Question about iLO 2600 Television
Want to know if the ilo 2600 digital or analog ?
Hi I just want to know if I need a converter box or not.
    Problem Solver:
  • 4 Answers
Posted on Dec 16, 2008
  • gwendolynhar Dec 16, 2008
Ilo 2600 HDTV manual
You would need a converter to make it work. Adapters won't work as the type of signal would need to be changes. Your best bet would be to purchase a DVD player that has outputs that work with the tv. Sorry.
Jul 07, 2016 | iLO 2600 Television
How do I connect it to my cable? I have a co-axial line (I think) and there is no visible port to plug into!
The ILO 2600 does NOT have an ATSC tuner for the current digital broadcasting.
Note that a slightly later version *might* have come with such.
Later models equipped with it usually have TWO coaxial inputs on the back whereas the original one only has the now obsolete NTSC coaxial input.
There are several possible explanations of what your friend has told you: he may have had a different model or he may have connected it to a cable which was broadcasting in the older analog format already. Or he simply had a different TV with a built-in tuner that can pick the signal.
So first thing I'd check is the number of antenna inputs you have on the back. When there are two the second is usually labelled "DTV".
Second, is there a Comcast cable box somewhere on your end? And if yes then isn't there other outputs to it other than the coaxial cable?
Finally, it is possible to find a digital-to-analog converter on Internet and eBay in particular, but I wouldn't rush doing that. It's practically half the price of a new 32'' LCD TV and you wouldn't be quite happy with the quality anyway.
Nov 28, 2011 | iLO 2600 Television
How can I get analog channels to work with DTV without cable
Hello drandald,
Your tv is a digital tv, so you do NOT need a converter box. The tv has a built in digital tuner. But if you have any other older tv's then what you need is a converter box to convert analog signals to digital. I know there is one in Best Buy (not sure if there is one in your location) but they have one called access digital tv converter. They are about $50 (CAN). You would still need your antenna or however you get your analog signals. The antenna needs to be plugged into your converter box and then the box would need to be connected to your tv.
Aug 29, 2011 | Zenith Z32LC2D 32 in. LCD Television
Is this system set up with a converter to run off and external roof-top antenna or does it need a digital converter box?
This model will require a digital converter box to receive the digital OTA channels since it has an NTSC instead of an ASTC tuner.
Sep 21, 2010 | iLO 2600 Television
Cable company switched to digital and the audio quit working for channels under 100 - former analog channels. channels 100+ work fine. when I switch to dtv, I get the "no signal" message.
If you are using HDMI with the cable companies cable box, you may have to go into the
cable box menue and set the audio out as HDMI. I had a similar problem with my cable providers box.
Hope this helps,
Jun 14, 2009 | iLO 2600 Television
HDLCD2600 come set for cable. Make sure the tv is set for "tv" or "air" then run the auto channel memory or search feature of the set. If you have the manual it's under "memorizing channels". If your still have problems, call Sansui TV's customer service number 800 289 0980.
Nov 04, 2008 | Sansui HDLCD-2600 26 in. LCD Television
Ilo DVD player/recorder
> jfthr - Tv convertor boxes transfer digital signals into ANALOG. So when it goes to the dvd recorder it IS ANALOG. I have my antenna hooked to my convertor box, the converter hooked up to the ILO (A/V connections) then, the output on the ILO to the input of my analog tv. (Video selection on my tv). It works great to watch tv and/or record. I switch to the "DVD SOURCE" to watch dvds. Maybe you have the conv box hooked to the tv then the outs on the tv to the dvd. That would explain why you can get a picture but not watch dvd? The ILO has to go between the box and the tv in order to watch dvd.
Aug 07, 2008 | iLO DVD Recorder DVDR05
Converter box
the digital box has to hooked up the rca plugs on the bac of the vcr if you want to use the vcr (you will only be able to pick up channels throught input and the box will have be set on the channel you want to record. You need a switch to hook the vcr and dvd player both up. the atenna cord can be attached to the back of the convertor box then attached to the tv.
Jun 15, 2008 | Insignia Digital-to-Analog Converter for...
Can't get out of digital mode back into analog
My TV just did the same thing.  All you have to do is turn off the tv, unhook your cable antenna, then restart the tv with the antenna unplugged.  Then go to tv menu, and this time turn the digital scan off.  I really hoped this helped someone!
Jul 23, 2007 | iLO 2600 Television
Don't know where you are from, however, if you are with mediacom or a similar Cable provider, They informed me that their cable box does the converting and will only work when your tv is set to Analog. So, searching for "digital" channels will get you no-where. Set and search channels in analog and you "should" receive digital. Call your local cable provider and see if they tell you the same. Silly question, but are you signed up for digital service???
Feb 11, 2007 | iLO 3200 32 in. LCD Television
Televison & Video Logo
80 people viewed this question
Top iLO Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Jason Morris
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
