator Heater
Hello, I have a Model # TR0715 that needs a power
yes a switch opens and closes the power take old one to hardware store or local electrical supplier
Jan 16, 2010 | DeLonghi 6707E Oil Filled Radiator Heater
Delonghi Dragon Two, oil filled rad trips the main elec fuse
If it is tripping the breaker in the panel, there is a direct short in the heater. Scrap it before it causes a fire. Seriusly
Oct 24, 2009 | DeLonghi 6707E Oil Filled Radiator Heater
Dual rocker switch needed
This might be a re-branded De Longhi heater. Here is De Longhi parts website:
http://www.delonghi-accessories.com/models.asp?cat=143
Parts are also avail. from Fox International, though price is higher.
Jan 16, 2009 | DeLonghi 6707E Oil Filled Radiator Heater
Delonghi 5 fin 700/800/1500w, oil filled heater.
It sounds like you have a lemon. The heat exchanger tube has developed a hole somewhere. These things are designed for the small element inside to heat up the oil, and that is supposed to radiate the heat. It would be dangerous to use without any kind of oil. The element would burn out hopefully before it started a fire, but not necessarily. I don't know what kind of oil they use, but its a thin viscosity, like some turbine oil. You can patch the hole and try some pump oil or something, but I personally don't think its a good idea. I wouldn't do it.
Mar 01, 2008 | DeLonghi TRD0715T Oil Filled Radiator...
Delonghi TRD0715T Safe Heat Oil-Filled Radiator will not work, won't turn on its new just taken out of the box
Ditto same problem. Took it out of the box, plugged it in the electric outlet and did not turn on.
I tried atleast 5 different electric outlets to make sure nothing is wrong with the outlet. Tried changing the timer settings. No use.
Returned it to Lowe's.
Nov 17, 2007 | DeLonghi TRD0715T Oil Filled Radiator...
DeLonghi 6707E Oil Filled Radiator Heater Logo
346 people viewed this question
Top DeLonghi Heating & Cooling Experts
Paul Carew
Michael Youngman
Michael Youngman
Are you a DeLonghi Heating and Cooling Expert? Answer questions, earn points and help others
