Question about Magellan SporTrak GPS Receiver
SporTrack Map Magellan GPS - internal wiring
I have been asked to fix a Magellan Sportrack Map GPS unit that had a battery leak inside it. It appears someone has worked on it before me as the soldering on the wiring between the case and the circuitboard was pretty ordinary. Half of the wires were not connected so I am in desparate need of knowing which wire goes where. The silkscreened letters on the PCB are TRBGGE. When I first opened the unit the black -ve battery lead was connected to the E plated thru hole and the red +ve battery lead was connected to the R plated thru hole. I have little confidence in getting this unit to work but if I am to have a snowballs chance in hell it would help if I knew the wiring connections to the PCB - just the order of the colours from top to bottom would be great. The battery acid has left some oxidizationaround the screen connector but the connections themselves all apear to be working. I just have no confidence that the previous repair attempt connected the wires up correctly.
4 Suggested Answers
DanEz007
  • 86 Answers
SOURCE: Satellite cannot locate my Magellan 700 - Please Help
All zeros ehh? nice.. :) I'm not sure that having that wire that was "loose" solderd on was a good idea. Pretty sure your talkin about the RF cable from the main board to you I/O card (the card with the power connections). this cable isn't supposed to be soldered on, although I don't see what it could hurt as long as the connection was good before the solder cooled. If you open the unit up.. (again) and take out the I/O card (power card) . Look on the back of that circuit card and make sure that there are three small ICs' in a row at the position that sits in the outter beveled part of the back cover. I know this is hard to explain, but basically, if your missing an IC chip and you can't find it, then there's no hope.. look at some of my other posts and try various software resets. if you find the small IC chip I'm talking about (somehow) then call that professional solderer guy back. Let me know. -Daniel
Posted on Apr 29, 2007
  • 20 Answers
SOURCE: Magellan 700, lost signal found a causation. Need help
Bin the Magellan - nothing but problems when you need to update or resolve problems.. I am replacing my magellan with a Tomtom Go which does auto updates via a cradle linked to PC.
Posted on Jan 08, 2008
Benimur
  • 6966 Answers
SOURCE: wire problem
Might this help? 83b9bee.jpgThis was originally posted here.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on May 30, 2008
Sportrack Frontier Essential Deluxe model# 67-1161-000-00.
Check YouTube for something similar or contact Sportrack directly.
May 19, 2017 | Cycling
I have purchased a later model Sportrack trunk mount bike rack. It did not come with a manual. I am not sure how to use it
I guess they don't think posting directions online is a good idea. Maybe you could call them and ask why.
http://www.sportrack.com/contact
"You can call one of our agents at 1-800-561-0716 Tuesday to Friday 8:30 a.m. to 5:30 p.m. EST "
Feb 22, 2011 | Sportrack Sporttrack 3 Bike Trunk Mount...
I have a Magellan 315 gps that is appoximately 10 yrs. old. Does it have an internal battery that needs to be replaced?
Not a fix, shared information.
Yes these units have an internal ten year lithium battery. I am currently researching this issue, as I have two dead and one working 300series GPSs. When the internal battery dies and the regular batteries are removed or die the unit will loose all user data (way points and routes), as well as the satellite map and initialization. After dieing the unit will appear to function normally but fail to lock on, track or get a fix. Only showing the coordinates from the initialization. These units also have an internal capacitor that provides sufficient power to hold the memory during quick battery changes, but not over night. I have as yet found a working solution, but only researching this for a few days.
barang at asia period com
Nov 19, 2010 | Magellan GPS 300 GPS Receiver
Firmware failure downloading to Magellan Sportrack pro. Unit will no longer initialize (power up).
Generally this means it will have to be sent in to Magellan for repair. Go to the magellan web site find your support number and they can walk you through a hard reset which may get it going (maybe) but if nothing else they can tell you where and how much to get it fixed. It is usually pretty reasonable but keep an eye out for what a new one costs. Sometimes if you catch a sale etc it can be cheaper jsut to get a new one.
Apr 02, 2010 | GPS
Downloaded map update to Magellan 760 - now the unit will not even power on. What can I do? Carolyn
charge it up for a few hours then press and hold the power button till it powers up
Jul 08, 2009 | Magellan Roadmate 760 GPS Receiver
Magellan just stays on Magellan blue screen
According to Magellan and other people who have experienced the same problem, this is terminal to the unit. It can be caused by downloading the 08/09 Magellan map upgrade, which can cause the unit to permanently lock up. Magellan is well aware of the problem, and should offer to replace your unit if you have the problem. If you elect to have it repaired, Magellan can download the map upgrade for you in the repair process. Here is a site noting the same problem: http://74.125.93.104/search?q=cache:pNLjGT-i4-sJ:forums.gpsreview.net/viewtopic.php%3Ft%3D8958+magellan+4250+gps+stays+on+blue+screen&cd=8&hl=en&ct=clnk&gl=us
Other than replacing the unit, there appears to be no "fix".
Feb 18, 2009 | Magellan Maestro 4250 GPS
CAN NOT GET MAP ON GPS MAGELLAN EXPLORIST 210
try updating the firmware from the magellan website that fixed mine.
Oct 29, 2008 | Magellan eXplorist 210 GPS Receiver
No sound on GPS
The internal memory was formatted. This is a catastrophic occurrence and the most common E-mail message I get asking for help. Look under Bugs on the Tips and Tricks page for some background. Before buying an RM360 on eBay, make sure that it comes with the original Magellan SD map card and not a blank one, and make sure that the original owner did not format it! A formatted unit will not speak or make sounds. Because the RM360 is a discontinued device, Magellan WILL NOT FIX THIS. If you want to attempt a reflash, see the Hacking page.
Aug 24, 2008 | Magellan RoadMate 360 Automotive GPS GPS...
Manuals
I don't know what model you have. But if you go to www.magellangps.com and search for manuals for that model you should be able to find one that works. their manuals are in .pdf format. good luck
Jun 06, 2007 | Magellan SporTrak GPS Receiver
Magellan SporTrak GPS Receiver Logo
113 people viewed this question
Top Magellan GPS Experts
Marvin
Marvin
Steve
Steve
Are you a Magellan GPS Expert? Answer questions, earn points and help others
