The Tub in my machine is off balance
When my washing cycle hits the spin cycle it made the thumping your load is off balance sound and so i adjusted the load and it still made the sound. Even with no clothes in it there was the sound. The tub itself is leaning to the left and will not shift back to center when I pull it over there. I need to know how to adjust it back to center.
Thank you
Shana Prosperi
  • luponem Jan 01, 2009
    I think I have a similar problem with my Kenmore 80 series washer. The tub is off center. It leans to the front right of the maching. I do not have any wash or spin issues. It has been like this for the past few years. Looking under the machine I cannot tell why it leans. I read in other forums that the springs that balance the tub could wear out, but this seems strange.
  • Anonymous Mar 01, 2009
    i have the exact same problem, hope someone knows what to do to fix this.
  • 11 Answers
SOURCE: Kenmore Waher spin cycle out of balance
Sounds like your front to back spring is pulling to tight, sometimes you need to replace it and sometimes you can take it off and stretch it. hope this helps
Posted on May 20, 2007
  • 1314 Answers
SOURCE: whirlpool top load washer- tub will not keep balance
did you take out the shipping bolts when you bought it if you did then its the universal joint under the agitatot or in it more likely
Posted on Dec 30, 2007
  • 125 Answers
SOURCE: tub out of balance
Assuming the machine is level I would first push the wash basket to the right rear corner while holding it there look to see if the spring on the left front corner is connected, if not reconnect it if its gone order a new one. Hope this helps
Posted on Jan 12, 2008
  • 1028 Answers
SOURCE: new washer violant spin cycle,even
ck to be sure shipping rod has been removed you will need to pull washer out and look for a pin through a rod that runs from 1 side to the other pull it completely out relevel washer if needed
Posted on Aug 11, 2008
  • 1122 Answers
SOURCE: I have a Kitchen Aid
there are 3 springs that hold it to the frame,remove the 2 screws from the washer head,one on each side,now pull up on the head and lift the front out and up,you will see 2 spring clips pop them out with a flat screw driver,open the lid and pull the washer case toward you,sit it aside and look at the other springs they will tell you where the other one goes,also the tub sits on a triangle bracket make sure that is in place to,under the tub,let me know-mike
Posted on Sep 26, 2008
What could be the cause of loud thumping during spin?
Sounds like one of the balancing springs either broke or came off.
Feb 02, 2016 | Speed Washing Machines
Balancing problems with the spin cycle
Redistribute clothes in the tub. It may take several tries. If this doesn't resolve try it with just water and no clothes load. Still doesnt resolve, there may be an issue at the upper bearing load carrying or bearing adjustment surface. A slim possibility there is something under the spinner tub, but that would interfere with the tub reaching spinout speed.
May 25, 2015 | Admiral Washing Machines
Spins out of balance even emty
http://www.askmehelpdesk.com/plumbing/whirlpool-out-balance-spin-cycle-18991.html
http://fixitnow.com/sbrvrs/washers.htm
http://www.repairclinic.com/Washing-Machine-Troubleshooting
This model of washer does not have an out of balance cut off switch. If the load is not balanced properly the tub could hit the cabinet sides. If the unit spins evenly while empty & out of balance while loaded, I recommend checking & balancing the load. If the basket spins out of balance while empty, I recommend having the suspension springs & balance ring checked. Be sure not to wash light fabric with heavy fabric clothes. Also ensure that the adjustable feet are level, that's most important.
Aug 01, 2010 | Kenmore 24032\24036 Top Load Washer
I have a zanussi washer/dryer but lately its making so much noise !! its driving me nuts please tell me what it could be ?? thanks
Hi
Thanks for using FixYa. If your washer is a front load washer then check these things if it is making noise--
Bellows
The bellows is a rubber sleeve that seals the suspended outer tub to the stationary cabinet front at the tub opening. Its purpose is to provide a water tight opening into the tub that can be sealed by the cabinet door, yet allow flexibility for the oscillation of the tub during the wash and spin cycles.
