Question about RCA HD52W59 HDTV Projection Television
No picture When I turn TV on the Power light is green and flashes once and then slight pause and then flashes 8 more times. What does this code mean and what can I do to fix it?
  • Bath_FF Dec 16, 2008
    I have no picture and the green light comes on then a short time later goes off
  • Anonymous Dec 17, 2008
    I have no picture and the green light comes on three times and goes off please help.
    Problem Solver:
  • 6 Answers
Try the menu button
Posted on Dec 14, 2008
Sony kds-60a2000 power light flashes 5 times, no picture
5 flashes - Lamp Driver - (lamp driver faulty)
This is the error code that usually means the ballast (it is the power supply for the lamp) is bad.
Apr 20, 2012 | Sony KDS-60A2000 60" HDTV
Power light blinks 4 times pauses then blinks 6
Not sure what the code means (mine occurred after a slight power surge...maybe an overheat or some kind of overload), but after leaving the tv off for 10-15 minutes the flashing stopped and the picture was fine on restart. I know you've probably figured this out already, but hope it helps somebody because Philips apparently does not want to make it easy to figure out what these codes mean.
May 27, 2010 | Philips 50PFP5332D 50 in. Plasma...
Red light and 2 green lights on front panel on.
This is an error code it means the TV is in protection mode. Which means it has detected a problem and is preventing power up so not to cause further damage. Error codes are generally 2 numbers 1 seq of flashes a pause and a second sequence of flashes. Most common problems for LCD are Video logic / Main input board or the power supply. For more info and possible solutions post your make and model.
For parts and info check.
or E-bay
Oct 20, 2009 | Televison & Video
Stays on for 2 seconds and switches off
A 2-2 code on that unit means over current shutdown. 95% of the time that code indicates defective convergence output IC's.
Jun 09, 2009 | Mitsubishi WS-65869 65" Rear Projection...
Picture Won't come on
Check capacitor cp150 2200uf 16v if bad replace 2 more caps in same circuit 220uf 35v. They will be located on bottom left board. Power/deflection board.
Dec 14, 2008 | RCA HD52W59 HDTV Projection Television
WS 55315 Tv won't turn on-
Thanks for your help can you send photos so I can see what to look for
Dec 01, 2008 | Mitsubishi WS-55315 55" Rear Projection...
Timer light will not go off and I cannot turn on TV
Are you asking about the wd62525? If so that's a v26 chassis and equipped with a self diagnostic test by flashing a series of two digit sequence after depressing the power button. After depressing the power button count the number of flashes - then you'll see a slight pause - then another series of flashes. (for example: four flashes, pause and four more flashes is an error code 44). The unit repeats this coding at least three times so be as accurate as possible...
Sep 26, 2008 | Televison & Video
Green flashes then tv turns off
or a new lamp. you could first replace the lamp.
the screen might work fine for a couple of seconds, but then it fades away or deteriorates. This means the lamp is going bad.
Aug 23, 2008 | Sony KP-51HW40 51" Rear Projection...
Sony KDP-65WS550 flashes when you try to turn it on
No the DLP units can flash more than 8 times. 9 blinks mean Zero Crossing detector which means diode number D6166 or D6114 is open they are on the A board.Let me know if you need any further info.
Feb 23, 2008 | Televison & Video
Red light flashes 8 times
i dont know the error code but my standby red light is blinking 8 times
Feb 10, 2008 | Sony BRAVIA KDL-40V3000 Television
RCA HD52W59 HDTV Projection Television Logo
70 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
