Question about Canon PIXMA iP4000 InkJet Photo Printer
White bands across printouts
I just purchased the printer yesterday so brand spanking new. Set up went smoothly (I am using with a mac) but all printouts have fine white hairlines across in bands about 10mm apart. I have tried the different nozzle cleaning/print head alignment functions, used different types of photo paper, printed tests from photoshop, illustrator and quark, changed the file type from jpeg to tiff, cmyk and rgb but all outputs have fine white lines no matter what I do. Please help.
  • 22 Answers
Either one of the print heads are bad or a cartridge. This is what causes that problem. I know it is a hassle but I would take it back. If try and fix it you could void the warranty.
Posted on Mar 17, 2007
Canon goes on offline. mac
HI,
you better go to printer and faxes,right click on canon printer and select USE PRINTER ONLINE AND
once again right click open the printer and cancel the prints jobs which was already in queue.
then put Refresh button and get the printout smoothly.
May 27, 2011 | Canon Office Equipment & Supplies
The printer does not print well - when I attempt to print anything it just comes out in rows of black and white shades. It is brand new (model:ML-191x252x) and everything is set up properly. I don't know...
If it is brand new as you say then do not try to repair it by your own (you will lose your guarantee) bring it back to the dealer you purchased it and ask him to give you a replacement!!!
Apr 09, 2011 | Samsung ML-2510 Laser Printer
White stripes or bands running across the printout. I raelise that these are caused by some of ther print nozzles being blocked and have carried out the following: several clean head runs followed by...
have you done a print alignment.. You could also stand to take out the ink and clean the ink compartment with some q-tips and rubbing alcohol.
I hope this helps..
Nov 05, 2009 | Canon i350 InkJet Printer
Horzontal white lines cut through print and picture copies. When doing head allignment the horozontal bars all have a white gap, 1 through 7. Epson Stylus CX5400
You don't need to do head alignment, because it is for vertical banding in printout. Vertical banding can be minimized by disabling high speed option without doing head alignment. If your printout have horizontal white lines, do check nozzle and head cleaning, or you can minimize white lines by printing in best quality (photo).
Oct 21, 2009 | Epson Stylus CX5400 All-In-One InkJet...
Red and blue lines across printouts
open printing preferences and click on maintenance. Run the print head alignment utility. Sometimes this will remove the horizontal banding. I had this same problem and had to uninstall the printer and reinstall just like it was new, running the alignment feature before it was corrected. Worked ok for a few days then started again. I assumed that the printhead is bad. To costly to repair and bought a new printer.
Jun 27, 2009 | Epson Office Equipment & Supplies
Magenta horizontal banding on all color printout
I suggest that if your machine is under warranty you call out HP, as I have heard that they don't support these machines with parts therefore you will get a new machine.
Good Luck
Dec 09, 2008 | HP Photosmart 3310 Printer
1986 chevy caprice
how to install a 1986 capri starter?
May 24, 2008 | 1986 Chevrolet Caprice
Horizontal White Banding
Most likely cause is that a roller has degraded during storeage. Measure the distance from the centre of the first band to the second and from the center of the second band to the third. If this dimesion is fairly constant you can work out exactly which roller is causing the problem. The most likely culprit will be the Photo Conductor Unit. This will give a large dimension - (approx the 29cm??) A service manual should give you the dimensions (circumferences) of the rollers within the machine. If you have a spare pcu around, put it in and see if it makes ANY difference.
May 13, 2007 | Konica Minolta magicolor 2300DL Laser...
Canon PIXMA iP4000 InkJet Photo Printer Logo
127 people viewed this question
old marine
old marine
