Question about Pioneer PureVision PDP-503MXE 50 in. Plasma Television
Pioneer 503mxe cant wire it up
I cant connect my digi box via scart or rf to my pioneer 503mxe anyone know how?
  • 5 Answers
To connect as you describe you will need a tuner card as the 503MXE is a monitor rather than a receiver. Otherwise the only option is to connect a scart to the 5xBNC connectors (Input 2) but you will need to be sure that your digi box outputs RGB over scart. If you have the optional video card (PDA 5002) fitted then you can connect via the s-video connection (Input 3) assuming your digi box has an s-video output.
Posted on Aug 04, 2009
  • anthony james booth
    anthony james booth Feb 27, 2013 new to this and was wondering if i have to use all the ports on the 5xbnc cable that you described for that monitor.and does it have to be rgb or can i use the one with scart on it.many thanx and hope to hear from you soon
    do you no any freeview boxes that out put s-video.thanx
Need to connect vcr to receiver and tv to record local channels with roof top antenna
You don't give any details as to your devices to enable any really detailed information so I can just give you the basics. First the aerial lead from the roof top, goes in the RF in of the video. If it's the TV remove it and place it in the video. You then need another lead that goes in the video RF out - back to your TV antenna in. Once done both should now pick up TV signals. The only problem you might have is if the VCR doesn't have a digital tunner and you live in a digital only area. In which case you would have to connect a digi box to the VCR via a scart socket. and record by selecting the scart socket (say AV2) instead of the TV channel when you set the recording up.
Sep 26, 2013 | Televison & Video
Digitial channel tune in and set up
if you have a problem getting digital channels (uk) find local channel number digital uk can help enter tuning menu go to manuial tune on tv or digi box. it will ask for channel number start with highest number pess ok or search repeat for each channel number normal 4or 5 depends on aera if still not getting all channels put aerial lead which come for aerial into tv bypassing any equipment such as vcr/dvd recorder then start again if still not all channels may need aerial upgrade .if yo get all channels connect vcr/dvd if some channnels disappear need to reset RF out on vcr/dvd remove aerial .connect vcr/dvd via scart reset RF out on vcr/dvd this can be found in vcr/dvd set up menu reconnect all leads should now work ok
Note do not set RF out to any digi channel numer
on Aug 17, 2010 | Televison & Video
Ineed to know how to interconnect our tv, vcr, dvd and top set box, Can you help? Philips DVP3120/05, Philips VR720 Philips 282 tv with built in dvd and Bush free view top box.
Problem solved : incorrect connection of scat leads Solved by roof top digal aerial Digi top box and on to VCR. and then on to TV.
Scart from VCR to TV
Scart from VCR to DVD
Scart from Digi Top Box to TV.
Everything now functions correctly
Equipment connected:
Philips VCR: 720/07
Philips TV : 28PW6515/05
Philips DVD: DVP3120
Bush top box
Nov 20, 2009 | Philips Televison & Video
How do you set up digi box with VHS recorderand Tv. Digi box has two scart leads
Take one scart from the digi-box & connect the other end to the TV, & the second scart on the digi-box can connect to the VCR. To record from the digi-box, the VCR must be set to the AUX input (or AV ). The TV will also be set to the AV input, this set up will let you watch digital channels & to record a digital source. Be aware depending on your type of digi-box, you may not be able to record & watch two different digital channels at the same time.
Oct 14, 2009 | Electronics - Others
Equipment and Locations (Denons are physically 15ft apart) Room 1 Sky Plus Satellite Digibox; (without HDMI outlet), but with one optical, one scart-video, and two Scart outlets. Panasonic DMR-EX77EB DVD...
Hi Martin,
A wiring Schematic is not that you should be looking. What you need is large feeders to understand hot to connect to various ports to give your desired output.
Jul 03, 2009 | Denon Audio Players & Recorders
Hii i cannot connect my tv to the dvd player , can u tell me how can i fix this problem
I wrote this down to connect at Digital Freeview box to TV and to Video. It works for me on a portable TV and I am a grannie so if I can do it ............ I did buy one of those scart boxes which allows 4 scart leads just like an electric plug multi socket, very cheap price. Hope this helps and Happy New Year.
Take the scart connector box lead to the digi box.
The scart from the TV and the scart from the Video both go to scart box.
TV aerial itself not plugged in or used.
Bottom video aerial to right digi hole
Another aerial lead (not aerial) from TV hole to left digi hole
Jan 02, 2009 | Insignia LCDTV26 26 in. Television
To connect analogue VHS/DVD player to digital Tv via digibox
if your digi box have two scart socets that no of them is mark ( to vcr ) and another is mark ( to tv ) or use rf cable
Aug 10, 2008 | Televison & Video
Can't tune stations from freeview box to DVDR3380/5
You can only record freeview channels through your box.
Assuming the digi-box has two scart sockets, connect as follows:
  • Scart 1 or TV scart of the digi-box to the TV.
  • Scart 2 or VCR/DVD scart of the digi-box to scart 1 of the DVDR3380.
The TV aerial should already be connected through the digi-box and DVDR3380 to the TV
To record from the digi-box, select AV1 / E1 / EXT1 on the DVDR3380
If you are doing timer recordings, you will also need to leave the freeview box on the channel you wish to record, or set the freeview box timer.
Dec 15, 2007 | Philips DVDR3380/05 DVD Recorder
Pioneer PureVision PDP-503MXE 50 in. Plasma Television Logo
211 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
