Question about HP Photosmart C3180 All-In-One InkJet Printer
Several sheets of paper are stuck. How do I get them out?
When I presssed the start copy button, the copier grabbed a small stack of paper, and the paper has jammed the copier.
  • Anonymous Jan 25, 2009
    i wanted to print a page but when i inserted the page it got struck and now i am not able to remove it
  • Anonymous Feb 18, 2009
    I have a paper jam on the HP C4380 and it says I have a carriage jam and to clear carriage. How do you open the carriage to clear the paper that is jammed and stuck inside?
  • 461 Answers
First remove any paper not loaded from the tray - DO NOT use force!
The following is from the HP Website:
Clear a paper jam from the back of the All-in-One
  1. Disconnect the power cord from the back of the product.
  2. Remove the rear access door: Press the tab to the right, and then pull out the door. Figure 1: Remove the rear door several sheets of paper are stuck.  How do I get t - c00652942.gif
  3. Gently pull the paper out of the rollers inside the product. CAUTION: If the paper tears when removing it from the rollers, check the rollers for torn pieces of paper that might remain inside the product. If any torn pieces of paper remain inside the product, more paper jams are likely to occur.
  4. Replace the rear access door. Gently push the door toward the product until it snaps into place.
Posted on Dec 16, 2008
Several sheets entered the printer at the same time and stuck. can't pull them forward or backward.
Step 1 Clear any loose paper from the paper tray. This will help you locate the jam. You will find it either in front, near the paper tray, or in the rear.
Step 2 To clear a paper jam near the paper tray, grip the paper and pull it firmly but gently from the printer. If you find a stack of papers jammed, grab from the middle of the stack and pull.
Step 3 For a rear jam, remove the back of the printer. When you find a free edge on the paper, grip it firmly and pull it out.
Step 4 Replace the back cover. Press the "Resume" button or turn off the printer, and then turn it back on. Your settings should reset.
Step 5 Try printing another document
Jan 13, 2011 | HP PSC 1600 InkJet Printer
Will not accept paper and print, I have taken the roller out at the back and replaced it again but it still wont latch on, if it occasionally does then it grabs several sheets and spits it out again or...
Dec 04, 2009 | HP PSC 1410 All-In-One InkJet Printer
It grabs several sheets of paper at one time
This is most likely a paper problem, the paper is basically sticking to the next sheet, Ensure the paper is stored in a cool dry place helps, dont load the paper with more than what you need for a couple of days and when loading the paper flick the pages to allow air between the pages
If this dosnt work try a different brand of paper
Sep 09, 2009 | Lexmark Optra E310 Laser Printer
Will not feed paper of any size. No jams ever.
clean the feed rollers with water and soft cloth.. try a stack of paper not a single loose sheet
Aug 15, 2009 | Epson Stylus 1400 InkJet Photo Printer
Entire paper stack jammed at feed chute entrance.
check at the rear part of your printer there a backdoor latch there..
open it..and you can get the jammed paper easily..
if there is a pieces of paper can get it by force..
rid the paper into pieces and clean the rollers of your printer..
and restart you printer..
hope it helps..
May 24, 2009 | Epson Stylus CX5400 All-In-One InkJet...
Paper feed grabs more than one sheet
Try fanning your paper several times. Take that nice neat pile of paper in your hands and wiggle it so that your thumb fans through the edge of the whole stack. Do this on both edges so that the stack of paper is slightly less perfect. You can also gently fold the whole stack slightly in both directions. Do this every time you add fresh paper. It should only take a few seconds.
Apr 21, 2009 | HP Hewlett Packard Officejet Pro L7680...
Toner overflow
Could be the cleaning blade isn't working on the drum.  Is the paper getting stuck on the fuser unit?
Oct 25, 2008 | Ricoh FT3713 Copier
Vertical paper feeder for the copier not grabbing next original sheet
I'm having a similiar problem. Can't consistantly feed one sheet at time. If i load several sheets it pulls all through, etc
Sep 03, 2008 | HP OfficeJet G85 All-In-One InkJet Printer
Printing and faxing more than one page at a time
Hi This is a common problem, not only with your printer, but most at some time or other. In part it seems you get what you pay for, in that if you buy premium paper (business grade 40 mil), you normally have less problems. The paper is drawn into the printer by a rubber or compacted foam roller, and sometimes the paper sheets will sick to each other, and more than one will be drawn in. The best thing to do if you are using less expensive paper, or even the expensive stuff, is to "fan" the stack of paper several times with your thumb, at the end that will face the rollers, and also don't let the stack get down to only 3 or 4 sheets, as the problem is worse near the bottom of the stack. Hope this helps. Good Luck!
Nov 30, 2006 | HP OfficeJet 6110xi All-In-One Thermal...
HP Photosmart C3180 All-In-One InkJet Printer Logo
139 people viewed this question
Ben Johnson
