Question about iLO XM-MP3-CD Car Stereo
No Sound - boat stereo
My boat's system consists of: 1) Kenwood KDC-2019 AM/FM/CD Tuner 2) Kenwood KDC-C??? 6 CD Auto Changer 3) Kenwood KAC-749S Amp Suddenly no sound thru Speakers (4). Tuner head is getting power and appears to "tune" and play CD (haven't tried the 6 CD Changer). The Amp has an external (flat) fuse that I pulled and it look "OK". There is also a small remote mounted on the back end of the boat. No hand-held remote. Can't get anyone to come to storage to work on it. Any suggestions before I stumble thru pulling the units and taking them "somewhere" to have them looked at? Thank you.
  • 1 more comment
  • bill ebert Mar 16, 2007
    Thank you for the quick response. The boat is in a storage unit, away from my location, but I'll head over that way and look for a "power lite".
    Yesterday when I was fooling around I don't remember seeing any power lite on the Amp "on". The unit, however, is mounted inside a smallish, cramped cabinet that I've got to "crawl" into in order to see the unit face-on (where the lite is located). I'll post what I see (or don't see) this evening.
    I didn't check for a fuse at the battery, but will.
    Question: Would the wire carrying the power to this set-up be right at the battery or would it be somewhere along some sort of "harness"? (I see on the Amps very basic wiring diagram that the fuse is located near the battery, but..) And, would that fuse be "only" for the Amp (and not also the Tuner & CD Changer)? I know that's a hard question to answer without seeing the set-up but perhaps you could relate what's "normal".
    Oh, the 1 page "instruction manual" for the Amp shows the location of the power lite.
    Question: if there's no power lite "on" then I would presume the problem would be with the Amp or one of it's fuses, correct? Thanks once again.
  • bill ebert Mar 17, 2007
    Thanks all. I've replaced the Amp and the world is good again ;-)
  • Anonymous Mar 19, 2014
    kenwood amp
  • 156 Answers
Assuming that the four speakers are connected to the amplifier, then the amp is the most likely problem component. Does the amplifier show a power light when the system is turned on? Note that there is probably another fuse in the amplifier power wire, near the battery.
Posted on Mar 16, 2007
  • Brian Neathery
    Brian Neathery Mar 17, 2007
    Typically, the amplifier would have its own power wire direct to the battery, and the radio/CD player would be wired to the switch panel area, but a boat is always a custom installation and there's no telling for certain how it was done. There's probably a ground wire present at the battery too.
    The easiest way to troubleshoot would be with a digital multimeter or voltmeter. Your amp has a main power terminal, a "remote" terminal, and ground terminal; for it to turn on there needs to be 12 volts present on the main power and remote terminals. If you find voltage on those terminals and the amp doesn't turn on, you probably have a defective amp.
    If you do have a power light at the amp, but still have no sound, I'd check the wires at each speaker. A shorted speaker wire can put the amp into a "protect" mode so that none of the speakers will play. However, in a boat the only thing a loose terminal wire could short against would be the other terminal on the speaker.
Looking for a Kenwood KDC X397 owner’s manual? .
Yes of course. See the link
hard copy of this Google Search
KDC-MP238/CR KDC-MP208 KDC-138/CR - Kenwood
manual.kenwood.com/files/B64-3898-00_00_KW.pdf
Translate this page
2 ' KDC-MP238/CR/KDC-MP208/KDC-138/CR. Contents. Before use. 3. Basic Operation. 4. General functions. Tuner functions. Disc play functions. General ... Menu Operation. 10. Menu System. Activating Security Code. Deactivating Security Code. Manual Clock Adjustment. Auxiliary Input Display Setting. Receive mode ...
Kenwood KDC-138 CD Player User Manual - ManualsOnline.com
www.manualsonline.com > ... > Home Audio Kenwood > Kenwood CD Player Record the serial number, found on the back of the unit, in the spaces designated on the. warranty card, and in the space provided below. Refer to the model and serial numbers. whenever you call upon your Kenwood dealer for information or service on the product. Model KDC-MP238/CR/MP208/138/CR Serial number.
