Question about Lexmark P4350 All-In-One InkJet Printer
Jamming paper Paper jamming in feeder tray . Regards Stoves
    Scholar:
  • 31 Answers
The paper pickup rollers might be worn out. They can be restored by rubbing Acetone (use gloves)on them just make sure that the acetone doesn't touch any plastic. There also might be a piece of paper stuck in the printer paper path. It might be out of sight and blocking the paper as it feeds into the printer.
Posted on Aug 20, 2007
SOURCE:
Fix paper feeder that keeps jamming. How to clear jam and fix on-going jamming problem
What thickness of paper are you using? Also is the paper new/fresh or are you re-using paper that has gone through the printer already?
Mar 03, 2015 | Lexmark X4550 Wireless All-in-One Photo...
I keep getting paper jam on my copier, tried cleaning the tray and feeder compartment but still the jams and squeezing of paper. what should i do pls
Try it from another paper tray and see it if still jams. IF it goes through, your first tray needs a roller cleaning or new rollers. Is it jamming out of the cassette or up into the fuser?
Feb 11, 2010 | Sharp AR-275 Copier
Jamming Problem
Clean the rollers,and select 2 sided to 2 sided.
Dec 28, 2009 | Canon imageRUNNER C3220 Color Copier
Phaser 7300 jamming manual feed
Can you print fine with no jams from the lower tray?
make sure you have clean new paper and start out with the 11"x8.5' letter paper. If you have that then follow the instructions below.
  1. Make sure there is no peaces of paper jammed in the path.
  2. clean the rollers with regular rubbing alcohol sometimes the rollers get way dirty to pick up the paper.
  3. If none of these tricks helped you then you have to change the the manuel feeder. part # 116-1561-00 good luck.
Dec 07, 2009 | Xerox Phaser 7300DN Laser Printer
Paper feed jamms the paper all the time, will not feed without jamming from bottom tray, top tray jams every 2 to 3 prints or print with the top corner bent
Unless both feeder rollers went bad at the same time, which is unlikely, it must have something to do with the paper. It might be slightly damp, or not the correct kind. Try using high quality matte white paper from a brand new pack and see whether it still jams.
Oct 27, 2009 | Canon PIXMA MP530 All-In-One InkJet...
Paper tray is jamming every few pages
My suggestion is to take out the paper tray. Put a little alcohol on a soft cloth and clean the feed rollers underneath . also install a fresh **** of paper.
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_7148ad2a373711a3
Aug 03, 2009 | Xerox Phaser 8400 Laser Printer
Document feeder jams
When you put your paper in, check the side clamps are set correct, if there is a gap at one edge, your feeding will be all over the place.
Tuck up the clamps to clamp the paper, not too tight where you bend the paper, but tight enough to hold it correctly.
Regards
Richard
Mar 13, 2009 | HP Officejet Pro L7680 All-In-One Printer
Bulk feeder keeps jamming
It might be the tray Feeder not placed properly or the printer needs a service if not done in the last six months. Contact to your nearby Repair shop and Service centre.
Thanks
Scott
Feb 06, 2009 | Kyocera FS-4000DN Laser Printer
DOCUMENT FEEDER IS JAMMING
Try and clean the rubber rollers with Isopropyl alcohol. Do not use any solvents.
S. Mohan, Chennai, India
Dec 30, 2008 | HP Scanjet 5590 Flatbed Scanner
Lexmark P4350 All-In-One InkJet Printer Logo
184 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Clive
Clive
Thomas F. Schneider
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
