Question about Astatic 636L Noise Canceling Microphone Microphone
Engine problems i have a 2006 h3 hummer. the fan belt usually squeaks on me when the weather is really cold or wet outside. within the past month the belt has been squeaking really bad. the past couple of days my cooling fan seemed to b makin really weird noises and almost a grindin noise some. then my engine started to overheat and my coolant level was almost completely gone. there is also a clear almost oily liquid sprayed out under my hood. my brother looked at my cooling fan and it did seem like it might b a little loose but dont know if thats how it should be or not. i want to konw what the problem might be and how hard to get it fixed. i am hopeing it all just has to do with a bad fan belt.
Driving and Rpms go up
Dealer Checked my Hummer. They said all H3's have the same problem ...
www.elcovaforums.com > ... > General H3 Discussion
Sep 15, 2005 - 24 posts - ‎17 authors
rattling sound inespected in my hummer because ... go uphill or press on the gas pedal to ... same time up to 2500 rpm on my H3. .... Buzz or Rattle Noise While DrivingUnder Load from the Exhaust ... 2006 Hummer H3
Slow Gear Shift, Low RPM - Normal for H3? - Hummer Forums ...
www.hummerforums.com > ... > Hummer Lineup > Hummer H3
Mar 6, 2012 - Hey All! I recently bought a used 2007 H3 (automatic). ... for h3"!!.if it dont feel normal,,it aint!! im driving my 2nd h3 and they both felt ... 2006 Hummer H3... you can tell when locked up. go ez on gas and rpms dont jump,they ... Hummer H3 Won't get above 2.5 RPM - Hummer Forums ...
Jun 26, 2014
My h3 loses power and sometimes turns off when i turn
Mar 16, 2010
More results from www.hummerforums.com
RPM bouncing from idle. Caused short bursts of "unintended ...
Jan 01, 2016 | 2006 Hummer H3
2006 Nissan Sentra. Belts squeaks and stop seeking when you step on brakes.
If I understand this, your fan and other belts driving components in the engine bay stop squeaking when stepping on the brake? Your belts may need some adjustment to tighten. But it may be a vacuum hose leaking around the power brake chamber, or it is leaking, and sounds like the squeeking you describe. I would temporarily confirm the belt squeak by using a "Belt dressing spray" from your auto parts store, to see if it really is the belt or a possible vacuum leak. My belts squeak sometimes after the first start of the day in cold weather since the alternator is working very hard to recharge the battery after the start. It will be quieter when the engine is slowed down as in your braking scenario.
Mar 24, 2015 | Nissan Cars & Trucks
How do I replace the purge valve on a 2006 hummer h3??
It's a chevy engine. usually two 10mm bolts and it lifts off.
Or is it the Purge Valve Solenoid by the gas tank that is the issue?
Dec 19, 2012 | 2006 Hummer H3
I also have a 2006 H3 that the air conditioning was working great and was blowing super cold. then for 2 days i would try to turn the air on and it wouldnt work until the H3 was running for 10mins then it...
is freon level correct. does compressor come on when turned to cold? if it doesn't freon may be low or compressor may be bad. theres also an outside possibilty of the control being bad.
Jan 17, 2011 | 2006 Hummer H3
2006 H3 Hummer fan problem
Hi if your internal fan not work in any position well i fixed up myself easy and save your money.
locate the fan motor air just outside right courtesy drawn document in front of passenger. go from down and look up you will see a motor with a big connector white with 2 screw secure inside the motor block. loose the two screws and pull out gently the connector from motor fan block. you will see a green multiresistor connected with this big connector. Usually the first + voltage connector is burnet out. disconnect the connector pull from resistor and check for any burn. in my case the first pin was burned out completely
you can buy another connector or you can clean the burned connector take out form connector weld a small copper cable of 5 mm dia from resistor to the burn cable and reconnect the connector without buy a new one. after replace again the resistor in the hole of motor blow with the 2 screw.
Done all work again without buy another new connector.
Gabriel from Italy Turin
H3 hummer 2007
loveling one and Humvee owner
May 07, 2010 | 2006 Hummer H3
I have a 2007 H3 hummer, suddenly my fan does
It's the HVAC blower resistor in the air plenum under the glovebox. New resistor and wiring harness is about $70 at the Hummer Dealer.
Sep 10, 2009 | 2006 Hummer H3
Cooling fan is not pushing air out.
That could be the blower motor resistor or the blower motor
Jun 04, 2009 | 2006 Hummer H3
Fan belt engine trouble
faulty water pump grinds and squeaks
stuck thermostat
cooling fan /slipping clutch =spinning to slow or faulty relay
oily fluid .spray
..oil and coolants mix
could have blown a head gasket by now
Apr 11, 2017 | 2006 Hummer H3
2006 H3 Hummer Ac/Heater fan motor will work great and run, the next time I start and drive not come on at all. Then sometimes after driving about 15 min just kick on and run and do great.
I brought my 2006 H3 in to the dealer for the same thing. My blower stopped working all together but it started as an intermittent problem. He said he had to replaced a diode or resistor either behind the switch on the dash that controls the fan or on the fan motor itself. Have not had a problem since but that was only about 4 months ago.
Sep 10, 2008 | 2006 Hummer H3
Astatic 636L Noise Canceling Microphone Microphone Logo
62 people viewed this question
Top Astatic Audio Players & Recorders Experts
Michial Gueffroy
Tony
 steve
steve
Are you an Astatic Audio Player and Recorder Expert? Answer questions, earn points and help others