KENWOOD KDC-138 INSTRUCTION MANUAL Pdf Download.
https://www.manualslib.com > Brands > Kenwood Manuals > Car Receiver > KDC-138 View and Download Kenwood KDC-138 instruction manual online. Kenwood CD-RECEIVER INSTRUCTION MANUAL. KDC-138 Car Receiver pdf manual download. KDC-MP238/CR KDC-MP208 KDC-138/CR CD-RECEIVER INSTRUCTION MANUAL AMPLI-TUNER LECTEUR DE CD MODE D'EMPLOI REPRODUCTOR ...
Connecting Wires To Terminals - Kenwood KDC-138 Instruction ...
https://www.manualslib.com > ... > Car Receiver > KDC-138 > Instruction manual
Kenwood KDC-138 Manual Online: Connecting Wires To Terminals. To Kenwood disc changer/ External optional accessory (KDC-MP238 only) Fuse (10A) Wiring harness (Accessory1) Power control/Motor antenna control wire (Blue/White) TEL mute wire (Brown) Not Used (Blue) White/Black White...
Kenwood Car Stereo Head Unit Replacement Wiring Harness Plug ...
https://www.amazon.ca/Kenwood-Stereo...Wiring-Harness/dp/B005X273W8 Rating: 4.7 - ‎15 reviews
Kenwood Replacement Stereo 16 Pin Wire harness; Top quality all copper 18 gauge leads. Perfect Fit.Molex type 6 inch long black color; KDC KRC DPX KTS models see the descrition for model compatibility; Kenwood power harness plug 16 pin indash radio and video units; Allows for installation of an aftermarket radio ...
Mar 23, 2018 | The Computers & Internet
I have a Kenwood KDC-MP2032 installed in a boat. I changed the battery in the boat and now I can't get the tuner to power on. If I need to replace a fuse, where are they and what size fuse do I...
Try to check first the fuse on the fuse box of your boat if it is still good then the fuse of your stereo is located at the back of the stereo itself. Detached the stereo from its housing or holder you will see the fuse at the back of it.
Jun 28, 2011 | Kenwood KDC-MP2032 CD Player
Owners Manual for Kenwood Car radio Model KDC-M4527
KDC-M4527
CD Receiver with WMA/MP3 decoder Built-in
Audio Features
- 4 x 50 watt maximum output power by MOSFET Power IC
- 1 RCA preout, 2 Volt
- Separated tone control: Bass/Mid/Treble
- Source tone memory
- Balance/Fader/Loudness control
- System Q: Sound control with pre-programmed tone curves
- Auxiliary input with optional unit (CA-C1AX or KCA-S210A)
- Attenuator (-20dB) with smooth volume return
Tuner Features
- 24 presets: 18 FM, 6 MW/LW
- K3I clean reception Tuner
- Radio Data System (RDS) with Radio text
- Auto memory entry (AME)
- Up/Down seek tuning
- Local Seek
- FM Stereo/Mono selector
- Tuning mode : Auto1/Auto2/Manual
- DAB reception with optional unit KTC-9090DAB
CD Features
- CD-R/RW compatible
- 8 times over-sampling
- 1 bit D/A converter
- S/N ratio: 105 dB
- Dynamic range: 93 dB
- Channel separation: 85 dB
- MP3 decoder with ID-3 Tag display
- MP3 decoder MPEG-1/2 Audio layer-3
- WMA decoder: windows media audio
- CD-text
- Random/Repeat/Scan Play
Changer Features
- Dual changer control capability (CH1/CH2 & AUX)
- CD-Text with compatible units
- Disc Name Preset System with compatible units
- Disc & Track repeat
- Disc & Track scan
- Disc & Magazine random play
General Features
- Removable faceplate
- Protection case for faceplate
- Disabled System Indicator (DSI)
- Mono Colour LCD display
- 14 segments x 8 characters
- White LED display backlight
- Selectable key illumination (red or green)
- 24 hours clock
- Auto Dimmer
- 2 way telephone mute
- All off select (20/40/60 min.)
