Question about GTCO CalComp Drawing Board III 34180 Graphic Tablet
I can't get right proportion in X/Y axis in my Acad with DBIII
If I get 4 points from perfect circle on this Drawing board, the result in Autocad 2002 is alway oval either in X or Y axis. Can you help? many thanks.
PS : I have installed the latest driver (it run automatically) looks like success but the result is still the same.
  • 1,606 Answers
Run the tablet command in acad and configure/calibrate it. should fix it
Posted on Jul 09, 2009
How do i fix autocad? Please help!
You can fix this problem in two ways.
First: follow these steps
- Open the Registry Editor by typing "regedit" in the Windows 8 Search charm and selecting "regedit" from the Apps section of the search results.
- Navigate to the "HKEY_LOCAL_MACHINE\Software\Autodesk\AutoCAD\R15.0\ACAD-1:405\AdLM\Type" registry key.
- Right-click on the registry key and click "Export."
- Choose a name to save the license registry key file as, along with a location where you want to save it, and then click the "Save" button.
But if it useless try the second way- DWG Fix Toolbox. http://www.autocad.fixtoolbox.com/
Dec 23, 2014 | The Computers & Internet
How to make a 5 point star
Use a compass to draw a circle the size you want your star to be.
Draw a second, smaller circle inside the first, using the same center point. Make the second circle about half the size of the first.
Draw a line from the edge of the outer circle to the center point using a ruler.
Place a protractor on the line, with the center hole of the protractor over the center point of the circle.
Measure and mark every 72 degrees around the circle (72, 144, 216, 288 and 360 degrees), dividing the circle into five even sections.
Line the ruler up with the center point of the circle and one of the marks you just made.
Draw a line from the edge of the outer circle, through the center point, ending at the edge of the inner circle.
Continue drawing lines as described until you have drawn the five lines, which evenly divide the circle.
Connect the top of one of the lines that touches the outer circle to the lines that touch the inner circle on both sides, forming a point.
Continue to connect the lines around the circle until you have made a five-point star.
  • Make the inner circle larger for a fatter star or smaller for a thinner star.
  • Draw your star on poster board and cut it out to use as a pattern for drawing more.
  • To make a six-point star, measure and mark every 60 degrees (60, 120, 180, 240, 300, and 360 degrees), dividing the circle into six even sections.
  • To make an eight-point star, measure and mark every 45 degrees (45, 90, 135, 180, 225, 270, 315, and 360 degrees), dividing the circle into eight even sections.
  • Quick and easy may want to do this a few times before the final perfect one. This actually made me think. Haven't done geometry in a very long time.
Dec 23, 2014 | Cars & Trucks
Acad 2010 product serial number
Solution:
Product keys are required for installation of Autodesk products and are used to differentiate products that are both sold independently and as part of a product suite. For example, installing AutoCAD 2014 as a point product requires product key 001F1, but installing AutoCAD 2014 from the Autodesk Product Design Suite Ultimate 2014 requires product key 781F1. The same version of AutoCAD is in both software packages but the product key differentiates one package from the other
Aug 04, 2014 | Autodesk AutoCAD 2010
Autocad error 0x69bbc67c
install the latest sp from the autodesk website. Failing that, turn of graphics hardware so it uses software in Options
Mar 25, 2013 | Autodesk AutoCAD 2010
When i use programs such as autocad, proportions are distorted
change the monitor resolution settings in the control panel on the computer.
Apr 03, 2009 | Computers & Internet
I keep getting the same message while using autocad 2002lt
There are a few things to try. I'd try this first: Start ACAD and use the Recover command (File menu) to open your drawing. If that doesn't you can insert your drawing into an empty drawing as an exploded block and/or purge your drawing.
Dec 17, 2008 | Autodesk AutoCAD LT 2002...
Digitalizzing problem
I have a problem with the same hardware and software. I'm using AutoCAD 2008 and when I trace an object that is 1:1 it come into AutoCAD as a different scale. I have tried different scale factors in AutoCAD and nothing.
Jun 02, 2008 | GTCO CalComp Drawing Board III 34180...
Autocad 2008 et Drawing Board III (is there compatibility?)
If you are using the drivers supplied by GTCO, they won't work with Autocad 2008.
They are not a fully compliant Wintab driver. Check with the Autocad software to be sure of what kind of tablet driver it needs.
There is a site called www.vtablet.com that sells a tablet driver that is fully Wintab compliant.
May 30, 2008 | GTCO CalComp Drawing Board III 34180...
GTCO CalComp Drawing Board III 34180 Graphic Tablet Logo
232 people viewed this question
Top GTCO Computers & Internet Experts
William F. Bryant Jr
Level 1 Expert
Are you a GTCO Computer and Internet Expert? Answer questions, earn points and help others
