Question about Thomson 20LCDB03B 20 in. Television
Top left side of the monitor asking for a key dats monitor locking so i need to open the lock plesae help me
In the remote the keys are not working except power & 0- 9 switches so please help me to open the lock of monitor
  • 1 more comment
  • srinivasa kumar Mar 16, 2007
    please provide mannual or step by step solution
    plese help me quickly
  • Anonymous May 07, 2008
    how can I go to service mode
    Champion:
  • 217 Answers
Try holding the menu button down, this works for most monitors, just hold it down for at least 1 minute or so
Posted on Mar 25, 2007
Locks on Back Doors, and more...
This is because your master switch on the drivers door may have corroded oxidation on the contacts inside the switch and that master switch is the feed for all inside door lock switches your remote and keypad work because those electrical signals go through the driver door module you must clean all contacts on the master switch get them shiny you can use 4/0 steel wool and alcohol and also take the lock switch apart and clean the button contacts inside the switch for this use alcohol and 1000 grit sandpaper glued to a pencil and lightly spin in your fingers to shine the contacts sometimes just an eraser works but it depends on the quality of it so go with the sandpaper glued to the pencil or any circular object that will fit inside after this blow out the switch and use the alcohol to clean out and let dry
Feb 11, 2018 | 2002 Ford Expedition
Having trouble with keyless remote control on 1993 lexus es300. Replace battery on remote- still not openning doors. Help Please!
Try reporgraming it
1. Start with key out of ignition, drivers door is open all others closed and
drivers door is unlocked.
2. Insert key into the ignition (Do NOT Turn) and Pull key out.
3. Perform these steps within 40 seconds.
A. Using the power lock switch on the drivers door, perform 5 lock/unlock cycles
starting with lock. Use an even pace and try to go about one cycle per second.
(1Cycle = 1 lock and 1 unlock).
B. Close, then open drivers door.
4. Perform these steps within 40 seconds.
B. Insert the key in the ignition cylinder.
C. Turn the ignition to ON (Do NOT Start) then back to OFF.
D. Remove the key from the ignition.
5. Press any button on remote for a minimum of 1 second.
System should now lock and unlock doors once.
6. Close and open drivers door.
7. Press any button on remote for a minimum of 1 second. System should now lock and
unlock doors. Once to confirm programming, twice to indicate programming failed.
8. Repeat steps 5, 6 and 7 for additional remotes.
Jan 02, 2013 | Cars & Trucks
My Apex tv at2402 is locked and i don't have remote control, what need to be done to get this fixed?
OK . . .
First, press the TV button at the top of the remote so the remote is operating the TV rather than the cable box. Then try these combinations - hold down both keys at the same time for 1-2 seconds before trying the next one.
ENTER and TV (on the top row)
ENTER and MENU
MENU and TV (on the top row)
If these don't work, try holding down the MUTE key and then press other buttons on the remote one at a time while still holding down MUTE. Do not use the number keys (0-9), the POWER key or any of the keys on the top row (DVD, AUX, etc) except for the TV key.
If this doesn't work, please post back with the model number of your AT and T remote and I should have some other suggestions. If it's not printed anywhere on the remote, the model number should be inside the battery compartment. If you remove the batteries, replace them quickly or you may lose any codes you have programmed into the remote.
I'll wait to hear back from you.
Anyone looking for assistance with unlocking this TV, with the original Apex remote, please click on this link for instructions:
http://www.fixya.com/support/t8361476-locked
Mar 02, 2011 | Apex Digital AT2402 24" TV
I have a LG HT554PH home cinema and would like a region code to enable it to play region 1 dvds. i have just paid £5 from a website and it is no use my dvd player wasnt on the list. there is a reion...
Hi
To make the player as region free, switch on the LG HT554 Player. Push the eject button to open the tray. Now, press “0” on your player 4 times or until the region code settings shows up on your player. It will show the current region code and will then ask for new region code. Press “0” on your remote to set it as a new region code(0=All Regions). Press Enter key on remote, now restart your player and check the player by playing the DVD’s. It should be region free now.
Please post back for any further assistance. If you are satisfied please do accept the solution.
Daniel
Jul 23, 2010 | Audio Players & Recorders
I purchsed this monitor at a thrift store. It
Is your remote working? If so use the key pad and open up the menu- look for advanced settings, press unlock (parental controls) also use the default setting to auto reset the channels....
May 29, 2010 | Kogi L7CH Monitor
My keyless remote stop working & i tryed the step and it only work once. please help
Synchronization
Turn ignition switch to position II. Turn ignition switch to position 0 and remove key. Within 1 minute: Press and hold key lock button. Press unlock button 5 times. Remote control should now operate system. If not: Repeat procedure.
Mar 26, 2010 | 2001 Mercedes-Benz M-Class
Program remote control for mazda mpv 2002
Courtesy of: forums.mazdaworld.org
Try this, it works on several 2002 models:
Step 1: Open drivers door and leave open.
Step 2: Lock and unlock the drivers door using the power door lock switch on the door.
Step 3: Insert key into the ignition.
Step 4: Turn key to on position and return to off position. (IMPORTANT - use ON position NOT ACC position). Do this 3 times within 10 seconds. Leave key in the ignition.
Step 5: Open and close the drivers door 3 times. (Door should be left open after this step).
Step 6: ECU should respond by locking and unlocking the doors.
Step 7: Press any button on remote #1. ECU responds by locking and unlocking the car doors.
Step 8: Press any button on remote #2 (etc.) Each time the ECU will respond by locking & unlocking the doors.
Step 9: Remove the key from the ignition and the ECU will respond a final time with a series of door locks and unlocks. You're done
Dec 06, 2008 | 2000 Mazda MPV
Memorex MVD 2042 DVD Player ''Key Lock on''
mt memorex dvd player says ``key lock on´´ and i don't know how to quit that and i can't opened with the remot control
Help please!!!!!
Nov 17, 2008 | Memorex MVD2037
Need unlock code for Philips DVP5990
Having the same problem!! Please help
Thanks
Jul 26, 2008 | Televison & Video
Thomson 20LCDB03B 20 in. Television Logo
157 people viewed this question
Top Thomson Televison & Video Experts
 Grubhead
Grubhead
Are you a Thomson Televison and Video Expert? Answer questions, earn points and help others
