Question about IBM Belkin Enterprise 1100VA (31P7074) UPS System
Belkin 1100VA UPS stopped working. Bought new batteries, still no luck.Is there a way to check/replace the fuse/circuit breaker? It doesn't seem to be working.
  • Anonymous Dec 26, 2008
    I have the same problem.  Did you fix it?
5 Suggested Answers
appex
  • 7 Answers
SOURCE: replacing the batteries in the belkin ups f6c800
look around the box and nottify the screw point open these screw and look for red and black cables that indicate the polarity of positive and negative, make sure the positive goes to it position as well as the negative on the new batteries.
Posted on Jan 25, 2008
tech240
  • 169 Answers
SOURCE: Need a schematic for a belkin F6C120-unv
When batteries discharge during ac power it could indicate charger failure or micro failure or some other wierdness. makers do not release cd info. The best thing is.. buy another one as they can be very difficult to repair and of course they are dangerous, batteries are always live, waiting to bite you. I have worked on and repaired such circuits as the AP 200 series resonant converter and selling and hiring UPS for a long time. Beyond the simple easy checks youhave done the time it takes to understand how they work can better be used.
Posted on Sep 23, 2009
  • 23 Answers
SOURCE: UPS won't charge replacement battery. When power
change the chord wich is connected to u r ups..........
Posted on Sep 29, 2009
  • 84 Answers
SOURCE: APC BACK-UPS PRO 1100VA 120V does not cold start.
When was the last time you replaced the batteries? These units will not start with old / failed batteries connected, or without batteries connected.
If you have a voltmeter, check the batteries. Your unit should have two batteries harnessed together. if you check the individual battery, you should see just over 13 volts, together should be around 26 volts. if you see less than 12.5 volts, that would be why the unit will not start.
You will have to replace the batteries if that is the case. Your BP1100 takes an RBC 7: moz-screenshot-1.pnghttp://www.refurbups.com/APC-RBC7-Compatiblemoz-screenshot.png
Posted on Apr 14, 2010
My belkin F6c-500 works on the non back up side however, doesn't work when power is lost. I have replaced the batterey.
Moss Fet Transistors Failure.
When an UPS works too Much time power line disconnect always the UPS only works for a while. too much time working with the Batteries inside makes the power converting transistors overheating and failure.
Check Internal Fuses, inside the UPs there is an automotive Fuses(30 Amps) plug tipe like in cars.
if the fuses are OK .........................then check it by a Technician.
Check it by a Qualified Technician and check the Mossfets.
Sep 27, 2014 | B&B Belkin 84Whr F6C550-AVR - Rev.A UPS...
Counious beep sound
It is most likely in need of a new battery. Most beep when no battery present or bad
Mar 26, 2014 | IBM Belkin Enterprise 1100VA (31P7074) UPS...
The UPS in this office is out of order, message that appear on screen is 'UPS V OUT LIMITS' and 'Battery critical'
follow this steps and fix it. God bless you
Plug the battery backup into a working electrical outlet. If the battery backup turns on when the power button is pressed, then the problem may be that the previous electrical outlet is faulty. Proceed to step three. If the battery backup doesn't turn on, proceed to step two.
  • 2 Reset the circuit breaker on the battery backup. APC battery backups have a labeled circuit breaker button located on the unit near the phone line, fax line, USB, network and coaxial cable inputs. Press the button to reset the circuit breaker. Power on the battery backup by pressing the power button. If the battery backup powers on, proceed to step three. If the battery backup doesn't turn on, proceed to step six.
  • Read more: http://www.ehow.com/how_7266444_troubleshoot-apc-battery-backup.html#ixzz2lwOvPO75
  • 3 Determine if the battery backup is charged and providing battery power. With the battery backup on and plugged into a working electrical outlet, plug a computer monitor into one of the battery backup outlets labeled "battery backup plus surge protection" on the battery backup. (APC power supplies have some outlets that provide only surge protection while the other outlets provide surge protection plus battery backup.) Turn the monitor on. Unplug the battery backup power cord from the wall outlet. If the monitor remains on, the battery is holding a charge, supplying electrical power and the battery backup is working properly. If the monitor goes off, proceed to step four.
  • 4 Charge the battery. Plug the battery backup into an electrical outlet and allow the battery to charge for 16 hours. This will fully charge the battery.
  • 5 Test battery charge. Once the battery is fully charged, repeat step three. If the monitor stays on when power is interrupted to the battery backup, the issue is solved and the problem resulted from an incompletely charged battery. If the monitor turns off when power is interrupted, the battery within the battery backup is faulty and needs to be replaced.
  • 6 Replace the battery backup unit. The unit itself is faulty. If the battery backup is under warranty, contact APC to request a replacement.
  • Nov 28, 2013 | MGE NOVA AVR 1100VA Tower UPS 81111 UPS...
    Eton 1550 UPS not working (No power and tottaly off LED)
    Check fuses.external and internal fuses.
    almost all the times there is a circuit breaker outside.
    Inside there is a fuse .replace
    Aug 28, 2012 | Eaton Evolution 1550 UPS 11 kW 1550 VA...
    Need a schematic for a belkin F6C120-unv. All functions of the unit work fine other than the charging circuit won't keep the batteries charged. Runs about 24.7 volts, but keeps getting lower as the...
    Sep 22, 2009 | Belkin Enterprise (F6C1200-UNV)...
    Wont turn on acts like it's dead?
    The batteries in these systems can last for 3-6 years, or shorter if damage occurs. You might want to check the battery using a voltmeter, or just order a new battery. You can check out http://www.batteryinternational.com/ups-batteries.html for a new battery.
    Apr 01, 2009 | Belkin UPS Battery Finder: F6C325 UPS...
    Ups problem
    The batteries need to be replaced. They probably have more than 3 years.
    Replace the batteries and let the new ones charge fully for a day and your UPS will work like new after that.
    Oct 14, 2008 | MGE Pulsar Ellipse 800 (89363) UPS System
    Doesn't start and shows "Failure..." on display
    Hi, a couple of things you can do but may I first suggest you bring it back to the Technical Support people who replaced the battery and voice your issue. The new battery might have to be replaced (don't be surprised) and you may have certain warranty claims that may be void if you try opening the UPS yourself. If for some reason you want to do it yourself, then you have to open the UPS and check the circuitry including the new battery. You need to be familiar with the use of a multitester (VOM), working with HOT circuits and general electronics. You have to start with any fuses, circuit breakers, relay, SCRs, transistors, etc. If you are not that comfortable doing so, guess were back to the first paragraph. Hope this be of some help. Good luck
    Apr 25, 2007 | Powerware 9120 UPS System
    IBM Belkin Enterprise 1100VA (31P7074) UPS System Logo
    574 people viewed this question
    Top IBM Computers & Internet Experts
    Alun Cox
    Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
