Question about Vtech Kidizoom Digital Camera
Your Vtech Camera
Did you ever get your issue with the buttons not working figured out?  I am having the same problem.  Please lem me know if you have, I would really appreciate it!  abutler541@hotmail.com
  • Anonymous Dec 26, 2008
    We have the same problem, too. The button is stuck in and won't pop back out.
  • 423 Answers
Could the button be sticky (due to sticky fingers)? If so, try to pop the button out with a pocket knife or something similar and slim. When you get it out, take a q-tip and dip into some hot soapy water and run it around the button. Should take off the sticky stuff and might fix you. If not it could be a defect in the camera.
Posted on Feb 17, 2009
Vtech KidiJamz keyboard: keeps saying turn off message (Let's jam again later..) and then turning off even with new batteries in place.
Ours had the same issue. I took the Vtech Kidijamz apart. The power button has its own little board. I unscrewed that. It connects to the next board via two wires. I reflowed the solder for all the connections for those two wires (four solder points total). Issue fixed. FYI: reflowing solder just means heating each solder point (with a soldering iron) until the solder gets soft and then removing the iron to let the solder cool and thus harden.
Oct 05, 2013 | Vtech KidiJamz Studio
I HAVE A SONY DIGITAL CAMERA DSC T-20 AND HAVING AN ERROR MESSAGE E:61:10 PLEASE SEND ME HOW I CAN SOLVE THIS PROB LEM
Hello and Welcome
The symptoms of this error is
  • After pressing the power button in capture mode, the lens would extend and a slight humming from what appeared to be the auto focus motor could be heard for about 5 seconds. When the motor stopped humming, the camera would beep and display E:61:00 in the LCD Screen.
  • Camera would extend the lens but not be able to focus on anything past 8 inches or so.
  • Zoom in and zoom out would not work.
  • Playback mode and the Setup mode was not affected.
To solve this
Put the camera about a half inch from a hard surface.
Let the lense go out and hit the surface and retract a little bit. Let it go out all the way when it tries the next time.
If that doesnt fix it, try this:
Turn it on and let the lense go out fully
See where the lens comes out of the camera? The little round crack that surrounds it? Wiggle the lense a bit and blow in there a bit. (Be sure not to blow on the lense!)
Now turn it off/on again, and it should be fixed
See the following video, It may also help you
I hope it will be Helpful for you.
Thanks and keep Using FixYa
Mar 16, 2011 | Sony Cyber-shot DSC-T20 Digital Camera
The "enter" button won't work. Doesn't make any difference if you have the blue button on the left or the orange button on the right, neither "enter" button works when pressed.
I had the same issue, enter button didn't work on orange or blue side. Turned out the exit button (door icon) was stuck in a depressed position. Once the button was popped up the enter button started to function again.
Nov 16, 2009 | Vtech V.Smile Pocket
Will only take pictures....won't let me use video, picture editor, games or access memory.
HI,
Here are some steps to solve your issue:
1. Press the Reset Button with a paper clip. This should reset your camera and should wok fine..
If this does not solve the problem, please continue the following steps:
1. Please make sure the camera is OFF.
2. Interrupt the power supply by removing the batteries.
3. Let the camera sit for a few minutes without batteries, then replace the batteries and press the Reset Button again.
4. Turn the unit ON. The unit should now be ready to play again.
5. If the unit still does not work, replace the batteries with an entire set of new batteries.
Please leave me comment, if you need further assistance
RNJ VINODKUMAR
Oct 06, 2009 | Vtech Kidizoom Digital Camera
Vsmile will not turn on
HI! Have a few ideas for you. First, are the batteries brand new never used good batteries? Also, are you sure they are in the correct way? If so, try to reset the system. Unplug all cords from the Vsmile. Then, for a full timed minute, press down BOTH buttons on the front of the console. After the minute, plug everything back in and try to power it up. If this does not work for you, please contact Vtech Customer support. You can reach them at 18005212010. Hope you find this helpful! Good luck! :)
Sep 08, 2008 | Vtech V.Smile Pocket
Vsmile home unit and 2 Vsmile pockets no longer work! GR!!!
You should definately call customer service! I had to do this with our vsmile and they were very helpful with tech issues immediately. You can call them at 1.800.521.2010. One thing to try, they had me do this on the home unit. Unplug everything, then hold down both buttons on the front for one full timed minute. This resets the unit. See if this works for you. They will ask you to do it on the phone first anyway. If not, I hope they are able to suggest other helpful solutions for you! If not, you can find a good deal on a new one on ebay. Good luck! I know how much the kids enjoy this unit!! :)
Aug 13, 2008 | Vtech V.Smile TV Learning System
Help
http://www.vtechphones.com/vtechui/support/manual_list.cfm
May 10, 2008 | Vtech Kidizoom Digital Camera
Vtech Kidizoom Digital Camera Logo
322 people viewed this question
Top Vtech Cameras Experts
Tony
brian soufane
Are you a Vtech Camera Expert? Answer questions, earn points and help others
