Space bar when pressed gives me a number 4
Was on my yahoo msn dunno wot i pressed 4now my spacebar is gi;vin me 4s if i press F get pf the caps lock when pressed beeps th0e 4letter gi;ves me 0r i;ve had to delete letters/numbers so u can read this 0r there wud be 4s before e;ve0rything an jus noticed som keys like 4;v gi;ving me apostrophes
  • deepenergy69 Dec 15, 2008
    no 4 4there is 4no 4c0rumbs 4its 4ob;viously 4something 4to 4do 4with features on laptop
  • 3 Answers
Try turning the keyboard upside down and shaking the crumbs out. If that doesn't do it, try blowing it out with canned air between the keys.
Posted on Dec 15, 2008
The spacebar on my laptop doesn't always leave spaces between words, what is wrong with it?
Inside the key, there is a metal bar the makes the spacebar key depress from anywhere you press it. Either this bar as unclipped from its hinges or they have broken.
Jul 06, 2014 | Toshiba Satellite A100-S8111TD Notebook
Space bar sticking keyboard
There is something under the space bar you can pry it up carefully and remove the debris it should snap right back in.
Oct 31, 2013 | HEWLETT-PACKARD Computers & Internet
My Dell Latitude D630 spacebar came off. Nothing looks broken, but I can't get it back on.
If the hinge parts are not broken and are still in place then place the space bar over these parts, align it so it is in the correct position then press the space bar down until the hinges click into the space bar.
Dec 15, 2012 | Dell Latitude D630 Notebook
My new straight Talk phone won't unlock
hit the dash that is ABOVE and to the left of the OK then hit the space bar on the bottom. Space bar is the widest key on the bottom and actually looks like a typical keyboard space bar.
Jun 01, 2012 | straighttalk.com
The far right and left ends of the spacebar do not work. In order to use the spacebar function, the direct middle of the button has to be pushed down.
You need to reposition (clip) the torssion bar under the spacebar key (a steel wire formed in a wide U shape), it is unhooked, call for a professionnal if you'r not sure how to do this as you may brake the plastic hinge if you don't know what you'r dooing...
Aug 09, 2011 | Toshiba 310CDT Keyboard
My spacebar key is no longer working properly. I have an acer aspire laptop 5735Z . I deliberately pulled the key off to clean underneath and then just clicked it back on, thinking it would work normally....
There is usually a metal piece under the space bar, if it isn't seated properly the space bar will teeter. Try to remove again and see if they metal bracket is seated correctly.
Oct 18, 2017 | Acer NSK8458AN Keyboard
Space bar is sticky du to liquid accident ( soft
Get a Electrical/Electronic solvent spray from RS, give it a good spray (with Power Off!) and operate it lots of times. The spray will evaporate naturally and may remove the gunk! Ian.
Sep 17, 2009 | Acer TravelMate 5530-5207 Notebook
Onmydelllaptop,thespacebarwillnotspacenormove
The rubber plug below the spacebar button is faulty.The button needs to be removed gently and the rubber plug below it which touches the board below should be cleaned.If this does not solve the issue the rubber plug below the button needs to be replaced.Its a common problem.
thanks and please do not forget to rate the solution.keep updated.
May 19, 2009 | Dell OW7658 (J4624SK8115RT7D50) Keyboard
Sidekick lx spacebar
Go to:
http://www.fixmysidekick.com/sidekick-lx-or-sidekick-2008-space-bar-not-working/164/
Or just read this...:
sidekick2008spacebarpicture.jpgIs the space bar on your Sidekick LX not working when you are trying to text or in AIM? Do you have thesame space bar button problem on your T-mobile Sidekick 2008? Does the Sidekick spacebar work in other apps though?
If so then this fix is for you.
1. Open the AutoText & Spelling screen. From the Jump screen, press the MENU button, then select Settings > AutoText & Spelling.
2. Uncheck the following settings:
    • Highlight misspelled words
    • Auto correct spelling
3. Exit out of the settings screen and try it out.
Hopefully, this will have solved your issue.
How to check for misspelled words with these two options unchecked?
Run a manual spell check on T-mobile Sidekick: To run a spell check while in a text field from any Edit Text submenu, or by using the keyboard shortcut by pressing MENU +S.
Dec 19, 2008 | Sharp Sidekick LX Smartphone
My keyboard is inserting spaces where they don't belong.  it is usually around R's, N's and spaces (I  press the   spacebar once it it inserts 2 or three spaces, the  faster I type the   worse it gets.)...
You should open the key board.and clean space key and change rubber cap.
Hope this be of initial help/idea. Pls post back as requested, how things turned up or should you need additional information.
Good luck and kind regards.
Oct 25, 2007 | Logitech 967437-0403 Keyboard
Computers & Internet Logo
192 people viewed this question
David Payne
David Payne
