Question about Sony Cyber-shot DSC-W30 Digital Camera
Camera won't turn on
When I insert battery a red light comes on right next to where the battery is located in the camera. Although the battery is charged the camera won't turn on.
  • kristinkell Feb 03, 2009
    I just charged my battery, and inserted it into the slot. When I try to turn on the camera, a red light by the battery blinks and my camera won't turn on.
    New Friend:
Do not turn on the camera and the battery charged to enter the red LED does not light next to it. Take a fuse inside?
Posted on Jun 08, 2013
There was a POWER button.Please press the button.The button will show GREEN.
Posted on Dec 19, 2008
Canon t3i will not turn on without sd card?
This a situation the manual not even mentions. The red light on the bottom right of the camera is the memory access indicator. It should light green as I remember ok. And blink when it is writing to or reading from the memory. If it is red, it means : this is not ok.
This light is not a gadget. It should be taken serious. As long as it is burning, of flashing you are not supposed to switch of the camera or to remove the memory card. If you still open the memory compartment or switch of the camera or remove the battery, while the camera indicates I'n accessing the memory, serious damage can occur to the memory card.
You could lose all your pictures, because of it.
I would suggest, make sure your battery is charged correctly.
Format your memory card in a PC with FAT 32.
Check if al contacts in the camera are clean and shiny. (Battery and memory card contacts too)
The place the battery and the memory card in the camera and try switching it on again. If it should start, first do a format of the memory card in the camera before you starts taking pictures, of the camera has its own format and can make a folder.
You should be able to switch on the camera without a memory card inside. The camera will us the internal buffer, to let you take a picture in DEMO mode.
I hope the red light does not indicate your internal memory is corrupted. Because if nothing helps and the red light comes back, I think you should contact a Canon service centre.
Jan 14, 2014 | Canon EOS 600D Rebel T3i Digital Camera
Canon Ixus 105 got a bit wet, now it won't turn on and indicator light at the back is red/orange??
Sit the camera in sunlight for few hours until its get warm and make sure the battery and memory card out and the doors must be open . After that insert the battery only and try to turn on and see the result.
Aug 07, 2012 | Canon PowerShot SD1300 IS IXUS 105...
I mistakely deleted pictures from my camera (Kodax Esay Share M340) Move picture to internal memory.How can i get the pictures back
If Try one or more of the following
Ready light does not turn on and the camera does not work.
Ready light blinks green.
  • Camera is operating normally.
Ready light blinks amber.
  • Wait. Resume picture taking when the light stops blinking and turns green.
Ready light blinks red and camera turns off.
Ready light glows steady red.
Ready light is off or glows steady green.
Mar 10, 2011 | Kodak Cameras
Won't turn turn on. A red and green light comes on, but nothing on the screen.
Step one: Reset the camera
  1. If you have an optional memory card installed, remove it.
    NOTE: Although removing an optional memory card is not necessary for performing the reset, it eliminates the memory card as a possible cause of the problem.
  2. Remove all batteries from the camera for at least five seconds.
  3. Reinsert the batteries and close the Battery/Memory card door.
  4. After verifying that the camera works without an optional memory card, reinsert the card if you removed one in Step 2.
Try to turn the camera on. If it now works properly, the camera experienced a temporary electrical problem and should now work properly.
  • If the issue is resolved , you do not need to continue with the rest of the instructions in this document.
  • If the is not resolved , continue with the next step.
Step two: Check for damage or corrosion on the batteries
  1. Open the Battery/Memory card door on the camera.
  2. Remove the batteries.
  3. If the batteries are damaged or show corrosion, replace the batteries.
Step three: Recharge the batteries
  1. Recharge the batteries or replace the batteries if they are damaged or will not charge.
  2. Try turning the camera on after the batteries are fully charged or have been replaced.
Step five: Ensure the batteries are installed correctly
  1. Re-insert the batteries correctly into the camera by referring to the image on the Battery/Memory card door for proper battery placement.
  2. Try turning the camera on.
Step six: Turn on the camera without the memory card
  2. Remove the batteries and optional memory card from the camera.
  3. Wait 15 seconds.
  4. Re-insert the batteries into the camera, but not the memory card.
  5. Try turning the camera on.
    • If the issue is resolved , format the memory card in the camera and then you do not need to continue with the rest of the instructions in this document.
    WARNING: Formatting the memory card in the camera will erase any images stored on the memory card. To avoid losing the images on the memory card, first save the images to a computer or another disk.
Step seven: Service the camera If the camera still will not turn on, service the camera.
Mar 04, 2010 | HP Photosmart E327 Digital Camera
Should the power light be green or red, when I turn camera on it shows a green light then turns red
Red light indicates that the camera is out of charged., Try to charged your battery for 3-4 hrs if you encounter flashing red on a fully charged battery you need to call kodak 1 800 235 6325 ext 12
You can charged you camera using 5V AC Adaptor or a USB cable taht attached into the computer
Nov 16, 2009 | Kodak EASYSHARE M1063 Digital Camera
The battery wont charge
i had the same problem.
if your battery light is blinking a red light then you should call up casio's technical support and they'll send you a new one within 2-5 business days:)
call 1-800-435-7732 for technical support! :)
Apr 01, 2008 | Casio Exilim EX-Z77 Digital Camera
Camera wont turn on, intermittent red power coming on
This may or may not work (it's primarily a trick for certain Canon cameras with similar symptoms). Remove the cameras battery, then remove the memory card. Insert a BRAND NEW or fully charged rechargeable batteries. DO NOT insert the memory card. Instead, just turn on the camera. If the lens retracts, turn off the camera, insert the memory card, then restart the camera.
If this doesn't work, here are some other things to try. But don't get your hopes up, as they only seem to work for little less than half the cameras with similar problems:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jan 08, 2008 | Fuji FinePix V10 Digital Camera
Sony Cyber-shot DSC-W30 Digital Camera Logo
180 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
