Question about Clarity 435 Amplified Cordless Phone, Boost Volume up to (30dB), Extra Loud Ringer for the Hearing I...
Cordless telephone ringer does not ring
I have a beetel make 2.4 Ghz cordless phone in my office which when connected to main telephone line rings well. But when the same instrument is connected to EPBAX, it does not ring at all. All other functions are normal with the phone except the ringing. Checked the voltage in the EPBAX line, it is 64 VDC and the ringing frequencey is around 40 Hz. Can we make this instrument ring in this EPBAX ? Pl help... Regards Srini
  • workoholic Dec 05, 2007
    hi
    i have a new beetel walk clip caller id cordless,for which i do not have the working manual,therefore i am not able to set the phone book details in the phone,i have tried setting the numbers using mem/prog but it does not seem to work and also the phone goes blank or switches off after a few minutes of talk,i have charged the phone for more than 20 hrs but it is still
    not working please help
    swetha
3 Suggested Answers
big Jessie
  • 70 Answers
SOURCE: why does the phone flash when not ringing
Hi friend,
I think may be you have set the"light setting",you can try to resetting or cancel this setting.Some phones will flash when they are under good signal.
If you have any phone's questions,you may check the website,it may be an useful website: http://www.1010store.com
Have a good day!!!
Posted on Aug 21, 2009
afghandude01
  • 115 Answers
SOURCE: Clarity C210 single line trimline phone - ho do
you can change it on the settings... goodluck...
Posted on Jun 06, 2010
Phone ringer off
It a little bit older cordless phone, I CAN'T find the model number, there's a menu/elect button on the face but I can't turn the ringer off. The base has a ringer that I turned off but the phone still rings. There are no switches on the phone or base for turning it off.
Nov 14, 2013 | Northwestern Bell 36028-2 2.4 GHz Twin...
Panosonic phones will not ring. I can call out but ringer does not work when someone calls me
mY dear Your Phone Ringer Default So Please change Ringer
And Ringing Sound Problem will solved
Dec 06, 2012 | Panasonic KXTGA410M 19 GHz Cordless...
Does not ring
MY dear Your Phone Ringer Default So Please change Ringer
Aug 04, 2012 | Panasonic KX-TG2122 2.4 GHz Twin Cordless...
Hi I have a vtech Hannah Montana Cordless phone and it won't ring. It has a slash through the ringer bell on the screen. I've tried the ringer settings taking the battery out and the tone and...
These can be the only things that are causing your problems:
Ringer mute
You can mute the ringer temporarily when the telephone is ringing.
Press OFF/CLEAR or MUTE to temporarily silence the ringer. The next call will ring normally.
Ringer volume
You can change the handset ringer volume to a comfortable level. The ringer can also be turned off so the telephone does not ring when there are incoming calls.
To adjust the ringer volume:
Press MENU/SELECT to display the menu when the handset is not in use.
Press or to select >RINGER VOLUME, then press MENU/SELECT.
Press or to adjust the volume. A sample of each volume level will be played as you adjust it.
Press MENU/SELECT to save your selection. You will hear a confirmation tone.
Make sure the ringer is on (page 8).
Make sure the telephone line cord and power adapter are plugged in properly (page 2).
The handset may be too far from the telephone base. Move it closer to the telephone base.
There may be too many extension phones on the telephone line to allow all of them to ring simultaneously. Try unplugging some of them.
If the other telephones in your home are having the same problem, the problem is in the wiring or local service. Contact the local telephone company (charges may apply).
Other electronic products can cause interference to your cordless telephone. Try installing your telephone as far away as possible from the following electronic devices: wireless routers, radios, radio towers, pager towers, cellular telephones, digital telephones, intercoms, room monitors, televisions, VCRs, personal computers, kitchen appliances, and other cordless telephones.
Test a working telephone at the telephone wall jack. If another telephone has the same problem, the problem is in the telephone wall jack. Contact your local telephone company (charges may apply).
The telephone line cord might be malfunctioning. Try installing a new telephone line cord.
Wait for the handset to synchronize with the telephone base. Allow up to one minute for this to take place.
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
May 31, 2011 | Vtech DECT 6.0 Digital Cordless Phone
.com.aumodel WDSS 5335 1 my
There could be DC voltage on the ringer circuit. When a phone line is not in use there should be 0 Volts on the ringer circuit. Sometimes a device connected to your line can "leak" voltage on to the ringer circuit, and some phones will see this as a continuous ring signal.
