I have a gateway P6860fx notebook w/ rgb,hdmi,sata,3 usb ports and a couple other ports and a Shift3 XL-90 Entertainment Projector that only has red white and yellow rca. Can I splice rgb cable to yellow video rca cable or does anyone make this? help please, Scott
  • 4,806 Answers
Hi there
What you need is a RGB to male VGA cable, these are not expensive and will cut down time wasted by trying to splice cables
kind regards and please don't forget to rate us
Posted on Dec 14, 2008
When i plug it in makes noise like it will power up but when i press the power button nothing happens
Review: Discovery Wonderwall Multimedia Projector ...
? 15:01
Dec 3, 2010 - Uploaded by georgef551
This is a review of the Discovery Wonderwall MultimediaProjector, ... twist the lens to focus the image, up to at least 120" (can go farther), but you'll ... RGB elements, which stands outlike a sore thumb when video gets .... The bulb will just make the display more true, and possibly, ... sound compared to 3m?Missing: power ‎power
Discovery Expedition Wonderwall Entertainment Projector, Inc.
Rating: 2.7 - ‎60 reviews Discovery Expedition Wonderwall Entertainment Projector: ... color contrast, volume control, distinct power on/off button, LED indicator light .... A lot of reviews complained about the fan noise and speaker level, but I thought .... I got it for Christmas to play video games on and you can't even make out the words. Discovery Expedition Entertainment Projector ..., Inc.
Rating: 2.5 - ‎267 reviews
Jan 05, 2016 | Discovery Channel Discovery Expedition...
What is causing a green hue to the entire screen?
1) Check that the plug is tightened into the device and projector. 2) check the prongs on the plug. Are any bent or missing? If so, get a new cable.
Tip: If you can move up to the next plug level, that could help too. So if you are using RGB, try a DVI cable if your projector takes it and your device outputs it. Other connections include are the Display Port and HDMI. They are on par with DVI, but they can deliver audio. Again that is only if the projector accepts it and sound can be played through the projector.
Aug 25, 2014 | Epsonr PowerLite X9 LCD Projector - HDTV -...
I have a zx4800 touchscreen gateway and i want to conect it with the tv is it possible ?
You may be able to add a second monitor. You need a USB video adapter to get an external video port. There are no external video ports on the ZX4800 all-in-ones. Here is an example USB VGA adapter: . DVI and HDMI versions also exist. These aren't the greatest solution so don't use them for gaming.
These will work if the TV has a compatible port. If your TV has VGA input, you are fine with this option. If your TV has HDMI inputs, you need to check the specifications. Some TVs have HDMI ports that do not interpret the signal from a computer. If your TV only has composite or component video inputs, you will need a converter from VGA (RGB) to the TVs input. (Component is YPbPr.) One option is . VGA to component video cables do not work; those are meant for projectors that understand the RGB encoding.
I hope this helps.
Dec 20, 2012 | Gateway GM5664 Desktop PC
How can I get my Gateway desktop to recognize my Projector?
it has to be set up as an additional monitor/display. so, there are settings to set up the displays as either twins, unique seperate or something like that. have not had to do it. but i know that the graphics have to be able to recognize what format the signal is. pc settings change and graphics setttings change. have you done both? the projector should have had instructions? if not look for the manual online.
Aug 23, 2012 | Gateway Computers & Internet
How to turn on rgb from lap top to tv.
In order to connect your laptop to your TV using RGB, you need an RGB adapter. RGB is also known as component video; it breaks up a video signal into red, green and blue. laptops do not have RGB outputs. However, many laptops have VGA, DVI or HDMI outputs. An RGB adapter connects the single VGA, DVI, or HDMI cable to an RGB cable, which is actually three different cables tied together. INSTRUCTIONS:
1. Connect either the VGA, DVI or HDMI (in the order of increasing video quality) cable to the VGA, DVI or HDMI port on your laptop, depending on what is available. 2. Connect the other end of the cable to the side of the RGB adapter with the single input. 3. Connect the RGB cables to the red, green and blue ports on the other side of the RGB adapter. 4. Connect the other end of the RGB cables to an available component input on the back of the TV. 5. Tune the TV to the component video input you used through your television's menu. 6. Turn on your laptop. The laptop should now display on your TV screen.
May 30, 2011 | Computers & Internet
Source not found I am using an Acer Aspire One
Make sure you are using ports other than the USB port. Vivitek Service indicates that at least some of their projectors do not use the USB port for input. "The USB port is not in input port. This is used for service only. Please use another input port such as RGB input. Regards, Vivitek Customer Service
Hope this helps.
May 16, 2011 | Vivitek D825MS Projector
How do I set up my Elmo to a data projector & a laptop? Specifically, Where do I put the RGB cords - what get's hooked up to what? Thanks!
I am going to bet you got a manual with the TT-02rx that explains the connectivity. If not, you can go to and download the manual from the TT-02rx page. Look on page 30.
TT-02rx can be connected in a couple of ways:
1. Directly to Projector - connect a standard VGA cable from the RGB output on the TT-02rx to a RGB (VGA) input on your projector. This will allow you to directly display anything you put under the Elmo camera.
2. USB to laptop, VGA from laptop to your projector. You can connect a standard USB cable from the Elmo to an open USB port on your laptop. From the laptop, you will need to connect VGA cable from output jack to projector input. To view images from the Elmo, you need to have installed the Imagemate software on your laptop first. Elmo can only be viewed thru the software interface.
3. The last option is run VGA from your laptop to VGA input on the Elmo. Then run VGA from Elmo to your projector. This offers the greatest amount of versatility as you can switch between the image on your computer screen and the image on the doc camera. Adding the USB cable as described in 2 above will also allow you to use the digital features such as image capture, reveal, spotlight, etc.
Dec 09, 2010 | Elmo Projectors ELMO TT02RX DIGITAL...
Can't hook up my laptop to play DVD's through my Eiki LC-XNB4M
computer should always be connected with 15 pin VGA to DVI-I cable.
Select in menu input 1 analog RGB and adjust output resolution of Dell to 1024 x 768. this should work !
USB is only for mouse control with pj remote
Jul 09, 2010 | Eiki LC-SM4 Multimedia Projector
Computer to HDMI outlet of Hitachi HDTV rear projector
The TV should be pretty simple. It is generally going to be HDMI 1, 2 or 3. If the TV won't tune to one then it doesn't detect a signal on that port. More likely, there is a setting either in your Graphic Adapter software or in Windows to output to this port. Windows doesn't turn anything but the RGB port on by default.
May 02, 2010 | Hitachi 51F59 51" HDTV Projection...
Computers & Internet Logo
143 people viewed this question
David Payne
David Payne
