Question about Fujitsu LifeBook C2340 Notebook
Fujitsu C-6651 Lifebook does not startup
The power supply is plugged in and switched on (I have tried from a number of power sources) and pressing the suspend / resume switch does not start the computer
  • 1 more comment
  • hotrissoles Dec 14, 2008
    try the main switch on the side
    that worked, thank you very much
    R
  • Arnatkoak Feb 17, 2009
    I am having an issue with a C-Series LifeBook. I shut it down, and now it will not start up. My far left battery light is red, the one to the right of it is green. The side switch does not work, and the suspend button does not work either.
My power button is not working, is their any way to start the nootebook making a power shortcut?
If the laptop was opened up, (ALL power removed -> AC adapter and battery; PLUS -> anti-static precautions taken!), and the laptop has a power on switch, (under the power on button), that plugs into the motherboard; you can unplug the switch, and touch the motherboard contacts to try to turn the laptop on. (Sorry about the run-on sentence) Jump a wire or similar, across the contacts, and see if the laptop turns on. Could try to be more specific, and detailed, if you had listed more info about the Fujitsu Lifebook. Such as it's Series number and Model Number. Example: Fujitsu Lifebook E8210. In this example E is the Series number, and 8210 is the Model Number. Post back in a Comment.
Regards,
joecoolvette
Nov 18, 2015 | Fujitsu Siemens LifeBook Computers &...
Cannot get boot menu on fujitsu lifebook ah531
try del or F8
but i recommed you to go to the BIOS setup,and set the boot priority
it's saver,and easier
Aug 21, 2012 | Fujitsu LifeBook AH531
I was working on my computer and all of sudden shutt down and no power any more
Hi
Take out the battery and the main power supply. Leave it out for about 1 min then plug only the main power supply in and switch on. If that does not work then there might be a problem on the motherboard and you should send it into a Fujitsu agent.
Mar 08, 2011 | Fujitsu Siemens LifeBook T1010 Tablet PC
Fujitsu Lifebook does not boot up
Have you tried draining the static on your computer?
Turn off the computer
remove the battery and adapter
press and hold the power button for 1 minute
plugged back in the adapter and battery
turned on the computer
if not resolved:
tried using an external monitor and connect to your computer to check if you can have a video on the external, if yes it is possible an LCD issue
Also, you may try using a flashlight in your LCD and check if you can see any, if none?
I suspect possible LCD issue.
May 21, 2010 | Fujitsu LifeBook A6010 Notebook
I have a Fujitsu Lifebook LBS6120 notebook
Turn on as you did before and leave on for 10 minutes. Then, try turning OFF the computer by keeoing the POWER button pressed for 7 secons. If the computer goes off, then your screen is fried and the computer is actually booting up normally... you just can't see it ;)
Mar 17, 2010 | Fujitsu LifeBook E8010 Notebook
Lifebook Fujitsu A6020 does not boot up. Hear hard drive work a little but the three lights all flash at the same time and never stops and never boot up. Tried to get into BIOS but unable to.
There are a few causes for this.
  • Battery is bad and is shorting the power supply out
  • Battery is bad and has damaged the power plug in the back of the computer.
  • The power supply is bad and doens't have enough to power the computer.
  • The motherboard is bad/damaged - This is worst case scenario
Let's troubleshoot and see if it is anything else besides the motherboard.
  1. Remove the battery and plug in the cord and power up. If it works, replace the battery
  2. Wiggle the plug in the back of the computer. If it is loose, the plug needs replaced
  3. Take your computer to a repair shot and try a replacement power supply and see if it will work.
  4. If that doesn't work, then you may want to leave your computer there.
Jan 24, 2010 | Fujitsu LifeBook A6020/C Notebook
My lifebook s7010 won't startup. After put the on button the screen still remains black. The fujitsu logo will not appear on the screen.
Unplug the AC adapter from power cord, then remove the battery.Wait 30 min and put the battery back.Plug the AC in power cord and try again.If not start you need check AC adapter with voltmeter.If the AC working your computer need service.
Nov 10, 2009 | Fujitsu Siemens LifeBook S7010 Notebook
Fujitsu fpcr32302 not detecting audio output
First at boot press F8 and then in the advance option select Last known Good Configuration.
At startup press Del and then in the bios select Load Default,save and exit.[This one might or might not work]
On the Desktop...go to START--ALL PROGRAMS--ACCESSORIES--SYSTEM TOOLS--SYSTEM RESTORE and then try to rollback to previous date when the laptop was working fine.
You did not mention the Operating System you are using for Vista here's the link http://www.laptopbeep.com/fujitsu-lifebook-a6025-drivers-for-windows-vista Download the audio driver and install. I suppose you have realtek high definition for XP audio driver you can search through Google.
Aug 10, 2009 | Fujitsu LifeBook A6025 (FPCR32302) PC...
My fujitsu lifebook e7010 doesnt always turn on properly
If an external monitor is plugged in an the display is ok then the problem is probably an inverter board or bad/loose flex cable to the lcd screen.
If the external display is distorted then the problem is the video adapter on the laptop.
Mar 31, 2008 | Fujitsu LifeBook E7010 Notebook
Computers & Internet Logo
149 people viewed this question
Top Fujitsu Computers & Internet Experts
Alun Cox
Computer Links
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
