Question about Hitachi 43FDX20B 43" Rear Projection Television
Hitachi 43fdx20b blurred Picture
I'm in Atlanta, Ga and I have a Hitachi 43fdx20b projecion tv about 4 years old with a blurred picture in the lower left hand corner, double images. The tech that came out tried to adjust the convergance on the set, but he stated that it wouldn't line up. He suggested that I get two ICs replaced. Is this a proper diagnosis? With parts and labor, what is the going rate for this type of service and how long should it take to perform?
  • Anonymous Mar 15, 2008
    Same exact thing Berney has wrong with his television is wrong with mine. I have adjusted it and cleaned it throughly and cannot diagnose the problem. One thing I thought that it could be is undernieth the adjustment eyes there is some sort of fluid in it, it looks low and there is a place to add new. I would do so if I knew exactly what it was for fluid. Could someone help me with this?
  • Anonymous Mar 30, 2009
    Left quarter of the screen is blurred or like double vision with green lines.
    President:
  • 3,130 Answers
Yes this is a normal diagnoise. Just about every Tube type projection TV set ever made will one day need these IC's replaced. They are not really that hard to replace but you would need to know how to solder and unsolder on printed circuit boards, know the procedture, and then have a service manual handy to adjust the convergence after yoou replaced the IC's. If the tech works on alot of these types of TV sets's, most likely they could adjust them without having a service manua handy. This repair done by a pro should run you anywhere from 250 on up to 400 bucks depending on who does the repair and where. Good Luck
Posted on Apr 01, 2007
My hitachi 43fdx20b has a pink tint to it. I have noticed that if i move the tint slider one way or the other it will turn the screen green, but now it doesn't. Does this have something to do with my...
My 43fdx20b had a pink tint to it also. The picture was clear otherwise. I found, on mine, I needed to adjust the Red Screen control. It was located behind the front panel. I removed the two screws on either side of the front panel and was able to remove the panel. Then I adjusted the Red Screen control. I found that if I tuned in an old Black and white movie I could adjust the color fairly accurately. Good Luck.
Jan 02, 2010 | Hitachi 43FDX20B 43" Rear Projection...
Convergence chips replaced, tv powers on and no picture
You have to replace the chip with the same kind, or at least crossed referenced, but still exactly the same but diffrent manufacturer.
Aug 15, 2009 | Hitachi 43FDX01B TV
The red light on front of tv is on but tv itself (picture), sound
Check all the picture bulbs works.
This is a plasma tv right?
U have it along time right?
Aug 13, 2009 | Hitachi 43FDX20B 43" Rear Projection...
Hitachi 43FDX20B, watching tv, screen went blank, no picture, no sound turn off then back on power light on but the same nothing
The TV computer may have detected an error. See if the problem persist after unplugging the device overnight to reset it. If it does not, the issue may be with the board or its power supply circuit. Probably loose soldering or leaking capacitors.
Jul 24, 2009 | Hitachi 43FDX20B 43" Rear Projection...
What dose a convergence board look like?
This is what the convergence PWB looks like. Its located on the extreme right side of the chassis looking in from the rear of the set.9cc0c04.jpg
Nov 27, 2008 | Hitachi 43FDX20B 43" Rear Projection...
Double picture 3d
You need new Convergence ICs post the model number and I will post the numbers you need and where you can get replacements with free instalation instructions with pictures
May 13, 2008 | Hitachi 43FDX20B 43" Rear Projection...
Hitachi 43fdx20b
well i had the same t.v. and u will have to set the picture tube which is really simple it ight seem hard but if you need an hand give me an call 1-403-362-2560 and ask for jason
Dec 17, 2007 | Hitachi 43FDX20B 43" Rear Projection...
Samsung rear projection 42" green curves causing distortion just started
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
http://www.digitalhome.ca/forum/showpost.php?p=564268&postcount=220
Dec 02, 2007 | Hitachi 50UX57B 50" Rear Projection...
Flashing power light
you need 4 caps in you dm module they are 1000 mf @35volts
May 23, 2007 | Hitachi 43FDX20B 43" Rear Projection...
Dark , blurry picture
MTNESTR, My guess would be the FBT loc.TH01(flyback transformer) Hitachi p/n#BW03004 which would be far less expensive than replacing the entire deflection board... A shop could ring test the FBT to confirm the failure. I do know the FBT in this unit has an internal resistor that is prone to failure. It is in-line with the focus block and if it's open it would explain the blur and lack of screen voltage to light the crts properly. The deflection board is about $290-$350 plus shipping and a FBT is somewhere between $60 - $90 depending on the supplier. Hope this helps! Bill
Jun 04, 2007 | Hitachi 46F510 46" Projection HDTV
Hitachi 43FDX20B 43" Rear Projection Television Logo
316 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
