Question about Hitachi RAS-09UH Air Conditioner
Outdoor unit will not run
Its 22 F outside I have a outdoor Infinity that will not run .The indoor is fine Its a fish store with lotsa great stuff but need cooling 'Its a 4 ton unit its been fine when temps are 28 to 32 help or I'll be eating lots
  • Stephen Evans May 11, 2010
    have you check the fuses?circuit breaker?
    Guru:
  • 588 Answers
Running an air conditioner in the winter.
Generally they have a low pressure switch on them that won't allow it to run when the pressure falls below about 60 psig, at 22° F refrigerant R22 pressure is about 45 psig.
So to run it at that temperature you will have to disconnect your low pressure switch and install a jumper wire across those terminals and install a low ambient fan cycling switch kit (that you can get at your local ac parts house) which will keep the head pressure up when unit is running.
But by bypassing the low pressure switch you won't have any protection if you have a refrigerant leak or your indoor blower fails
or filter or evaporator gets dirty or plugged up.
Posted on Apr 10, 2009
    President:
  • 2,692 Answers
Some air conditioners have a thermostat that will not allow the compressor to run below a certain out side tempature as it will cause liquit to come back into the compressor(called slugging) and damage or destroy it.
http://www.hitachi.com.au/productsearch.aspx?pId=62&
Posted on Jan 08, 2009
Luxpro psd111 thermostat shows snowflake (sometimes blinks), outdoor fan works, but no cool air comes out inside- no air flow at all. Is it the thermostat or an a/c unit malfunction?
If the outdoor unit is running the indoor fan should definitely be running. Turn power off to indoor unit. Put red green and yellow wires together behind the tstat with a wire nut. That is power (red), indoor fan (green), and compressor (yellow.) Turn power back on. This is bypassing the tstat and you should have indoor fan and outside running as well. If yes the problem is in the tstat, if no indoor fan the problem is in the unit. Good Luck!! Let me know!!
Apr 28, 2017 | Heating & Cooling
Radio Shack 63-1090 indoor/outdoor temperature unit. Won't give outdoor readings. Temps are cold, -5F but it always worked before. Put in new batteries in the inside and outside units, wiped outdoor sensor...
According to instructions for similar systems, you have to replace batteries in the outdoor unit first, then the indoor unit and wait 10 minutes without pressing any buttons for the indoor unit to begin displaying the outdoor temperature.
Dec 31, 2013 | Heating & Cooling
Why is Mr Slim MS-SGF24VC outdoor unit working when indoor unit off
Possibly a bad control board in the outdoor unit. Pull the disconnect outside to stop machine, wait 10 seconds and out back in. White mist was likely frost built up on indoor coil due to condenser running without the fan.
Jun 11, 2017 | Heating & Cooling
Unit for downstairs is running fine, but upstairs unit doesn't want to kick on, but outside unit is running (fairly hot though). Tried to re-set, but "cool" just sits there and flashes on the...
Are you saying you have two HVAC systems or one? If you have two indoor units, you must have two outdoor units. Which outdoor unit is running. You said it is running hot. Assume the fan in running to cool the condenser. If so it should be about 20 degrees warmer than outdoor air. If not maybe you have a dirty condenser coil. Need more information.
Aug 26, 2011 | Carrier 38CKC036 Air Conditioner
My AcuRite 00992 wireless weather station has suddenly quite displaying the outside humidity and dew point. Batteries are all new. I have lost my manual to troubleshoot this problem.
Double check the batteries to make sure they are installed correctly. If one of the batteries in the outdoor sending unit is in backwards, it will not send the outdoor data. On the indoor unit, there is typically one battery that is used for receiving the signal from the outdoor unit. If all of the batteries are in correctly but that one, you will see the display and the indoor temperature information, but the outdoor information will not be displayed.
Aug 27, 2010 | Acu-Rite Adagio Clock Radio
Rudd Acheiver 13 nothing turns on outside but the fan inside is
Try pushing the red reset button at the outdoor unit near the brass service valves (where the refrigerant lines enter the outdoor unit). Also check for power from circuit breakers furnishing power to the outdoor unit ( the indoor unit has a seperate power supply source ). There may be fuses in the service disconnect box mounted near your outdoor unit. If those "blow" they will prevent operation of your outdoor unit. You can test continuity using an ohmmeter. If you do not have an ohmmeter, you can take the fuses to the local hardware store. They should be able to test them for you and offer replacements if needed. If after doing all these steps you continue to have problems, let us know and we will dig a little deeper. :-)
Apr 18, 2010 | Ruud UBHC Air Conditioner
Will Not Heat
On the outdoor unit the fan should not be running, on the indoor unit the fan should be running. If you then check the outdoor unit with fan not running, you should be able to hear clearly that the compressor is actually working. If this is all correct, it is possible that your fourway reverse valve is seeping and needs to be replaced.
Apr 15, 2009 | Fujitsu 18R1 Air Conditioner
Breaker keeps getting flipped off
20kw heat should have 2 separate 60 amp circuits on number 6 wire.
Mar 03, 2009 | Ducane Grilling
Heat pump not running
Depending on the age of the unit it could be several things, does it have a circuit board? Contactor could be bad, freon leak if it has a low pressure switch, burnt wires, connections, etc. Do a complete visual and check for 24 volts, does the indoor unit run? Transformer may be bad.... No indoor unit - no outdoor unit, most of the time the outdoor unit gets its 24 vac power from the indoor unit which runs them both, look for fuses (like car fuses)..
Apr 26, 2008 | Heating & Cooling
Hitachi RAS-09UH Air Conditioner Logo
219 people viewed this question
Top Hitachi Heating & Cooling Experts
D. E. Hev
rugby prop
Are you a Hitachi Heating and Cooling Expert? Answer questions, earn points and help others
