Question about Amana ALW480DA Top Load Washer
The belt broke on the washing machine
I need to find out how to remove the water pump so I can place the belt on the pulley.
    Problem Solver:
  • 7 Answers
You will have to remove the whole motor assembly out, then remove the water pump using torx 20 from the whole motor
Posted on Jan 06, 2009
I have a whirlpool ultimate care ii heavy duty super capacity plus washer that fills, and agitates, but will not "spin" or drain water. What do you guys think needs replaced?
"If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:
If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt.
If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it."
May 04, 2015 | Whirlpool Washing Machines
Washer won't spin
Hi
One of the most common problems with washing machines, however, is that they won't spin. Usually this is caused by an issue that easily can be fixed, but other times it can be more serious. In some cases, just the balance of the load can cause the machine not to spin.
First open the lid and reposition the clothes. Close the lid and retry. The washer may not spin at all if the tub is unbalanced.
Examine the lid switch for wear. Replace a worn lid switch by first using a screwdriver to remove the top of the machine. Remove the cabinet holding the old switch in place by unscrewing the two console screws, tilting the console back, removing cabinet clips, and unlocking the lid switch block. Unscrew the mounting screws, and disconnect the ground wires before removing the old switch. Insert the new switch in it's place.
Look for excessive glazing or cracks on the sides of the belt. If these signs appear, remove the old belt by tipping the washing machine over on it's side, and unscrew the clamps securing the pump coupling with a screwdriver. Place the new belt over the transmission pulley, and then over the motor pulley's nearest edge, slowly turning the motor pulley to pull the belt around and into the pulley.
Replace the washer's motor by firmly grasping on the metal slip-on connectors holding the wires in place, allowing you to pull the connectors apart. Use a screwdriver to unscrew all of the screws holding the motor in place, and remove the old motor. Insert the new motor in its place. Secure the new motor to the machine with screws, and reconnect the motor's wiring harness.
Replace the washer's pump by removing the service panel on the back of the machine with a screwdriver and disconnecting the washing machine drain line and the rubber pump outlet hose. Remove the fasteners holding the pump to the bottom of the machine, along with the drive belt from the pulley below the pump. Replace the old pump with a new one, and reinstall the drive belt back on the pulley, reinsert the fasteners and reconnect the rubber pump inlet and discharge lines.
Also check this link to get a detailed idea related to your issue:-
http://www.repairclinic.com/Washing-Machine-Troubleshooting?red=Washing-Machine-Repair-Help#itdoesntspin
Please get back to us if you have further query or else please accept the solution.
Sep 03, 2011 | Whirlpool Ultimate Care II LSQ9564J Top...
Drum will not spin in any cycle
Hi
For that reposition the clothes. Close the lid and retry. The washer may not spin at all if the tub is unbalanced.
Check the lid switch for wear. Replace a worn lid switch by first using a screwdriver to remove the top of the machine. Remove the cabinet holding the old switch in place by unscrewing the two console screws, tilting the console back, removing cabinet clips, and unlocking the lid switch block. Unscrew the mounting screws, and disconnect the ground wires before removing the old switch. Insert the new switch in its place.
Then check for lose or worn or crack in belt. If these signs appear, remove the old belt by tipping the washing machine over on its side, and unscrew the clamps securing the pump coupling with a screwdriver. Place the new belt over the transmission pulley, and then over the motor pulley's nearest edge, slowly turning the motor pulley to pull the belt around and into the pulley.
So there are various conditions when a washing machine wont spin. Please check this link to get a detailed idea related to your problem:-
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Aug 05, 2011 | LG WM1814CW Front Load Washer
It does not spin - error
Hi
Open the lid and reposition the clothes. Close the lid and retry. The washer may not spin at all if the tub is unbalanced.
However there are various reasons as to why a washing machine won't spin. Also check this bellow link to troubleshoot your issue:-
May 03, 2011 | LG Washing Machines
How To Repair a Washing Machine That Won't Spin?
Instructions: 1)Open the lid and reposition the clothes. Close the lid and retry. The washer may not spin at all if the tub is unbalanced. 2)Examine the lid switch for wear. Replace a worn lid switch by first using a screwdriver to remove the top of the machine. Remove the cabinet holding the old switch in place by unscrewing the two console screws, tilting the console back, removing cabinet clips, and unlocking the lid switch block. Unscrew the mounting screws, and disconnect the ground wires before removing the old switch. Insert the new switch in it's place. 3)Look for excessive glazing or cracks on the sides of the belt. If these signs appear, remove the old belt by tipping the washing machine over on it's side, and unscrew the clamps securing the pump coupling with a screwdriver. Place the new belt over the transmission pulley, and then over the motor pulley's nearest edge, slowly turning the motor pulley to pull the belt around and into the pulley. 4)Replace the washer's motor by firmly grasping on the metal slip-on connectors holding the wires in place, allowing you to pull the connectors apart. Use a screwdriver to unscrew all of the screws holding the motor in place, and remove the old motor. Insert the new motor in its place. Secure the new motor to the machine with screws, and reconnect the motor's wiring harness. 5)Replace the washer's pump by removing the service panel on the back of the machine with a screwdriver and disconnecting the washing machine drain line and the rubber pump outlet hose. Remove the fasteners holding the pump to the bottom of the machine, along with the drive belt from the pulley below the pump. Replace the old pump with a new one, and reinstall the drive belt back on the pulley, reinsert the fasteners and reconnect the rubber pump inlet and discharge lines.
thank you and hope this helps
Feb 09, 2011 | LG WFT1071TP Top Load Washer
Belt amana washer replace mod lw6501w2
I have a similar amana top load washer and just changed the belt. Here are the steps I used to change the belt:
1) Unplug the washer
2) Slide the washer away from the wall about 12"
3) Remove two screws from the bottom of the front panel, slide the front panel down (there are 2 metal tabs that slide into slots on the top of the front panel - observe how they slide into/out of the slots). Set the panel aside.
