Question about Sony KP-51HW40 51" Rear Projection Television
Convergence issues on Sony KP-51HW40
How do I know if the lenses need to be realigned or replaced? thanks
    Genius:
  • 2,920 Answers
You cant realign them they are factory set so you would need to replace them if the colors are out of line or you cant reset it manually. the tube are preset and not meant to be redajusted
Posted on Dec 14, 2008
Picture looks like a 3-d screen
This kind of problem occurs due to failure of convergence output ICs in Sony KP-51HW40 tv.
Replace convergence output ICs to solve tv problem.
Local tv repairman will do this job if you have no experience of electronics stuff repair.
Thanks.
Nov 12, 2010 | Sony KP-51HW40 51" Rear Projection...
KB-51HW40 blur with different colors layers
Its called the Convergence. Its likely a device on one of the main control boards is failing. these are a common issue on the projector tv's usualy it will be a whole board replacment, OR componnt level trace and replace. This is something unless you are familiar doing can be quite hazardous. If your not sure get a local shop to give a free estimate, all my projection tv's have done this with time, you can even go into the menus and realign it through tv settings, but sometimes they will start to wander out again.
Nov 15, 2009 | Sony KP-51HW40 51" Rear Projection...
My colors wont stay converged
put a convergence repair kit in the set that will usually repair the Issue. You can get the Sony convergence repair kit which works with your model at the following link. The kits contain the replacement parts and complete instructions www.tvrepairkits.net
Jun 23, 2009 | Sony KP-51HW40 51" Rear Projection...
Sony kp 51hw40 real projection tv
Below is exploded view of your Sony KP-51HW40 TV rear side which shows board names and location.
You need to check D Board for convergence ICs and these are marked as IC8001 & IC8002 on circuit board.
Nov 23, 2008 | Sony KP-51HW40 51" Rear Projection...
Sony KP-51HW40 Convergence issue
Sorry about that heres the link. No installing the board will not involve soldering if you decide to go that route.
http://servicemanuals.vstore.ca/
Apr 10, 2008 | Sony KP-51HW40 51" Rear Projection...
Can you adjust the convergence by the convergence menu without going through the service menu? The settings through the convergence menu should save automatically. Have you replaced the convergence ICs? If so the settings should save, if not the D board will need to be replaced or at the very least rebuilt. Let me know if you need further assistance with this issue.
Intermittently convergence problem.
Try resoldering both convergence ICs located on the D board if that doesnt correct the problem you will need to replace both ICs let me know if I can assist you further.
Apr 04, 2008 | Sony KP-51HW40 51" Rear Projection...
Sony tv KP-61HS10 lenses wont align
This is common in those sets. One of your convergence IC's has stopped working and needs to be replaced. The convergence IC should be replaced and the convergence circuits realigned by someone with experience in Sony projection sets.
Aug 09, 2007 | Sony KP-61HS10 61" Rear Projection...
KP-51HW40 - Picture not Clear
Your problem is a typical convergence problem that happens on almost every tube type projection TV set ever built. There are two Convergence amp IC's that need to be replaced. If you have no TV repair experience, play it safe and call in a pro to assist you in this. Good Luck
Apr 29, 2007 | Sony KP-51HW40 51" Rear Projection...
Sony KP-51HW40
I read it online that this is a very simple problem. It needs highvoltage splitter. I tried to open the front panel to see where the splitter is. However, I need some hint as to how to open the front panel. Good luck. Kiran
Feb 19, 2007 | Sony KP-51HW40 51" Rear Projection...
Sony KP-51HW40 51" Rear Projection Television Logo
74 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
