Question about Frigidaire GLER331A Electric Dryer
Dryer was running, then it just shut off and now it wont turn back on!
  • 686 Answers
Check your thermal fuse if it is open which means burned out either the whole machine won't work or the heat element either way check that first
Posted on Mar 02, 2009
  • 85 Answers
Posible thermal fuse failed, motor or breakers tripped. always check breakers 1st
Posted on Dec 16, 2008
Dryer completely shuts off after about 15 minutes. Cannot turn the dryer back on for about an after
SORRY TO HAVE TO TELL YOU BUT Dryer runs then shuts down wont start up for an hour:
Bad motor windings
Aug 31, 2014 | Dryers
Dryer light stays on when door is shut nd wont run
check the door switch,i don't work on lg but on any other dryer if the wsitch is broke the dryer won't start and if the light is on the switch shuts off the light and dryer will start.if you send the model number i can look up the switch for you.open the door and look around the frame where the door closes into,there should be a push button switch or a little paddle that the door hits,when you push in on the switch it should make a clicking sound or i've seen the paddle broke off.hope this helps or if you removed any wires to the door switch you might of wired it wrong
Mar 30, 2013 | LG Dryers
It shut off and now it wont turn back on
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 11, 2011 | Maytag MDE5500AYW Electric Dryer
Shut off and wont come back on. Dryer does nothing at all
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer Repair - The
heatman101
Feb 18, 2011 | Dryers
Amana DLE330RAW Elec Dryer starts then shuts off & wont turn on
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer2_bing.gif Repair ? The dryer2_bing.gif will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Jul 08, 2010 | Amana DLE330RAW Electric Dryer
DRYER WONT TURN ON. IT WAS RUNNING. TIME WAS UP AND CLOTHES NEEDED MORE DRYING. WENT TO TURN IT BACK ON AND ITWOULD NOT START.
1. Check the circuit breaker for your dryer
2. check to make sure the door switch is operating correctly (this is a safety device that prevents the machine from turning on if the door isn't shut or if the switch is defective.
3. Recheck
May 26, 2010 | Amana DLE330RAW Electric Dryer
Dryer wont start
most of these dryers have a thermal fuse that shuts the dryer down when it over heats and it is not resetable. most of these on a kenmore are on the back of the dryer. locate the thermal fuse and use an ohm meter to tell if it has continuity or not. no continuity - replace it.
also if your dryer is over heating one of the most common causes is a crimped vent hose or pipe. don't use plastic hose as it crimps shut easily and won't let the heat out of the dryer causing the problem you described.
May 25, 2010 | Kenmore 500 6952 Dryer
Dryer wont run
sound more like a motor problem,, does it sometimes humm while trying to start ,,that first sign ,, repl motor
Dec 29, 2008 | Dryers
Dryer wont run
The fuse is located on the rear bulkhead upper right hand side. Clean the dryer out open all vents check slides and rear bearing.
Dec 14, 2008 | Frigidaire GLER331A Electric Dryer
Frigidaire GLER331A Electric Dryer Logo
74 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
