Question about NAD T761 Receiver
Optical Audio problems with T770 NAD Receiver
I've had this receiver for years and has worked great. Has a digital coax input that has always worked flawlessly but the optical input has always been "iffy."
When I had it hooked up to the cable box, the audio through the optical used to take 5 minutes or so to "kick in" when the box was rebooted.
I then switched the cable box to the digital coax and moved my DVD player to the optical.
With my Denon DVD player it would work, but sometimes take10 minutes before it did so.
A year ago I bought an HD DVD player, (doh, now obsolete), but it worked great with the optical for a while, and then slowly started to take more and more time to work, (ie. no sound through the optical for about 10 minutes and then eventually it took 30 minutes).
Now there is no optical audio at all.
Thoughts?
I'm assuming the problem lies with the receiver as all 3 devices had "issues" with delay in getting the receiver to accept the optical audio.
I've had the receiver since it was new.
The thought of unhooking that thing and taking it in for sevice is daunting.
Thx.
Geoff Jones
Santa Rosa, California
5 Suggested Answers
SOURCE: Right surround channel not working in some modes
I had the same problem with the right channel.    It turned out to be a broken wire inside the receiver; it can be found connecting from the main PCB to the card for the 5.1 board.    After repairing the broken wire, it has worked fine.
The harness connects the 5.1 low level signals to the board which are then redistributed to the amplifier section.     It is a bundle of wires in gray casing and with red, black and white wires (with shielding).
Find the offending wire, repair or replace and it should be fixed.
Hope this helps
Posted on Oct 27, 2007
Dipu007
  • 2110 Answers
SOURCE: Nad T770 Manual
http://nadelectronics.com/img/manual/NAD-T770(EN).pdf
Posted on Dec 18, 2008
SOURCE: NAD T743: The digital channels stop working after a short time.
I had the same problem just once, about a week and a half ago. Don't tell me that this problem is going to get worse.
Posted on Feb 04, 2010
mikeywaf
  • 346 Answers
SOURCE: I have an NAD T755.
Hi - Not a flash of brilliance I know, but have you switched physically the HDMI cables between the PS3 and STB before connecting to the NAD?
Also - You might try (if you have them) a set of component cables from the STB to the receiver to try and see if the cable box may be having having difficulty with your NAD.
If you can let me know the results of cables switching I'd appreciate it. On a personal note I both love and hate HDMI, having had similar problems 8^)
Good Luck
Posted on Mar 26, 2011
No sound on coax audio input from HDTV
Check your settings on your tv. You may have to turn off the internal tv speakers in the setup menu in order to get any audio output from the jacks on the back.
Dec 20, 2012 | Sony STR-DE835 Receiver
Hmm, sounds similar to my problem. Analog input and FM seems to work but all coax/opto input are dead ( for me there isn't a buzz).
Have you, fredrik648, solved your problem?
Anyone with ideas what to do?
Thanks
///Johan Westerlund.
May 11, 2009 | NAD T743 Receiver
Using NAD t743 with Panasonic DMP-BD55
The reciever you have has 5.1 inputs at the backof it.The only way to get Dolby True HD and DTS HD is to run the 7.1 analog out from the bd55 to the nad. You'll have to leave the 2 rear surround open on the bd55 leaving the remaining 6 connected to the nad. The digital coax and the optical will not transmit the hd data, only the analog out will. Run a hdmi right to your HD tv for picture bypassing your amp. this will workfine and you'll have the audio you want. You,ll have to change the input settings for dvd in your amp to 5.1 to recieve the audio.
Dec 14, 2008 | NAD T743 Receiver
No sound from optical or coax digital inputs
You have to use the system setting using the remote and turn on the inputs you want to use. Hope this helps.
Keith
Oct 16, 2008 | Denon AVR-1602 Receiver
Connecting new tv to DRA-685
you can use the headphone jack just get an adaptor to change from the headphone type to RCA type. adjust the volume of the tv to 3/4 of the way to give line level to the stereo, use an aux input on the stereo. if you had a suround sound dolby digital / DTS receiver then use the digital coax out to that type of receiver, but since you have an anolog 2 channel receiver you must use the only anolog source (the headphone).
May 21, 2008 | Denon DRA-685 Receiver
NAD T770 (T2 Monitor button)
the best solution for this problem is to throw it away and never buy nad again. its junk.
Apr 21, 2008 | NAD T770 Receiver
No HDMI video output from AVR-588 receiver to plasma TV ???
the avr-588 apparently cannot carry sound via hdmi - don't know why; just what i found out from the geek squad at best buy; solved the problem by connecting optical cable from cable box to receiver; be sure to change the input on the receiver for opt-2 (system setup >2 inputs) to correlate with tv
Feb 16, 2008 | Denon AVR588 Receiver
Sound from digital input(s cut out
You are probably correct. The input switcher IC or the power supply feeding the Optical switcher is most likly got a problem. The cost to diagnoise a problem like this could cost you with a repair, more then you could most likly get a new reciver for. Its a shame of all the great technology that gets thrown aweay in the dumps every day. Good Luck PS please do not forget to rate this thread.
Dec 11, 2006 | Kenwood VR-2090 Receiver
NAD T761 Receiver Logo
147 people viewed this question
Top NAD Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a NAD Audio Player and Recorder Expert? Answer questions, earn points and help others
