Question about Kenmore 24 in. 15932 Built-in Dishwasher
No water in unit
Turns on but not getting any water
    Master:
  • 638 Answers
My dishwasher will not fill with water: This is often the fill valve. You can test the fill valve coil for continuity with a ohm meter, no needle movement = bad fill valve. You can also test the fill valve for 120 volts at the fill valve with a volt meter, power there and no fill = bad fill valve. No 120 volts there, you will have to trace power back to find the trouble maker. Test things like the float and float switch, wires and timer. Fill valves are very bad for working once or twice and then quitting, if your dishwasher fills the first and second fill cycles and then no more water through the rest of the cycle, replace the fill valve. You will need to remove the access panels to get at the fill valve. Dishwasher fill valves also have a screen built into the valve entrance, this can also get all clogged up and need to be cleaned.
Posted on Dec 14, 2008
Air conditioner wont work
When the STOP indicator light turns on, the internal water tank has filled with condensed water and the air conditioner will turn off automatically. You can drain the internal water tank by removing the plug on the back of the unit, be ready for a lot of water to come out of the unit. The unit will shut down when the water pan is full. This condition may occur either when the unit is operated in high humidity conditions, or when the unit is being operated in HEATMODE, since the auto-evaporation function will not work in the heating mode. I hope this helps, have a great day, Andy K.
May 22, 2013 | Heating & Cooling
Low humming noise coming from the dishwasher when start no water going into machine?
First you will need a tester , that has 120 volt setting remove the lower cover and you should see a water valve sometimes they put them in the back of the unit also , but always near the floor, with this unit plugged in and unit turned on so that it should be filing with water, check the wires on the water valve to see if you are getting the 120 volts , if you have the power but the unit is not filling the water valve is bad , if you dont have power at the valve then the timer or door switch is bad this is all there is to this unit , I bet on a bad water valve here is a place to get parts and as always be careful when worjking with unit with power , if you need to replace anything turn main power off before seviceing unit , I have found several washers the water valve wa sjust fill of dirt , cleaned it and it worked just fine , if you need parts go here , http://www.appliancepartspros.com/ email me at glipsky@tampabay.rr.com
Jul 26, 2011 | Bosch 24 in. SGS43C12 Classixx...
I have a instantaneous water system 10H Hydropower ...did not get a manual when installed....I need to have hotter water as it's winter and the water is like warm...not sure what to adjust...opened...
take the cover off the 10 h unit light up the burner by turning on the tap turn the water flow tap on the front of unit (white knob) clock wise slowly feel hot water pipe coming out off unit when temp increases put cover back on check temp at sink if too hot turn knob anti clock wise
May 23, 2011 | Bosch Water Heaters
I have powerstar model # 45557701- what causes the cracking noises when water is heating? what will make the unit slow to start to heat? how can i change the heating units?
The crackling noises is just from air in the water and should be of no concern. If you are having a problem of heating up the water with the unit it is most likely do to water moving too fast through the lines. Ideally, there should be a shutoff valve installed on both sides of your heater (makes for easy removal if it needs to be serviced). But if you turn off the valve about 1/4 to 1/2 way on the one on the "in" side of the heater (where the cold water enters) then you will slow down the water going through the heater and this will give the water a better chance to heat up. This should alleviate the heating problems you are having. If you do have a shutoff valve on the cold (in) side of the heater, shut it off about 1/4 to 1/2 way and then go to your shower and turn the hot on all the way (no cold). Wait for the water to warm and test the water by hand to see if it is the temp you want. If it is still not warm enough, turn the hot on the shower DOWN just a little. This will actually make the water hotter. I know this doesnt seem right but it will. On the other hand, if the water coming out with the hot water fully turned on is too hot, then just turn on a little cold water at a time until the water is the temp you want. Remember, always give the water plenty of time to get from the heater to the shower before you decideof its the right temp. Ideally, you should be able to turn the hot water on all the way and get the hot temp that you want and if you want to cool it down, just turn the cold on just a little bit until it is where you want. I'm fairly sure the problems you are having are due to the water going too fast through the unit and once you adjust that and understand better how these tankless heaters work, you wont have any more trouble. They are difficult to get used to after using conventional water heaters and the manufacturers arent very good about giving you these hints so they will work properly. You will need a professional to uninstall and hopefully this will work and you want have to. But if you do, it requires shutting off the water to the unit. Shutting off the pwer to the unit. Unattaching the water lines to the unit and then unattaching the electric lines from the junction box or wherever they are attached. The heater then can be removed from the wall by unscrewing the screws from the hangers which hold it to the wall.
Feb 21, 2011 | Bosch PowerStar AE115 Tankless Water...
Water heats, then turns cold
These units need lots of flow to start and run. Set the temp on the unit lower and the people in the shower will have to use more hot and less cold which will make the unit more stable.
Jun 29, 2010 | Bosch AquaStar Indoor Natural Gas Tankless...
Ice machine not filling up with water
I'm uncertain as to your approach to the actual repair of the tubing, but when you turned the water off and then on some sediment may have clogged the water inlet screen for the icemaker. Turn the water off and check the water inlet screens for a possible clog. If not clogged, contact an appliance service company.
Apr 14, 2010 | Kenmore 53092 / 53094 Side by Side...
Pilot light will not automatically light when hot water is turned on
This is a great unit! Try turning the flow nob to the half way point and the flame all the way to low. Run the hot water tap and slowly turn the flame dial until you hear the unit try to light. Every house is different regarding the restrictions in the plumbing and water pressure. Once the unit tries to light that is your minimum setting. It is best to leave it there.
Apr 05, 2010 | Bosch & Tankless LP Hot Water Heater
We have the WH95TP unit on our boat. It has worked great for 10 years. Last weekend there was water leaking from behind the unit. We turned it off and turned the water flow off and left for the week. When...
Was the unit running when it was warm? If it was then you need a tech to look at the sealed system. If it wasnt running then you need to adjust the icemaker ejector blade so its straight up (12 oclock) Thats when it will allow the compressor to come on.
Sep 26, 2009 | U-Line Refrigerator Ice Maker
Unit not working - don't know how to remove
the unit willnot effect any water delivery anywhere in your house.
Mar 03, 2009 | Thermasol Steamshower Generator AF Series...
Water is not getting hot enough to wash dishes
Is this a home unit or commercial unit? Most home units use the hot water supplied by your hot water heater so to get it hotter you need to turn that up.
Oct 07, 2008 | Dishwashers
Kenmore 24 in. 15932 Built-in Dishwasher Logo
1,077 people viewed this question
Top Kenmore Dishwashers Experts
D. E. Hev
Fred Sops
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