Outer Tub Assembly
The outer tub assembly is supported by two suspension springs and stabilized by two air shock assemblies. A cement counter weight is mounted to the front of the outer tub by screws. A counterweight is molded into the rear half of the outer tub. These counterweights prevent excessive oscillation of the entire suspended assembly during an unbalanced spin cycle.
Spin Basket Assembly
The spin basket is constructed of stainless steel. The circumference of the basket is perforated to allow water to flow through it as it revolves. A heavy steel shaft is pressed into the spin basket support which is then bolted to the basket. The spin basket assembly is entirely supported by two ball bearings pressed into the rear of the outer tub. A large drive pulley is mounted to the free end of the shaft that extends through the rear of the outer tub. There are three plastic vanes mounted to the spin basket to aid in the washing action during the wash cycle. The rotation of the spin basket provides both the washing action during the wash cycle, and water extraction during the spin cycle.
High pitch "jet engine" noise--A certain amount of motor whine is normal during the spin cycle.
Rattling and clanking noise--
• Foreign objects such as coins or safety pins may be in drum or pump. Stop washer and check drum. If noise continues after washer is restarted, objects may be in pump.
• Belt buckles and metal fasteners are hitting wash drum. To prevent unnecessary noise and damage to drum, fasten fasteners and turn items inside out.
Squealing sound or hot rubber odor-- Washer is overloaded. Do not overload washer. Stop washer and reduce load.
Thumping sound— Heavy wash loads may produce a thumping sound. This is usually normal. If sound continues, washer is probably out of balance. Stop washer and redistribute wash load.
Vibrating noise--
• Washer is not resting firmly on floor. Move washer so it rests firmly on floor. Adjust leveling legs. NOTE: Some shaking of the washer is normal without moving across the floor. See INSTALLATION INSTRUCTIONS for details.
• Shipping bolts and foam blocks have not been removed during installation. See INSTALLATION INSTRUCTIONS for removing shipping bolts and foam blocks.
• Wash load unevenly distributed in drum. Stop washer and rearrange wash load.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Nov 10, 2009 | Zanussi ZWD12270 Front Load Washer / Dryer
Tub rotates CW during agitation, out of balance, hits side of metal cabinet, but no error code
Hello srcoray,
Did you replace the clutch, just trying to get a feel for your hands on experience with the machine? If you did the work did your machine use the upper roller clutch bearing along with the clutch pulley mounted roller clutch bearing?
The FAV6800AW uses a reversing motor and motor controller that powers the motor and clutch pulley to rotate CW in Wash/Agitate cycle and CCW in Spin Cycle.
In Wash/Agitate cycle the roller clutch bearing should rotate freely CW allowing the agitator shaft to drive the transmission in wash cycle driving the tumblers to rotate only not the wash basket. In spin cycle the roller clutch bearing will lock up (one-way roller clutch bearing) driving the spinner shaft to rotate the wash basket and transmission CCW. Unless my thinking is wrong it sounds like the one way roller clutch bearing is frozen or dragging and not rotating freely in wash cycle rotating the wash basket CW. I’m an owner like you and will try to help.
Just a few other questions;
If you have a load of wet clothes in the wash basket and you select Spin Only cycle will the spin cycle complete with out dc/UC errors?
With the lid raised can you rotate the wash basket CW? It should not; it should only rotate CCW and do that with very little resistance.
Rich
May 22, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Pounding noise after wash and final spin
  • The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle. Call a qualified appliance repair technician.
    if this helps please give a fix ya vote
  • Jul 14, 2008 | Kenmore 3.2 cu. ft. Plus Top Load Washer
    Thumping and banging
    make sure all shipping pins are out the tub should move all around from side to side if it level still bangs its eather the balance ring top basket are there 3 slides on a plate above the motor just put some silacone oil on tham move around
    Feb 09, 2008 | Kenmore 24032\24036 Top Load Washer
    Washer makes loud thumping after finished spin cycle
    I replaced the drive block and it solved my problem. (thumping noise at the end of spin cycle) Easy repair. Videos on utube show all the steps.
    Jun 07, 2006 | Whirlpool LSR7333 Top Load Washer
    Washing Machines Logo
    361 people viewed this question
    Top Washing Machines Experts
