Question about Frigidaire 30" Self-Cleaning Drop-In Electric Range - Bisque
BURNER DOESNT HEAT AT THE RIGHT SETTING
MODEL #REG533MN-3 CHANGED BURNERS AND STILL HAD THE PROBLEM.
ANY IDEAS??
  • Allen Neal
    Allen Neal May 11, 2010
    what was the original problem
2 Suggested Answers
  • 198 Answers
SOURCE: Left Front and Right Rear burner does not heat up
Both burners should be replaced as well as the recepticles that it plugs into. There are recepticle kits available for this repair.
Posted on Feb 08, 2009
Replaced coils & igniter but dryer won't heat. Tested all thermostats and they read good. Can't see if the igniter is glowing or not.
check psu to ignitor and the main burner valve sets and resets
you can do this manualy by removing the thermocouple and testing the burners does it try to strike??? and doesnt burn or does the burner try to come on then go out if it wont strike perhaps the door catch isnt right you dont give a make model etc details so its hard to even guess,,,?
Dec 20, 2014 | Dryers
The front dual burner will not heat.
Then it's just the wire connection at the burners. They're probably burned off and need replaced. I replaced the connectors on my mothers burners and they work fine now.
Nov 15, 2014 | Frigidaire PLEF398AC Electric Kitchen...
GAS OVEN WILL NOT GET HOT
see this instructions and fix it. God bless you
  1. eHow
  2. Home & Garden
  3. Home Appliances
  4. Other Home Appliances
  5. How to Troubleshoot a Gas Range Oven That Won't Heat
By Kefa Olang, eHow Contributor
Although gas range oven may prove useful for cooking and baking, they may fail to ignite if they aren't properly maintained and set up. Lighting a gas range often involves simply turning a knob; however, blockages from food particles and debris caught in the burners, improper burner cap installation and gas supply are common problems that interfere with your gas range oven's performance. A few troubleshooting guidelines may solve these problems safely.
Other People Are Reading
Things You'll Need
  • Toothpick
  • Paperclip
Instructions
    • 1
      Check you have gas in your tank if your gas range oven won't heat. Contact your gas supplier if you've run out of gas.
    • 2
      Clean the burners if you have gas but your burners still won't ignite. To clean the burners, lift the burner caps 9b4f010f-be4f-4db6-8a88-4c3fd17e3339.gif
    • 3
      Inspect the small vertical holes on the side of your burners for dirt, food and debris. The gas won't ignite if they are clogged. Scrape dirt, debris and food from the vertical holes using a pointy object such as a toothpick or paperclip.
    • 4
      Reinstall the burner caps properly. If they are tilted or wobbly, the gas may not ignite. Install the caps on the right burners. Some burners are smaller than others, so match the caps to the appropriate burners.
    • 5
      Move the burner knob to the "Lite" position and wait for the gas to ignite. If it ignites, rotate the knob to your desired setting. If it doesn't ignite, contact a qualified appliance technician.
Jul 18, 2013 | Ovens
I havef a KitchenAid Gas Range Model KGSS907... and one of the ignitors on one of the burners is not sparking. I tried to take the stove top off to check the wire to the ignitor but don't see how to...
Typically the burner come off by removing the burner caps and inside the burners are 2 screws that hold the burner base to the top..yes you could swap igniters on all burners they will be the same. If by swapping the igniters it still doesnt work the things that could be the problem are;
the spark module espically if the igniter that doesnt work on that burner suddendly work on a different burner
the spark switch on the gas valve for that burner..typically all burners spark when one it turned on but the only one that lights is one that has gas flow to it..so turning on a different burner first and leave it set to light setting by turning on the one that doesnt light it will light if that spark switch is the problem
of course a cracked igniter
a broken wire from the spark module to that igniter taht doesnt work..its not that uncommon that the insulation will sometimes wear off a wire off so the electric that should be going from the spark module to the igniter is instead being grounded by that wire touching the metal on the frame uninsulated
Good luck,i hope i have been able to help you fix your range,
GENE
Aug 27, 2011 | KitchenAid KGSS907SSS Gas Kitchen Range
Heat shuts off after about 3 seconds, recycles
its not suppose to stay on for long time...its suppose to recycle...set it at high heat all burners should come on for few seconds and then go off for few seconds...small burner do faster then bigg ones
Nov 10, 2009 | Jenn-Air JED8430 Electric Cooktop
GE electric stove problems, our stove has 3 small burners and one big burner. When we use the big burner at medium heat it does fine then all of a sudden it starts glowing bright red and burns whatever is...
Replace the infinite heat control switch for that burner. (the burner switch that you turn with the knob to select the temp setting) If you list a full model number (usually behind the lower drawer panel on the frame of the range) I can look up the part number for you. It is not a very difficult repair.
Oct 11, 2009 | Kenmore 95592 / 95594 / 95595 / 95599...
Jan 11, 2009 | Frigidaire FEF352 Electric Kitchen Range
Whirlpool electric range burner power light stays on but no heat
Hello givemeanidth.
Welcome to Fixya
You said, have a Whirlpool electric range (model rf363pxpt0) with standalone burners - the burner power indicator light stays lit whether the heat control knob is on or off, there is no heat coming from the burner on or off. You pulled the burner from the receptacle and one of the tabs broke off and stayed in the receptacle. You removed the tab and made sure no pieces remained in the receptacle then bought a replacement burner, no change. You put the replacement burner in the back burner of the same size and had heat within 10 seconds. You changed out the burner with the one that had been in the back of the range, no heat. As long as the breaker to the range is on the power light stays lit but no power to that one burner only.
What is the model number and the age of your range?
Waiting for your reply.
Huuum
Sep 02, 2008 | Whirlpool GR465LXLS Electric Kitchen Range
Frigidaire 30" Self-Cleaning Drop-In Electric Range - Bisque Logo
37 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Paul Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
