Question about Candy CIV60 Electric Dryer
Dryer will not start properly, buzzer operating
Candy CIV60 front loading tumber dryer - I set the timer to the required length but when I press the start button a buzzer goes off and it does not start, If i keep pressing the start button and move the timer dial at the same time eventually the buzzer stops and the dryer starts. I believe the buzzer is supposed to operate at some time during the cycle to indicate something, maybe nearing end of cycle, I do not know whether it is the timer assembly, the relay pcb or start switch which is faulty
  • Anonymous Mar 27, 2014
    When the buzzer goes off I have to turn the timer to make it stop buzzing.And you don't have to push start button for it to come back on.Just turn the timer against
    Novelist:
    Champion:
  • 244 Answers
More than likely your timer is faulty too much to replace most timers about same price to replace your dryer if not cheaper
Posted on Aug 11, 2007
Why won't the buzzer alarm go off at the end of a drying cycle
Search Results
    Why does my Kenmore dryer model 417.94802/94862 end ...
    www.shopyourway.com > Manage My Life > Questions
    Why does my Kenmore dryer model 417.94802/94862 end of cycle alarm go off ...washer/dryer unit I do see that it is normal for the end of cycle buzzer to go off ...Why won't my Kenmore dryer model 110.86872100 shut off at the end of the ...
    Why won't the buzzer shut off on my Kenmore 80 Series ...
    The buzzer won't stop buzzing after the load is complete. ... or turn on the timer and the dryer will start just by selecting a cycle and closing the door. ... The dryer should continue to run and at the end the buzzer should only stay on as long as ...
    FIXED The Buzzer At The End Of The Dryer Cycle Comes On But Won't ...
    www.applianceblog.com/.../21739-The-Buzzer-At-The-End-Of-The-Dry...
    Dec 11, 2010 - 10 posts - ‎2 authors
    My maytag dryer has operated wonderfully until today. All of a sudden the buzzer that goes on at the end of the drying will go on but will not shut off unless I open the door.... To test it: by-pass the push-to-start switch and see if when you turn the timer on and close the door, the ... VERY annoying dryer End of Cycle Signal
    Jun 29, 2012
    Maytag DE8410 electric dryer - End of cycle buzzer stuck ...
    Mar 27, 2011
    Kenmore 80 series, buzzer won't shut off
    Sep 10, 2005
    More results from www.applianceblog.com
Feb 08, 2016 | Whirlpool Dryers
No heat
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Jul 12, 2011 | Candy CIV60 Electric Dryer
Candy cic60 not giving hot air
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Sep 20, 2010 | Candy CIV60 Electric Dryer
Error E1
dear customer,
most of the time the timers of dryers aren't faulty even though the dryer doesn't run properly in timmed mode. dryer timers have small motors on the back. The motor rotates gears and cams that open and close switch contacts that control the loads in your dryer. A load is something that does work like a motor, heater, light bulb or end of the cycle buzzer. When the timer is manufactured the amount of time each set of contacts will be closed is built in by the timer cams and gears.so i recommend yu to check the follwoing
  • Test the moisture sensor
  • Test the thermostats
  • Test the heating element
  • and finally the timer device.
hope you find this useful. thank you.
Jul 09, 2008 | Dryers
My candy civ60 dryer dose not heat
hi i too had that problem,when an engineer looked at it the thermostat,element were ok,he suggested that there was a blockage in the air flow,i took the whole thing apart ( i had nothing to lose ) cleaned it with a hoover very carefully then with a clean dry paintbrush,there is vents underneath the dryer if these get blocked the dryer blows cold air, its a saftey measure so that the fluff dosent catch fire ! i hope this helps,mine has run ok for 3 months now.
Dec 28, 2006 | Candy CIV60 Electric Dryer
Candy CIV60 Electric Dryer Logo
340 people viewed this question
Top Candy Dryers Experts
Marvin
Marvin
alanrsm
Tommmix
Level 1 Expert
Are you a Candy Dryer Expert? Answer questions, earn points and help others
