Question about Whirlpool LSR5132PQ Top Load Washer
Water won't stop filling
Once the easher is turned on, the water will not stop filling. Even if you push the knob in, it keeps filling the tub.
  • limida3 Dec 18, 2008
    Got the part, just waiting for a friend to help me put it back together. Thanks.
  • 113 Answers
You need to have the fill valve replaced. Easy and inexpensive. With the correct model # i can give u a schematic and part #. Let me know if you need help. Dave www.washermd.com
Posted on Dec 16, 2008
MAVT734EWW washer's water level not working, will just keep filling the drum and not stop even when open top door or click knob to off, have to turn water off at the source
A defect in the water-inlet valve may mean that it's no longer able to shut off completely when the electricity has been turned off to it. If this occurs, the valve may leak and drip water into the clothes tub. In time, the water may accumulate substantially. If this happens, you need to replace the valve.Replace the water valve with this part.
Nov 30, 2010 | Maytag Washing Machines
Water level dont stop I bougth a new part and still have the same problem the water dont stop.
put the washer on cold,start to fill washer, turn washer off if water still keeps filling you have a bad water valve,do the same test on hot,if both turn off when you push stop then check the water level hose from the water level switch to the tub,if both ends are secure then replace the water level switch-mike
Feb 18, 2010 | Kenmore 22422 Top Load Washer
Keeps filling up with water even on spin
Close the water supply valve and allow the machine to completely drain the water from the tub. Turn off the machine and disconnect it from the power outlet. Open the water supply valve. Replace the water inlet valve if water drips into the tub when the machine is off.
Start a new cycle if the machine stops filling when it is off. The control board or the water level switch is malfunctioning if it keeps filling even during the spin cycle. Indicate the model number for proper troubleshooting and repair assistance.
Feb 05, 2010 | Washing Machines
Whilst on the rinse cycle, it just keeps on filling with water and does not stop. If I am out, it is just waisting water all of a sudden. I have to physically turn the dial to Spin for it to stop filling...
Easy fix, no parts needed mate. Simply look for a loose hose going to the water level switch. The small vacuum hose from tub to switch vibrates off from time to time OR sediment gets into the tube where it attaches at the base of the tub. Remove the hose at the switch in the control console and blow through it to clear any blockage and reattach firmly. Remove the water and retry. With any luck the washer will resume normal duty's. Good Day!
Jan 11, 2010 | Speed Queen AWS75NW Top Load Washer
Washer tub won't stop filling with cold unless tap is off
Sounds like jammed open solonoid valve on hot or cold......water?,,quite simple to fix parts about *£8.00
Nov 02, 2009 | Washing Machines
Agitator starts at begining of cycle before washer is full
Please be carful as running the agitator without enough water will overheat and kick out the motor, however it should be ok when it resets itself.
Yes, the machine should stop agitating when you lift the lid so this too is part of the problem.
After looking at the print I can only suggest that the cam contacts in the timer ( contacts 12 and 14) that start the motor are burned and stuck together.
Quentin
Sep 17, 2009 | Frigidaire FEX831CS Top Load Stacked...
Won't stop filling with water
Does the water continue to run when the washer is unplugged from power?  If it does, then there is something stuck in the inlet valve that is keeping it open.  Could be the result of mineral deposits.  If the water stops when unplugged then the water limit switch is defective.  Unlikely since the water still flows when control knob is in off position.
May 29, 2009 | Washing Machines
HELP ME WITH MY PROBLEM
if water stops when knob pushed in raise console (probably screws under each end cap just pull caps toward you to remove )remove screws lift console ck small hose going to water level switch to be sure it is pushed on ..if water will only shut off when faucet turned off replace fill valve
Dec 12, 2008 | Kenmore 22422 Top Load Washer
Cold water keeps filling even when knob is pushed in
replace fill valve trash has gotten past screens in valve or screens are missing..remove screws each rear corner of console ..lift console ..remove lid switch plug remove clips each corner of top pull cabinet forward and off
Dec 01, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool LSR5132PQ Top Load Washer Logo
47 people viewed this question
Dan Webster
Dan Webster
Sal De
