Question about Samsung HL-R5668W 56" HDTV
DLP problems Hello, my model no. is actually HL-S5688W. This set was delivered on Friday, and the problem I'm having has gotten progressively worse each day. I can only descibe it as the TV is posessssed. It basically does whatever it wants whenever it wants. To be more specific, the set will freeze up then go blank then go blue then shut off then come on play for a short while then freeze then play for a while with some of the pixels dropping in and out. When this is going on I have absolutely no control over it. Neither the remote or the panel controls work. I have continuously tried unplugging and plugging the set. If the set is unplugged for several hours and then plugged back in, it will work for the first 5 or 10 minutes then the channel freezes. Meaning I have lost control of the TV. If I try to turn the set off, it will continue to play for a while then freeze, go black or blue then eventually shut off. I have contacted Samsung and they have arranged for a service call, but I have to wait a week before someone can take a look at it. I would appreciate any advice you may have.
    Champion:
  • 217 Answers
Since you cannot control the set with the remote, it is a main board problem
Posted on Mar 17, 2007
No Sound
Go to settings speakers and check unless cables faulty hdmi or scart connections
May 30, 2014 | Samsung HL-S5688W 56 in. HDTV Television
Lose normal engine power
some more info would help, might just need a tune up. is there an engine light on? what codes? does it drive fine then loses power?did this isue just start one day or has it progressively gotten worse?
Apr 02, 2014 | 2006 Ford Freestyle Limited
Don't watch video My project I have a 1991 Ford XLT Lariat that had a 302 efi V8 in it. I noticed I lost power one day and progressively gotten worse. I was going through 3 qts of oil a day in the la
Are u leaking oil if not your piton rings have gone most luckily and it is a huge job to put new ones back In might be best to get a new engine
Nov 02, 2012 | Cars & Trucks
Picture breaks up sometimes
check your cable connections from cable box,satellite box, etc... cables need to be tight, not just finger tight.
Jan 03, 2011 | Samsung HL-S5688W 56 in. HDTV Television
I bought a new home in Allen Tx in Sept. 07. I
sounds like the pump is week get a new pump
Dec 03, 2009 | GE Dishwashers
MY SATURN VUE 2003 6 CYLINDER IS leaking anti freeze
The water pump is on the front of the engine. Does it look like a hose leak?
Nov 19, 2008 | 2003 Saturn VUE
Not charging
Hello brocstar,
You could have a problem either with the power cord itself or the DC input jack on your GPS.
When you say you wiggled the "power lead" to fix the problem I believe you are referring to the actual power cord. If so, it's possible that the cord has a short that has progressively gotten worse and eventually caused the cord to fail. In that case it should be a relatively simple fix to simply replace the power cord and that's where I would start.
If replacing the power cord doesn't work then the problem likely is with the GPS itself and the unit may need factory service to repair the DC jack, battery or charge circuitry.
Hope this helps,
Ken
"Go Ahead. Use Us."
Jul 10, 2008 | Navman F20 GPS Receiver
Toshiba - 50H13 Projection TV
There is a large metal case behind the input board in the back of the set called the hyper board that needs to be replaced.Good Luck
Oct 07, 2007 | Toshiba 42H83 42" Rear Projection...
Samsung HL-R5668W 56" HDTV Logo
97 people viewed this question
Jerry Greenberg
Jerry Greenberg
Demonic-2011
Demonic-2011
