Wast ink counter indication saturated ink pad printer is modified ink tank and overflow ink tank now i don't know how rest the printer indication printer stop all functions green light on and green light blink copy photo fax memory card how can i rest
Download the adjustment program (see below)
Extrak adjustment you have downloaded
Go to The extrakded folder then click tricks-collections.bat file
Now set the date setting in you PC to 11 April 2008,
Run adjustment program by click AdjProg.exe file the click accept
Click Particular adjustment mode then select destination and printer port then click OK
Select Waste ink pad counter from the below window and double-click to execute it
Click [Check] button to check current protection counter's value.
Then Click [Initialization] to reset the protection counter to the initial value. Thats all.
After finishing, you can change the date to normal.
Link Adjustment program for epson CX7300, CX8300 and CX9300F
Adjustment program for epson CX7300 : http://www.mediafire.com/?8wrkugah2mj
Adjustment program for epson CX8300 : http://www.mediafire.com/?0xfnrgarvuj
Adjustment program for epson CX9300F : http://www.mediafire.com/?o020wlaf6te
SOURCE: Epson Stylus Photo R320
Turn off the power and look inside the machine to the right hand side. Just in front to f the print head you will see a white plastic dowel (see photo). Use something technical - like a finger, pen or screwdriver - to push this dowel in. You can then move the print head by hand to the middle of the carriage.
Once moved, turn the printer on and watch it travel back to the home position. If after returning home the dowel pops back out and does not retract itself, you will need to strip the machine out and rebuild the ASF section. Sounds hard but its just a few plastic parts to take apart and reassemble whilst looking to see if anything is broken.
Get a service manual; for the machine HERE if you need to strip it out.
SOURCE: waste ink pad saturated. EPSON STYLUS PHOTO R360
Replacing the pads is costly, messy and requires the printer to be taken completely apart. If you have little or no experience of stripping down printers it is best left to a proffessional. Contact Epson to find your nearest service centre, but remember to get a quote as it may be more economical to replace the printer. Sometimes the counter can "jump" to the end of life number, this especially happens where 3rd party or refilled inks have been used. If you believe this to be the case and there is no sign of ink leakage and the pads look fairly clean then you can just reset the counter using special software called the SSC utility. See these sites:
http://www.ssclg.com/epsone.shtml
http://inkjetprinterhelp.us/epsonSSC.html
More information about this issue and the "official" Epson resetter is available from the Epson web site, please read this link:
http://www.epson.com/cgi-bin/Store/support/InkPadsForm.jsp
Please take a moment to rate this solution. Thanks.
SOURCE: need replacement waste ink pad
Hi...
so bye bye waste pad... can't find any replacements but this is my recommendation for you a waste tank... It's what I did on my 2 Epson Printers... Click the link to get the idea...
waste tank
Or you can use some tissue papers to replace what was thrown away.
Happy Fixya...
SOURCE: reset ink-pad counter on epson stylus photo 1400
The simplest way to do this is to grab a copy of the A10_IPR utility that Epson distribute to their customers...
The utility is available to North American customers if you register no this site page http://www.epson.com/ipr/
The utility is also know to be available in the wild if you search for "waste ink ipr".
Just remember to scan any download using a virus and malware scanner before you attempt to use it as some utilities contain trojans or similar nasties.
Hope that helps.
SOURCE: waste ink pad on epson stylus photo r300
The Epson Stylus series of printers do not have this feature. You can find out more inso at www.epson.com. Hope this helps.
