Question about Refrigerators
Samsung RF265AABP bottom freezer model warms up
The refrigerator is about a year old. It says to keep it at 38 degrees but the fridge says 34 degrees no matter what the temperature is or what we turn it to. A month ago it warmed up (could tell it was not cold enough, even though it indicated 34 degrees), then a couple of days later cooled down again to a reasonable refrigerator temperature. Now it has stopped cooling and the ice cream is soup. The blue teardrop symbol with the star inside it is blue; the little symbol below that with the drop falling from a box shape is red. Help!
5 Suggested Answers
22yooper
  • 828 Answers
SOURCE: Refrigerator warm, freezer cold
Totally Unreasonable if you don't mind me saying so. The person who told you that story was thinking of an absorption unit more than likely.
Your proble is related to the defrost system of your refrigerator. There is a timer that automatically starts the defrost. It energizes the heaters that defrost the cooling coil. After the coil reaches a preset temperature a defrost terminator turns the heater off for the remaining time on the timer cycle. You could have a bad timer (stalled) which would not start the defrost. Locate the timer and turn the clutch head screw clockwise very SLOWLY until you hear one audible click. The defrost should take place and will be indicated by water in the drain pan under the refrigerator. If after 25 minutes it does not restart in the cooling mode turn the screw once again to the second click and replace the timer.
If the refrigerator restarts after 18-22 minutes and defrost does not take place your problem is in the heater circuit. Open heater or thermostat (termination switch)
Posted on Jul 16, 2008
TheMobilian
  • 8220 Answers
SOURCE: freezer not keeping ice cream cold
One thing you can do is clean out the area under the ice box where the condenser coils are located. Make sure the fan motor is blowing under there. Clean the kickplate. Get the air restrictions out of the fins and that may bring the freezer temp back up to par.
Posted on Jan 08, 2009
  • 531 Answers
SOURCE: 16 month old GE Profile
see if the back wall inside of freezer have ice if so you have to change tiker board or check your doors if closing
Posted on Mar 31, 2009
heatman101
  • 43501 Answers
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator2_bing.gif Condenser Coil Cleaning Refrigerator2_bing.gif Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting2_bing.gif Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Posted on Aug 12, 2010
The temperature of my GE Model PSH23PGSD in freezer and refrigerator will not maintain 0 and 34
heat rises so if it's cold on the bottom and warm on top in freezer it sounds like you have a bad evap fan motor,when you open the freezer door do you hear the fan blowing,if not look around and hold the door switch in and see if it blows on some models fan won't run unless door is closed but if no fan you have a bad fan motor,the problem with ge is everything runs through the mother board located in the back,also i've found that the fan blade slides off or out of position on the shaft and it just doesn't move any air but you have to find out if it's the fan motor or the board,also the fridge should be set at 37 or 38 not 34,if your handy and you're going to fix this yourself,i would get both parts from repair clinic because you have 365 days to return parts,change the fan motor first if it sounds like the fan is your problem and see what happens,this way you have both parts and you can fix it that day and send back any part you don't need,if that's under 8 years i would change the fan motor,it's cheaper than the board if this is what's happening.hope this helps and good luck
Sep 29, 2017 | GE GBS18HBR Bottom Freezer Refrigerator
Samsung french door fridge, bottom freezer
It might be a power supply problem. My RF265AABP model has +5V and +12V from the power supply board located in the compartment with the control board.
Jul 09, 2013 | Samsung Refrigerator PCB Board -...
Freezer turns of in cold weather
Many residential refrigerator / freezers are designed to work at temperature considerably above above freezing. Most modern refrigerator / freezer have a single electric thermostat - located in the fresh food compartment. This lone thermostat will control the compressor to keep the fridge (fresh food) section at the desired temperature (usually between 34 - 38 degrees F). The freezer will get colder regardless of how cold it is already whenever the fridge thermostat turns the compressor on.
Now that you see how the thermostat works, let's look at what happens when the fridge is placed in an unheated space - like a garage. In winter time, the temperature can drop considerably below 38 degrees. If the outdoor temperature remains cold enough, for long enough - it will affect the thermostat in the fridge. The temperature inside the fridge could drop below 38 degrees, preventing the thermostat from telling the compressor to turn on. Meanwhile, the temperature in the freezer compartment slowly rises from the normal -10 to 0 F degrees. It will continue to rise until it is the same temperature as the fresh food compartment or until the thermostat in the fresh food compartment tells the compressor to turn on again. This means the freezer contents will thaw.
If the temperature in the garage is even in the 40 to 50 degree range, the loss of cold in the fridge may not happen often enough to keep the compressor coming on often enough to keep some freezer items frozen solid - such as ice cream. Remember, water freezes at 32 degrees F, other products may require lower temperatures to remain frozen, and could thaw at 28 or other temperature.
Feb 13, 2012 | Refrigerators
Have had this refrig. for several years and have had no problems until our 2 year old grandaughter played at the temperature controls about a week ago...The freezer has been set at -2 and the regrigerator...
Hi there
Samsung's child lock is easy to alter
Press the vacation and fridge temp buttons simultaneously and hold for 4 seconds, this will release the child lock, to reinstate the lock just repeat this. 4 seconds is quite a long time.
Hope this helps
Gordon
Apr 20, 2011 | Samsung RB215LASH
My Maytag fridge is not working, but my freezer works fine. What do I do? The freezer is on the bottom, with the fridge being on top
Hi
Do you have any ice cream in the freezer? If it is soft than the freezer is also too warm. If you do not have icecream then you will need a thermometer to check freezer temps. Freezer needs to be 10 degrees F or colder down to -10. fridge should be 34-38... Sometimes freezer temps can seem cooler than they are with out a thermometer to test it. Also look for frosting up inside the freezer. Check that your door seals are in good condition. check that doors are closing completely.
Please let me know If I can help further.
Apr 14, 2010 | Maytag MBF2556HEW / MBF2556HEB /...
Freezer is cold but not keeping icecream frozen.
If, the fresh food section is 34- 38 degrees, then the freezer should be cold enough to keep ice cream solid. All of the cooling capability comes from the freezer section. I, personally, would not waste time or money on a ten year old box. Ten years ago it cost $1000, so, the outlay is $100 per year. Dump the old refrigerator and get a new one.
Aug 27, 2009 | Refrigerators
What temp should the fridge and freezer each be?
According to FDA safetey specs bacteria can grow at 40 to 140 F degrees .Refrigeration must be below this number but above 32F to keep from freezing. I maintain commercial refrigeration and they run at 34 to 38 F degrees. I have deep freeze set at -10F which keeps ice cream very solid but can go up to +2 F which renders softer ice cream...
Jun 25, 2009 | Kenmore 64802 Top Freezer Refrigerator
Sub zero 650 fidge holding at 53 degrees
That depends on if your model has a five or ten year warranty on the compressor. Your problem may not be warranty related. Check and see if the condenser is clean, check for a frozen cooling coil.
Jun 02, 2008 | Sub-Zero 650 / O Bottom Freezer...
Refrigerators Logo
169 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