4) Remove the electrical connector (upper left of motor). Press down on the top of the plastic connector - this will undo the catch hook holding the connection in place). Observe how the belt is routed before proceeding.
5) Remove 4 bolts holding the motor in place. You can remove the motor - even with the water pump and hoses in place - they will flex.
6) Remove the water pump from the motor. There are 3 torx - head screws to remove. Note: You will need a star shaped (torx) head driver (Looks like a screwdriver but with a "star" head on it. The one I used measured just under 3/16 in diameter.
7) carefully remove the water pump. - remove the old belt from main pulley under washer drum and also from the water pump. Insert the new belt - be sure to put the tension pulley on the outside of the belt.
8) Reinstall the water pump to the motor. Reinstall the motor. Route the belt correctly in the water pump body area first - them slide the belt around the left side of the main drum pulley - rotate the pulley counter-clockwise and the pulley will tug the belt onto the pulley. Once in place - check bolts and belt - then reattach the electrical connector (remember to press the plastic lever on top of the plastic connector before sliding it in place). Reattach front panel - slide the top of the panel onto the metal tabs - then attach screws at the bottom.
Feb 23, 2009 | Amana 3.2 cu. ft. Top-Load Washer
Maytag Performa PAV2300AWW screaching noise, belt problem, pulley broke
My Maytag Performa was making the loud squealing noise. I changed out the water pump/bearing, took care of the problem.
Putting a new belt on just help burn up the bearing (they needed replacing) and probably ruined the new belt. Probably seized the water pump bearing and the belt jumped and broke the motor pully. A washing machine motor is very strong, when that h20 pump bearing seized (or possibly some bearings jamed up) the motor kept on turning that belt and the plastic pully gave in. You'll need to replace that also. If the h20 pumb bearing is turning freely, likely the bearings jammed up but or now loose. That bearing should be tight, no slack or play in it. You can probably wobble the pully on it all around while turning it. The slightest slack is too much.
Oct 09, 2008 | Maytag Performa PAV2200
I have a GE top loading washing machine. Model #wjrr4170gww. I need to replace the belt and can't seem to get the belt on. I know it is a tight fit, but my question is what is the trick to get it on.
Dear Customer,
To replace the drive belt, you will need to open the access panel or in some cases tip the washer onto its side to expose the belt on the bottom. Start by removing the back cover, and look for a belt. If you do not see a belt (or a place for a belt - the belt itself may have broken and is hidden from view) and you can see the floor then your washer is a direct drive model that does not use a belt.
If you cannot see the floor because there is a steel floor in the washer, locate the motor and determine if it extends through the bottom plate. If so, then the belt is accessed from beneath the washer.
If you have to tip the washer over, place a large piece of cardboard on the floor to protect the floor and the washer's finish. Because a washer is pretty heavy, you will need an able-bodied assistant to safely tip the washer onto its side.
Also, there will be some water remaining in the washer, so have sponges and towels ready to clean up any spill.
To remove the old belt unscrew the clamps securing the pump coupling ( a leathery or rubber flexible part that connects the motor to the water pump). Remove the pump coupling to slip the old belt out. Some models instead require you to loosen the motor mounting bolts and shift it inward to relieve tension on the belt. Remove the old belt.
Place the new belt over the transmission pulley first then place it over the motor pulley. If it is too tight, place the belt over the motor pulley's nearest edge and then slowly turn the motor pulley to pull the belt around and into the pulley. Replace the pump coupling or tighten the motor mounting bolts. The belt should deflect no more than one half inch when you press on the longest straight run.Replace the cover and test the washer for proper operation.
Thank You for using Fixya.. Good Luck!!
Jul 10, 2008 | Washing Machines
Changing belt on washing machine, that broke
to change the belt you need to remove the pump attatched to the motor. the pump is held on by either spring clamps or in older models, torx (star) screws. I believe the size for the torx screws is #20. slip the belt over the motor pulley and around the tension pulley and finally around the transmission. reinstall the pump and you're good to go.
Aug 18, 2007 | Amana ALW540RA Top Load Washer
New belt
First put the belt around the small pulley, shd be the motor pulley i think. Then ease the belt around the big pulley & gently move clockwise if the pulley is on the left side; anti clockwise if you are inserting on the right side. The belt will fall into place. Actually it is very simple.
Apr 18, 2007 | Maytag SAV4655A Top Load Washer
Amana ALW480DA Top Load Washer Logo
78 people viewed this question
Top Amana Washing Machines Experts
Dan Webster
Dan Webster
Richard Roth
Richard Roth
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
