Question about Aspire (ATX-AS500W) (atx-as500w 12v) Power Supply
Missing -5VDC and -12VDC
Bench tested ATX-AS500W PS and it is missing the -12VDC and -5VDC on the pins that plug into the mother board. Is there a fuse to replace?
  • 341 Answers
Could be.Some do some don't.Some have a circuit breaker. Take the cover off and check. Be careful though as some parts in the power supply can hold a pretty significant charge for quite a while even after the power supply is turned off.If there is no fuse or if you change the fuse and it blows again I would say a new power supply is in order. Good luck.
Posted on Dec 15, 2008
Fan is working without 4 pin ATX pin but not with 4 pin ATx
Fans are Controlled by Temperature Control Setting of the Mother board. So the Fan controller is a function of the BIOS of the Mother Board...
Jul 17, 2014 | Intel Computers & Internet
The tv went off and back on at 10 second intervals Now it wont come back on.
this is indication from power supply, You must test this area. Missing +5vdc-5vdx+12vdc-12vdc etc.
God bless you
Jul 15, 2013 | Sanyo Televison & Video
How do I test a High Voltage Transformer on my Vizio VU42L-FHDTV10A?
It could be the main board. The main board controls the standby light on the front of the set. Check and verify that your 5vdc standby voltage is working. Next, I would check the "on" or "ps on" input on the power supply board. When you turn the set on (either my side buttons or remote) the main board should send a 3.3vdc signal into the "on" terminal on the power supply. This "on" signal from the main board turns on the other half of the power supply thus turning on your set. If you are not getting this signal from the main board, I would suspect the main board. To test your power supply, you can simply put a jumper from 5vdc to the "on" terminal on the power supply. Your 12vdc, and 24vdc power supplies should then become active.
Oct 31, 2012 | Vizio Televison & Video
E Machine ATX 250 -12E replacement PS
With emachine MOBO's you have to make sure you plug in the 20 pin plug from the power supply to the mobo. Also make sure all hard drives, cd/dvd roms, floppy drives, etc are turned on. Make sure the red switch on the PS is set to 115. Make sure the PS is plugged into a known working outlet. Make sure MOBO is properly in place with all grounds/screws in place and nothing metal near or touching board which may short it out.
You can review the E Machines PS replacement guide here for further instruction.
Good Luck,
Jesse
Jan 11, 2010 | Gateway Emachine Bestec ATX-250-12E PS...
Want to use the atx-300-12z as a hobby power supply. Need 12vdc.
You're asking for a fire or just burning out the power supply. But,at your own peril, check the yellow wires for 12v or buy a power supply test adapter from ebay. It bypasses the power switch usually done by the motherboard & will fire up the power supply like it was connected to a board. Then test the wires for 12v. Should be any yellow wire,red is 5v. Green is 3.3 or 3v.
Jul 22, 2009 | HP Bestec ATX-1956D 200w HP Part No...
Laptop HP Pavillion zd7000 (model zd7058cl) does not turn on
May be this sound crazy, but helpful to me in many cases.
Unplug all easily detachable parts and press turn On key for 20 to 30 seconds. Again resemble it and try to turn on. I hope it will work fine. if not don't waste your time and contact to local or online repair center.
Cheers
John
For any Tech Query: +1 (844) 355-5111 (toll-free)
Apr 17, 2017 | HP Pavilion zd7000 zx5000 zv5000 presario...
Need pinouts
I have an old pc chips M575 motherboard that also uses the J3 ATX Form card. I can only assume the pinouts are the same so here they are from the manual.
Pins 1-4 and 10- 13 are USB connectors
USB USB
Pin Description Pin Description
1 +5v 10 +5v
2 data- 11 data-
3 data+ 12 data+
4 ground 13 ground
Pins 5-6 and 15-16 are PS/2 Mouse Connector
Pin description
5 +5v
6 Mouse CLK
15 Mouse Data
16 ground
Pins 7-9 and 17-18 are Infrared connector
Pin description
7 Ground
8 Reserved
9 +5v
17 IR in
18 IR out
hope that helps
Nov 18, 2008 | Pc Ware M748LMRT Motherboard
Vizio P42HDTV Power on Diagnosis
Relays are the first big clue, triggered by the 5 & 12v supply you should be able to trace back using a dmm and see if you have both of those voltages present... The lead coming from the smps to the y-sus board is a good start. On a Vizio I believe the voltages are listed per pin right on the board...
If you had any kind of relay sound then you could suspect the y-sustain or z-sustain board or something else. With the relays being silent I'd strongly suspect the power supply.
Bill
Apr 06, 2008 | Vizio P2 42 in. HD-Ready Plasma Television
SFX-1211J no -5vdc
The -5 V requirement for ATX supplies was dropped after V1.3. It was used primarily for the old legacy ISA slots - though not exclusively. If you test any contemporary supply made in the last few years if will show a -5 V failure because it just ain't there! Unless you had a really old MB, the supply is probably fine. Look at the 20 or 24 pin MB connector and if there is no line where the -5 would be ( pin 18 ) then you have no problem.
Jan 04, 2008 | Enhance Technology SFX-1211J, Enhance 110W...
Aspire (ATX-AS500W) (atx-as500w 12v) Power Supply Logo
113 people viewed this question
Top Aspire Computers & Internet Experts
pankaj rautela
pankaj rautela
Jax Planet
Jax Planet
john smith
Are you an Aspire Computer and Internet Expert? Answer questions, earn points and help others
