Question about Kenmore Elite 45986 Front Load Washer
New Kenmore Elite Front Loader will not get past 'Sud' cycle,
My wife just received a new Kenmore Elite washer. There is a flashing message "F35" that continues and she cannot turn it off. What does it mean?
Also, she will set the controls at what she wants to wash. It will go through the suds cycle, and then the 'F 35' comes on>
What am I not doing right?
Thanks!
Hello wheeljc; I had the same problem when I purchased my Kenmore Elite in 2006. I have a HE4t front load. It's possible that you're using to much detergent, if you're using HE liquid it only requires a small amount and does a very good job.
Posted on Dec 19, 2008
My Kenmore Elite front loader keeps on showing the same problems
Cut down on your soap i only use very little soap and it works great.No more SUD code
Jul 02, 2014 | Kenmore Elite 45986 Front Load Washer
I have a Kenmore Elite Washer for over a year and is getting a F35 error code, then the SuD flashing. Cleaned out the soap container & inspected the inside (as stated on page 21 of "Washer...
F35 is a water level error.
The water level switch (pressure switch) has malfunctioned.
If you remove the top panel, three screws in the back, you will have access to the pressure switch.
With the tub empty, remove the vinyl hose from the switch and blow backwards through the hose to clear any restrictions.
If the fault codes return after doing this, you will likely need to replace the pressure switch.
Also - please be sure to use He soap.
Thanks for using FixYa!!
Nov 12, 2010 | Kenmore Elite 45986 Front Load Washer
My new kenmore washing machen is not working it shows F35
you need a new pressure switch more than likley its flashing sud before giving you a f35 too right?
that is a very comon problem with the steam washers
if you take the lid off and look to the rear right you will see it
it is small black and dark orangish redwith a hose attached to it
Aug 23, 2010 | Kenmore Elite 45986 Front Load Washer
Sud and f35 error in my kenmore elite h5 steam washer. The washer do not wash the cloth and flash F35.
I got the f35 and suds code repeatedly and my clothes weren't washed, I ordered from Sears the analog pressure switch that regulates the water coming into the washer and the codes went away, the part is esitmately $125.00 including shipping but you have to order from the Sears parts department.If you print a diagram of the washer it is #38 in the diagram and is easy to replace. You can install it yourself and as a female I did not call service to do it.
Jan 17, 2010 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite front load washer stops and blinks F35 and locks up
f35 code indicates a pressure switch problem. Try unplugging unit for 2 minutes.Plug back in and test.If F35 reappears,check hose from tub to pressure switch
Nov 04, 2009 | Kenmore Elite 45986 Front Load Washer
My Kenmore Elite HE5t washer flashes SUD continually, then goes to F35 mode and shuts off. Help!
Sometimes the SUDS/F35 is because of TOO MUCH detergent. To clear you have to set the cycle on rinse and then keep pouring cups of water into the detergent container as the cycle is going. You might have to do this a few times because if the SUDS message comes up the water flow will stop. Just unplug and try again. Also when the detergent container is finally clear you will see the little rotators gears move around when the cycle starts.
Aug 02, 2009 | Kenmore Washing Machines
Sud/F35
if your using more than 2 tbl spoons of HE detergent, you WILL have the same problem with your new washer." sud "stands for TOO MUCH SOAP
Jul 24, 2009 | Kenmore Elite 45986 Front Load Washer
F35
f35 and sud replace your pressure switch
Jul 02, 2009 | Kenmore Elite 45986 Front Load Washer
F35 & SuD error codes on Kenmore Elite Washer
F35 has to do with the pressure switch which is located under the top panel on the back right. It will have a little black hose hooked to it. This happens when SUDS or detergent somehow gets up into it and usually locks unit out. Only solution is to replace pressure switch. You can find the tech sheet behind the bottom front panel usually tape to the back side of that panel or taped to the bottom right side inside unit. Hope this helps
Jun 09, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
481 people viewed this question
Sal De
fordexpert
Robert Rankin
