Unit is plugged into power source but will not turn on manually nor with remote.
SOURCE: I can't get a signal
My suggestions here are to check your connections from your player to your tv. Make sure that if you are using the red, blue, green, red, white composite cables, that they are properly seated and connected. Next check your tv, and make sure that your cables are connected properly on the tv and that your tv is on the proper input. If you are using a HDMI cable and you still have no picture on your tv, there is a slight possibility that your cable could be bad. Hope this helps, if you still have no picture at that point I would recommend calling the support number for your device!
SOURCE: lost my remote for my RCA RT2500 Audio/Video
You need to confirm if the power switch is working as the button is stuck . So it is best to get this part corrected before we move to the remote as the power switch or the button aligment can be corrected if you open to check the continuity. http://www.fixya.com/support/r6178946-tips_repair_remote_controller
Next the remote controller must be checked for the IR outputs. please check this link below for tips to repair or find a link for a universal type remote.
