Question about Cambridge Audio Azur 540A Amplifier
Wife moaning at sound delay.......why.....
I have sound delay when connecting my azur amp to my tv via sky box & dvd recorder , anyone know why !!! how can i fix it !!! many thanks.
  • 54 Answers
The sound delay would not be caused by hooking amp up but must be a software problem in sky box. Try to get an off air station with a antenna and see if the problem persists.The dvd recorder should see your sky box output first then out from recoder to tv.Then use tv audio out to amp,or tv audio out to amp. RANDY
Posted on Mar 25, 2007
How to besto connect this unit to record from Sky plus box
SCART from Sky box to SCART input on Pana. SCART out from Pana to TV to monitor results. The Pana SCARTs should be marked, one for external source such as Sky box, one for TV
Oct 26, 2013 | Panasonic DMR-E65 DVD Recorder
How to connect Sky digibox & DVD recorder to Samsung UE46ES6300 TV
Buy 2 hdmi leads and use one to connect sky TV decoder to the hdmi 1 socket on the back of the TV and if your DVd recorder has an hdmi socket attach it to hdmi 2 or leave it on the scart socket
as you don't name your dvd recorder the connections available are unknown
hdmi is the best followed by component which requires a 3 cable lead 3 video (video is red green blue plugs ) audio is red and white which is a 2 wire lead which all are needed to get video and audio to your TV
scart is the lowest quality along with composite video
Jul 04, 2017 | Televison & Video
Wharfedale DVD recorder, no sound. Scart lead connected to Sky Box & scart connection to TV. Picture OK & can play DVD's or record to HD but no sound.
HI if you mean scart connectors on rear of DVD recorder, try swapping scart inputs on DVD recorder and if no joys then on set top box. (some units have 1 input designated for TV and the other for Set top box input)
Mar 16, 2010 | Televison & Video
I watch tv via Digital DVD recorder but am unable to see sky tv. Do I need an analogue recorder
You need an analogue receiver to view the co-ax output from your sky box but you should be able to connect via scart
Feb 08, 2010 | Panasonic DMR-EZ47V DVD Recorder/VCR
Have DVD recorder (DMR-EZ27EB)How can I record from a satellite program when the DVD recorder is connected to the AV 2 input and the satellite via SKY box is connected to the AV1 input
Connect the sky to the tv using a scart from the one marked tv on the sky box.Connect a scart from the one marked vcr on the sky box to av2 on the dvd.You then select av2 as your record channel on the dvd.
Dec 08, 2009 | Panasonic DMR-E55 DVD Recorder
I have just bought a samsung lcd tv with 1 scart socket. But I have a satellite box and an hdd recorder but I dont know how to connect it all up. Could anyone help. Thank you
The Sky box should connect to the TV using it's TV Scart output.
The HDD recorder then connects to the SKY via the other Scart.
When you turn the HDD recorder on, the SKY box will automatically switch.
You need to put your normal antenna into the HDD recorder and tune it in.
When the Sky is off, you can use the HDD recorder for playback, you can also switch between the 2 when it is on with the Sky remote.
Sep 05, 2009 | Samsung Televison & Video
Sky+ DVD Recorder Tuning
You need to connect up the Sky+ to your recorder via scart. This will eliminate poor picture quality. The Sky box will be on ext1 on your recorder or something like that
Oct 12, 2008 | Televison & Video
Connecting TV-DVD recorder-Sky plus
scart from the sky to the dvd recorder. then a scart from each to the tv. Job done.
Jan 18, 2008 | Televison & Video
Souud delay on tv /amp
Instead of connecting each device (sky&dvd rec.) to the TV separately, I would simply hook up the sky to dvd recorder (connect the sky output and dvd recorder input), and then connect the dvd recorder output (must be called "play out") to one of the available recorder inputs (which could be a dvr, an empty tape input, etc)of your amp. However, you'll still have to establish a feedback between your dvd recorder and your amp. Therefore, if the dvd rec. supports it, you'll have to hook up the rec.out, which is on your amp.,to rec.in on your dvd recorder. After all these audio connections, you will only need to make a video connection among the sky, dvd rec., and tv. Get a video cable to hook up the sky video output to your dvd recorder's video input, then do the same thing between the dvd recorder's tv output and tv.
Apr 12, 2007 | Cambridge Audio Azur 540A Amplifier
Cambridge Audio Azur 540A Amplifier Logo
281 people viewed this question
Top Cambridge Audio Audio Players & Recorders Experts
 Grubhead
Grubhead
Mike Duncan
Mike Duncan
Are you a Cambridge Audio Audio Player and Recorder Expert? Answer questions, earn points and help others
