Question about Canon PIXMA MX310 All-In-One Printer
Canon MX310 doesn't go on and Alarm light goes on solid.
I just purchased this machine yesterday.
Everything worked fine after I set it up.
Today I turned it on and the display didn't come on.
I disconnected it from the wall and connected it again. From that moment the machine will not turn on, and the annoying yellow alarm light is on solid.
Any suggestions?
Many thanks
    Master:
  • 638 Answers
Disconnect it again for sometime.also try to remove the cartridges from the printer if possible.and take out the power wire of the printers back for sometime.also remove if any computer wire connected to the back of the printer and then slowly ---slowly connect every thing back and check out.it should work.as the printer is new and the alarm light also bliks if the internal parts gets misallighned or blocked internally.if such problems get it replaced.
Posted on Dec 14, 2008
No lights flashing, just yellow alarm light is on. why?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
Jan 15, 2016 | Canon Pixma MX310 All in One
Printer screen wont turn on and alarm light on.
Check the print head. Get a cloth and clean out the print head area.
Aug 28, 2014 | Canon PIXMA MX310 All-In-One Printer
Why does my Kozy World natural gas wall heater set off fire alarm system?
Most new heaters give off a smell or some light smoke which needs to be burnt off the first time it is used it may smoke , this may be why your alarm is going off , run it with a window open to remove smell etc .
Feb 12, 2013 | Heating & Cooling
I bought some ink cartridges yesterday for my printer and got 510&511 combo pack for a MX320 only to get home and notice mine has 40&41 combo in it and is a MX310. Can I still use the 510&511...
That printer uses the following ink cartridges
PG-30
CL-31
(low capacity)
PG-40
CL-41
(normal capacity)
PG-50
CL-51
(high capacity)
The ink you purchased will not work on the Canon PIXMA MX310 printer.
Apr 04, 2011 | Office Equipment & Supplies
I have Canon multifunction MX310 I was using
press the Stop/Reset button for at least 5 seconds with the ink cartridge installed. Then printing can continue under the ink out condition.Canon do not like you to use refills and generic carts so the function for detecting the remaining ink level will be disabled
Jun 19, 2010 | Canon PIXMA MX310 All-In-One Printer
On my canon MX 310 printer I put in new Canon CL-41 Fine color cartridge and now the alarm light is lit and the screen says Check Ink U051 COL How can I correcty the problem?
You may need a new cartridge, that error says the ink cartridge is wrong or not installed properly. If it's a refilled cartridge it won't work, if it's a new canon cartridge, they warranty for 30 days from date of purchase.
Dec 23, 2009 | Canon PIXMA MX310 All-In-One Printer
HAving trouble printing
Check and make sure you did buy the right one first.
Apr 23, 2009 | Canon PIXMA MX310 All-In-One Printer
Alarm won't reset
To reset you can't just turn it off & on normally. You have to unplug the unit for a few minutes to an hour or so, depending on manufacturer, then plug the unit back in and turn it on. This usually will reset the unit. Hope this helps.
Mar 05, 2009 | Canon PIXMA MX310 All-In-One Printer
Reset Ink levels for canon mx310
To Reset the Canon Cartridges Works 100%
Power off the printer
Hold the stop/reset button then press and hold power (for 5 secs)
Hold Power and release the stop/reset button
Press the stop/reset button twice
Relase power button
Wait until the power button lights a steady/still green, press the stop/reset button three times with a 3 sec space between each press.
On the 3rd press the inicator should be orange.
Press the power button to set data
To set data remove cartridges then replace.
leave for 20 or 30 secs
Press the power button again to shut down
Then press power button to power up.
The printer will feed one piece of paper through
then set language and counrty.
Then ink should be reset
Any problems contact me on charmed_halliwell@hotmail.co.uk
Jan 31, 2008 | Canon PIXMA MX310 All-In-One Printer
Fax noise during phone calls
Call Canon directly - there is a problem with this issue and they have fixes you can download or they will replace the unit at N/C - call their support line and talk to someone
Dec 27, 2007 | Canon PIXMA MX310 All-In-One Printer
Canon PIXMA MX310 All-In-One Printer Logo
354 people viewed this question
old marine
old marine
