Question about Canon BubbleJet i560 InkJet Printer
Operator Error Message
I was trying to print when the printer status window popped up and said 'Operator Error. Please press resume button or turn off then on' (well something like that anyway). I tried both and it still doesn't work. I unplugged from computer, turned it on. Still flashed amber. Lifted cartridge lever on top of cartridges. Took all cartridges out then put each one back in. All except one made the printer flash amber. The cartridges that made it flash were refills and the other was brand new. I thought that was the problem, but I had lever up the whole time. Once I put new cartridge in, then put lever down, the printer flashes amber. Please help or I'll just chuck the stupid thing. Thank you
  • Anonymous Jun 21, 2008
    i want to smash this computer
  • Anonymous Mar 31, 2014
    Changed 2 of the cartridges and the printer doesn't recognise them, amber light flashing. Replaced with different ones and the problem still exists.
    President:
  • 2,961 Answers
Firstly most printers need to be told when you have re installed cartridges as they think they are still there from the fault. Go to your printer and faxes menu and select your printer and delete any pending print jobs. Next go to add/remove programmes and delete the printer software driver and disconnect printer from both pc and the mains for about minutes. Re install driver and reconnect printer to pc when prompted by driver or when it is fully installed, prefferably in a different usb port than previous and go through the set up as normall. if the same problem occurs, the printer must be faulty and require a repair or replacement.
Posted on Mar 16, 2007
SOURCE:
IP6000D printer
If your printer is still under warranty, then you can get it serviced for free.
but try, removeing the carts, close the cover, restart it, let it see that theres no carts in at all, put em back in, restart it.
Jul 22, 2008 | Canon Pixma iP6000D InkJet Photo Printer
I have just replaced both ink cartridges (canon brand) and I am getting an E 2 flashing message saying I have a Service Error 5100. I have turned it off and back on and still the error message. help,...
Go into Service Mode and perform an EEPROM reset:
This printer has a service mode for service-related settings and for performing test prints. The operator panel buttons are used to enter the desired service mode.
Service Mode Operations
1) With the printer powered off, hold down the resume button and press the power button.
2) While holding down the power button, release the resume button and press the resume button twice in succession. Now release the power button. The
indicator will blink in green and remain lit in green.
3) Select one of the following service mode functions by pressing the resume button the specified number of times.
Press Resume Indicator Functions
Zero times Green Power off the printer
1 time Orange Service test print
2 times Green EEPROM information print
3 times Orange EEPROM initialization
4 times Green Waste ink counter setting
5 times Orange Destination settings
6 times Green Print head deep cleaning
7 times Green CD-R test print
8 times Orange CD-R print position correction (horizontal)
9 times Green CD-R print position correction (vertical)
4) Execute the function you have selected (except for model setting) by pressing the power button. The printer will switch itself off after performing the function.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy Holidays!
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Dec 22, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Flashing orange light 5 times followed by green
I am also having this problem, would love someone to give us a solution before I through it out the window.....
May 10, 2010 | Canon BubbleJet i560 InkJet Printer
I have purchased a ''Virtually Mint'' Canon Pixma ip90 printer however, when I try to print a document a message pops up stating ''the following ink tank is not installed: black ink tank, colour ink tank....
Hi there you can try.
Following step by step resetting canon Pixma iP90 :
  • Before resetting printer canon iP90, start with printer power off.
  • Press resume button coincide with power button.
  • While pressing power button, release resume button.
  • Press resume button 2 times and then release both button
  • Green LED indicator will blinking and then stopped blinking.
  • When the Power LED lights in green, press resume button 4 times.
  • Press power button and the printer power will off. Otherwise off, depress again power button.
  • And the turn on the printer again, your printer canon iP90 should be response as normal.
All I ask is please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Jan 21, 2010 | Canon PIXMA iP90 Mobile Printer
Canon i9950, Operator error,5 amber blinks
  1. Turn off Canon i550, i560, i850, i860, i865, i9100, i9950 Printers
  2. Hold down Resume button and press Power button.
  3. Keep holding down Power button and let Resume button go.
  4. Press Resume button 2 times then let BOTH buttons go.
  5. Green lights will flash and then stop blinking.
  6. When green lights are solid, press the Resume button 4 times.
  7. Press the Power button and the printer should turn off, if not, press the Power button once more.
  8. Your Canon i550, i560, i850, i860, i865, i9100, i9950 Printers should respond as normal.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
Jan 02, 2010 | Canon i9950 InkJet Printer
Keeps blinking. I've shut it off, and cancelled all print jobs - even unplugged it. Keeps blinking. Says there is an operator error
Try this:
1. Turn off printer (use button, don't unplug)
If this not help may the print head is defective.
Oct 07, 2009 | Canon BubbleJet i560 InkJet Printer
Will the printer become damaged because repeated error message?
Do a EEPROM initialization:
Service Mode
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Jun 26, 2009 | Canon PIXMA iP1600 Printer
Status Monitor informs of Ink levels requiring me to press resume button during and after each print job.
What it means is the tank to collect waste ink (from cleaning etc) is full.
Canon suggest you return ther printer for replacement of the absorbant mat, suggest you scour the web for DIY cures.
Oct 19, 2007 | Canon i9100 InkJet Photo Printer
Canon BubbleJet i560 InkJet Printer Logo
938 people viewed this question
Clive
Clive
old marine
old marine