1. Check all of the telephone cables and any power cables - are they securely plugged in?
2. Remove every device connected to your phone line except the phone that was ringing continuously.
3. If the ringing stops, put the devices back one at a time and see which one causes the problem.
4. If the ringing does not stop, the fault is either in the telephone or your master socket.
5. If you have another phone that is known to be working, try it out to see if it has the continuous ringing.
6. If the problem no longer occurs, there could be a problem the telephone equipment, and you should contact the telephone's manufacturer for support.
7. If the test phone has the continuous ringing, call your telephone provider and tell them that there may be a short circuit in your phone line.
8. If the problem happens only with your cordless phone, and not a corded phone, then it could be interference from a device such as a wireless broadband router or microwave or the cordless handset batteries may not be charging properly.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Mar 20, 2011 | Uniden Cordless Phone
Vtech;5.8 ghz'#cs5121-2: how do i silence the phone to turn off ringer and then turn it back on>
go to main menu select the option of ringing or tone set-up and then select ringer type select silent same procedure done turn back or u can also fallow guideline book
Nov 01, 2009 | Vtech IA5854 5.8 GHz Cordless Phone
Samsung prostar 816 plus system ringing problem
sounds like your having a couple of problems at the same time. the lines only ringing at station 1 is the default setting of the system my guess is that the time and date are also way off if thats the case.
To change the ringing on a prostar 816 you first need to be at a display set (doesn't matter what the extension number is).
with the handset down enter #20 the screen should say MMC DISABLED
1) enter in 1 2 3 4 1 # (that enables programming)
2) enter in #62 the screen should say day ring assn
3) press the line you wish to program
4) press the buttons for the extensions that you wish to ring (the ones in the right next to the handset)
5) press # when finished with the line
6) repeat steps 2 through 5 for the remainder of the lines you wish to change
press #when finished.
next, the problem with the cordless not working has to do with the port programming, in default it assigns all ports as multiline sets.
To assign a SLT(single line telephone) port to the system while still in program mode dial #38 the screen should say slt dial type and then 16 0's.
0 = keyset 1=slt set
enter in all 16 digits followed by the # i.e.if your cordless is on port 7 it would look like 0000001000000000 #
lastly the phone that can no lnger recieve calls sounds like the do not disturb or DND has been pressed to stop the alarm from ringing. press the mute/dnd button (light should be off). to cancel an alarm press the ALM/SD button twice and then the hold button.
hope that helps out.
Mar 05, 2009 | Samsung Prostar 816 Phone
Model 21900 Series True Digital
We called the Thompson help line (for GE products) and they informed us that the phone was only set up to ring once and this can not be changed. We took the phone back to Staples.
Jul 13, 2008 | Bell Northwestern Phones - Excursion 5.8...
One one ring tone with incoming call..........
Make sure the ringer is on .
• Make sure the telephone line cord and power adapter are plugged in properly .
• The cordless handset may be too far from the telephone base. Move it closer to the telephone
base.
• There may be too many extension telephones on the telephone line to allow all of them to ring
• If the other telephones in your home are having the same problem, the problem is in the wiring
• Other electronic products can cause interference to your cordless telephone. Try installing your
• Test a working telephone at the telephone jack. If another telephone has the same problem, the
problem is in the telephone jack. Contact your local telephone company (charges may apply).
• The telephone line cord might be malfunctioning. Try installing a new telephone line cord.
• Remove and re-insert the battery and place the cordless handset in the telephone base.
• Wait for the cordless handset to synchronize with the telephone base. Allow up to one minute
for more info download this http://www.vtechphones.com/docMgt/public/art/52882/6041_manual.i3.pdf
Apr 01, 2008 | Vtech Cordless 6041 Phone
My phone works, but it doesn't ring!
disconnect all phones and just connect the GE phones.
there is only a certain amount of power transmited through a phone line to make the phone ring if you have too many phones running off the same line then the ones further away from the main connection suffer
Jan 05, 2007 | GE 21018GE3 Cordless Phone
Clarity 435 Amplified Cordless Phone, Boost Volume up to (30dB), Extra Loud Ringer for the Hearing I... Logo
73 people viewed this question
Top Clarity Lands Phones Experts
Marvin
Marvin
Andrew Taylor
Andrew Taylor
Are you a Clarity Lands Phone Expert? Answer questions, earn points and help others
