Question about Whirlpool GEW9250 Electric Dryer
Control lock unable to clear or unlock control lock
  • 3 more comments
  • Anonymous Dec 31, 2008
    I hVE A LOCKED CONTROL BUTTON ON FRONT LOAD DRYER CAN ANYONE HELP ME
  • Anonymous Mar 12, 2009
    Hey! That solved it for me, thanks so much!
  • bknick Mar 14, 2009
    unlock doesnt release dryer have two lights on on front. One is dampness and the other is bulky items. have replaced thermister and heat overloads still no luck.
  • ljmar23 Mar 30, 2009
    My control lock light stays on and no matter what i do i can't get it unlocked Please help!
  • Anonymous Apr 30, 2009
    Same thing. Won't cancel out w/three second reset button, constanting beeping, will not start.
  • 85 Answers
Bottom button on last row on right side of control panel depress and hold for 3 seconds it should activate or deactivate control lock if this does not help you could have a faulty control panel
Posted on Dec 16, 2008
Thanks so much it worked!
Posted on Dec 30, 2008
I had a same problem and some one solve the problem in this side. Solution is very simple. Open the top panel and remove the control lock light Thats all it'll start to work fine. Because control lock light does not read the correct volt.
I hope that's help
Posted on Apr 13, 2009
  • Valerie Scott
    Valerie Scott Jul 19, 2015
    Is there a trick to take off panel? Snaps or screws strategicaly placed?
How do I unlock the control panel of a ge microwave oven?
See the link
Many microwave control panels can be locked to prevent accidental use or access by children.
There are two different ways to lock the control panel:
  1. Press and hold the CLEAR/OFF pad for 3 seconds. The display will show "LOCK" and then revert to the time of day. A small "L" will appear in the corner of the display as a reminder that the control panel is locked. If anyone tries to use the microwave, the display will show "LOCK".
  2. On some models, press and hold the 5 and 7 pads simultaneously for 3 seconds.
To unlock the control: Repeat the procedure which was used to lock the control. (Press and hold the CLEAR/OFF pad for about 3 seconds or hold the 5 and 7 pad simultaneously for 3 seconds.)
unlock the control panel of ge microwave Google Search
Nov 05, 2017 | GE Microwave Ovens
Oven door is locked out - Sears no help
      1. Step 1 Read the display on the electronic oven controls, where the clock and timer normally appear. If the display reads "CLN" while the "Door Locked" light is on, the Kenmore range is in self-clean mode. When the Kenmore range is in self-clean mode, you must stop the cleaning process before the door will unlock.
      2. Step 2 Stop the self-cleaning process by pressing and holding the "Stop/Clear" button for three seconds. The oven lock should disengage after three seconds. In some cases, a malfunction between the control panel and the locking mechanism prevents the door from unlocking.
      3. Step 3 Hold the light switch for several seconds if the "Stop/Clear" button fails to unlock the range door. Engaging the light switch for several seconds resets the entire locking mechanism and overrides the "Stop/Clear" button.
Jul 03, 2015 | Kenmore 30" Freestanding Electric Range...
Iam unable to unlock my n72 lock code
if it is just a user lock code and not the network lock code, you could enter this combination to format and clear all codes and data on the set. while off with no sim, press *,3 and call button smalteneously and power up unit. hold for about 2 minutes and release. phone will be reset.
Sep 25, 2010 | Nokia Unlock N70 N71 N72 N90 6630 6680...
I have accidentally locked my microwave oven (profile performance convection oven). I was cleaning the front. Can you tell me what to do?
Got you covered. Here you go:
Microwave - Explanation of the Child Lock Out Feature
That info is from GE
Hope that does the trick.
Regards, Farmerbear at FixYa.com
Sep 13, 2010 | General Electric Microwave Oven
Why am I getting osd main controls locked flashing and then the same message saying unlocked and i am unable to clear it - posted in Monitors ... the attention osd locked is constantly flashing on and off...
Most of the monitors have a function to lock the OSD to prevent accidental changes in the configuration of the monitor.
If you are constantly getting the message about OSD being locked and unlocked then it means that the OSD locking button is constantly pressed.
Usually it is the "Menu" button on the monitor which is used to lock the OSD.
Check if the Menu button is constantly pressed.
Sep 11, 2010 | Compaq Presario 5000 PC Desktop
The Display on my microwave says "LOCKED"
The control lock shuts down the control panel pads to avoid unintended use of the microwave oven. To unlock/lock control, the microwave must be in standby mode, touch and hold stop/clear for 3 seconds until one long tone sounds and the display clears to show an outline if the display area. Repeat to unlock control, and return display to the time of day, if any pad is touched while the control is locked, there will be no response from the microwave oven. hope this helps.
Mar 28, 2009 | Magic Chef MCM660A Microwave Oven
F and DL error
check your wireharness from door lock assembly to the central control unit,,wire broke
Dec 26, 2008 | Kenmore Elite 45986 Front Load Washer
Can't Unlock oven doors after "self-Clean" maytag double oven
I was advised to disconnect power for at least 60 seconds to clear the control board. I did this several times with no luck getting the door unlocked. However, a few hours later, the door did finally unlock. Not sure what ultimately caused the door to unlock, but happy that I did not have to replace the control board.
Dec 22, 2008 | Maytag Kitchen Ranges
Smart lock access code on tv
A model number for your Magnavox TV would be helpful because the Parental Control Reset procedure varies. There should be a sticker on the back of the TV showing the model number. If you have a newer LCD model, the unlock code is usually 0711. Ignore any "Incorrect" warning and enter 0711 again. Then set or clear the Parental Access Code.
Sep 07, 2007 | Akai CFTD2083 20 in. TV/VCR/DVD Combo
Channel locked
with the tv off press and hold the volume down button on the tv & clear button on the remote for 5 to 7 seconds. perhaps you can borrow a friends remote for a day to fix it. good luck.
Apr 14, 2007 | RCA 27F530T 27" TV
Whirlpool GEW9250 Electric Dryer Logo
563 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
