There's only three ways this printer could not be working........
One way is .... that it does not have ink (sometimes kodak printers wont print unless both the black and color ink is above parr)
Second way is ..... it could be broken (which never happens to kodak printers, unless you hit them )
And the last way is .....the driver and the software is not installed ...therefore causing the printer not to print...... (See every printer has an installation cd...... On the cd is what they call a driver for the printer and also on the cd is a software that helps you printer/scan...etc)
Drivers for printers - Helps computer communicate with printer... (Drivers can be found at companies website under support and drivers or on installation cd)
software role for printers- Helps printers do they job....... (Example. Lets say your printer does work, does have ink and does print.......If you don't have the software installed on the computer then the printer wont be able to scan pic and docs....thats the reason for the software sometimes or i could be worst if you don't have the software)
If you don't have the installation cd than... Again drivers and softwares can be found at the companies website under drivers and support....
for proper operation, you will need 12V.
Some vehicles wont start unless there aer 8V.
Minimally 8VDC, but 12V recommended for proper internal amplifier operation. Purchase a used PC Power supply, and wire directly to the hard drive power pug. Inverters are also available.
BTW Amps are a measure of AC Current, not DC. DC is measured in Volts.
An Electrical appliance rated to work on AC will not work with DC, and vice versa.
You will need an invertor of some type to change the signal and wavelength.
It is impossible for the CD to work, unless the CD drive is defective... try other CD drives
If the CD has a lot of scratches then you need to download drivers in the internet to solve the problem... click this link to get the driver. Find number and choose from 55 to 59, since you did not specify your Operating System.
Fixya me if this solves the problem.... Rate me thank you if not.