- Built-in fuse/coil
- ISO A/B connector
- Remote sensor for optional remote control unit
- OEM steeringwheel remote hardwired connection
thats the most i could get go here http://kenwoodusa.com/Contact/ and have them send u one hopw that helps.
Oct 01, 2009 | Kenwood Car Audio & Video
Kenwood KDC-X589 seems like the CD player doesn't put out sound
you have to change the cd read setting it might got set to cd read 2 it needs to be cd read 1 in standby mode press menu button scroll through with track button till you see cd read and set it to cd read 1 if not in standby mode try in cd mode same steps
Jul 03, 2008 | Kenwood KDC-X589 CD Player
Kenwood XD 550 stereo start-up problem
this normally happens with a lot of sets! It usually happens during a Power Failure, Power Surge (Fluctuation) and if the wire of the component is taken out from the wall outlet while the system is on...To get rid of this problem all you need to do is to press the Display button on the main unit, it is located just below the main display! Voltage Selection has got nothing to do with this problem...
Jun 29, 2008 | Jwin JK-777 Nostalgic Stereo System with...
Cd changer
You can use any CD changer that has an FM modulater. You would listen to it by tuning in to a station on your tuner.
The sales person at any place that sells car stereos would be able to show you the right type of changer.
If your radio has a cd changer controller built into it, you need to check with the dealership to find out what the OEM changer would be. But a FM modulator will work with any car stereo.
Kenwood, Pioneer, JVC, Clarion, Alpine all sell FM modulator CD changers. I would not personally buy any of the cheaper no name brands. The money you save on the cost is not worth the difference in quality. Panasonic is a very good brand for car stereos but not home stereos, but I don't know if they make CD changers. if they do, that would be a good brand.
Jun 15, 2008 | Car Audio & Video
KENWOOD RADIO CODES
try this
KENWOOD SECURITY CODE CLEAR procedure
Your radio will require one of the following procedures.
Type 1
During the code request mode, while holding the DISP key depressed, press and hold the Volume UP or DOWN key for 3 seconds (so that “…” disappears).
Then using your remote enter your code.
Type 2
Press the "Auto" button and "Track up" on face of radio at the same time. The four dash lines ( . . . . ) should "disappear".
Type 3
Model# DPX-4020 and DPX-4030
Press and hold the 1 then the 6 preset key (preset keys are the buttons on face of radio for storing you "favorite" radio stations). "C" should display.
Then using your remote, enter your code.
Enter your number from the remote control unit. Your code number is 5227 (KCAR)
* Press numeric key “5” ( 2 times ) and press the Track UP/Next Track key
* Press numeric key “2” ( 3 times ) and press the Track UP/Next Track key
* Press numeric key “2” ( 1 time ) and press the Track UP/Next Track key
* Press numeric key “7” ( 2 times ) and press the Track UP/Next Track key
The security is canceled and the set enters the TUNER mode!
Jan 11, 2008 | Kenwood KDC-MP228 CD Player
Auxillary option not available in menu
Try putting the unit in standby via the "SRC" button FIRST..., then press the menu button and cycle through to the "AUX 1" option and activate this....then press menu button again. When the unit is next switched on, you should have an "AUX" option accessible via the "SRC" button which will cycle through all of the availale modes ....standby-tuner-cd-aux etc etc.
Jul 01, 2007 | Kenwood KDC-MP628 CD Player
iLO XM-MP3-CD Car Stereo Logo
1,476 people viewed this question
Top iLO Car Audio & Video Experts
xxxxxx xxx
Libran Moreno
Steve Sweetleaf
Steve Sweetleaf
Are you an iLO Car Audio and Video Expert? Answer questions, earn points and help others
