Question about RIM BlackBerry Curve 8310 Smartphone
Blackberry curve works with headset but not when headset removed
I plugged in my headset it works great, however when I unplug it and try to go to handset or speakerphone it doesn't work. The person on the other end of the line voice is chopped up. It appears the volume buttone is going up and down. HELP
  • 1 more comment
  • Anonymous Dec 31, 2008
    The normal headset and speaker phone was working find but today its not... ???
  • Anonymous Jan 20, 2009
    my blackberry's speakerphone doesnt work. arrghhhh what to do!
    Same thing as erarein1 . I will try the solution, but taking out the battery didn't work.
I have this same exact problem!! here is what works for me to fix it.. i plug the hands-free headset half way into the phone and then tilt it down (to push the jack up toward the front of the phone). After that i am able to use the phone regular again (speakerphone and internal earpiece works again.) I find that i have to do this once a day. There seams to be a short or something on the whole jack piece.. sometimes i actually just use my finger to wiggle the outside of the 3.5mm jack on the phone and that fixes it to! but i also found that there is replacement pieces like this on EBAY..
http://cgi.ebay.com/FLEX-CABLE-EARPHONE-JACK-FOR-BLACKBERRY-CURVE-8900_W0QQitemZ350187872475QQcmdZViewItemQQptZPDA_Accessories?hash=item350187872475&_trksid=p3286.c0.m14&_trkparms=72%3A1205|66%3A2|65%3A12|39%3A1|240%3A1318|301%3A1|293%3A2|294%3A50
Posted on Apr 12, 2009
  • 3 Answers
Actually there is probably something tiny stuck inside the hands free headset piece.
Blackberry should have put a little cap on it to avoid this.
When this happens to me I just blow into the hands free jack and it starts working.
Now a days a put a piece of tape over it to avoid it happening in the future.
Hope this helps!
Lucy
Posted on May 24, 2009
  • 21 Answers
First, take out the battery and leave it our for 15 sec. Replace and try. In cas the problem persists, reload the blackberry handheld software by connecting it to the computer and running desktop manager and application loader. The software is available on the CD that comes with the device or also frrely downloadable from the service provider's website
Posted on Dec 17, 2008
I cannot pair my blackberry curve 3G with my Wireless Nokia headset BH-503! It was working until I paired it with another nokia 2700 and after trying to pair it with my blackberry curve 3G again, it...
It is paired with the Nokia 2700.
From the manual (Click here to get it) page 11;
To clear the pairing and volume settings, switch off the headset and press and hold the multifunction key and press the volume up key until the indicator light alternates red, green and blue three times.
Feb 05, 2011 | Nokia BH-503 Bluetooth Headset
Does a supertooth 11 work with a blackberry curve?
being that it is a bluetooth device and the blackberry curve has bluetooth capability then yes they in theory will both work flawlessly with one another.
If you need further assistance please feel free to follow up with a comment and i will be here to assist you. If this assisted you please feel free to rate this comment. thanks and have a great day.
Aug 19, 2010 | Blueant Blue Ant 091193 Supertooth II...
I am trying to use an headset adapter for my 8310 and can't get it to work. Is there a way to change a setting?
is it a plug -in or a bluetooth headset if BT the code is 0000 if it is a headset you don't need to change any settings on it.
Nov 24, 2009 | AT&T Blackberry Curve 8300 Smartphone
Blackberry Curve 8330 can not find my bluetooth headset
Turn the 360 off.
Then turn Bluetooth off, then back on the Curve.
Then turn the 360 back on, input the code when asked to due so.
Jul 23, 2009 | RIM BlackBerry Curve 8310 Smartphone
Having problems pairing motorola h700 with blackberry curve
On the Blackberry, Go to Options, Bluetooth. Select the blackberry button, Add Device, and search. If search doesn work, try listen. While these are going conduct the following on the Headset:
Close theheadset. Go to the phone and choose discover, or search. Open theheadsetand pressand hold the big button. It should then turn purple and should be recognized.
Also make sure thebatteryon theheadset is charged before doing this.
If this doesntwork: Start the search onthe phone, Keep the boom of the mic closed when you press and hold the buttonon the h700. the light should turn purple. After this, open the boom
Mar 23, 2009 | Motorola Mobility H700 Wireless Headset
Motorola hs850 bluetooth headset won't pair with Blackberry Curve
try to delete it out of ur phone all the way and then try to pair it again
Dec 15, 2008 | Motorola Mobility HS850 Consumer Headset
PHONE WORKS WITH HEADSET PLUGGED IN BUT NOT WHEN UNPLUGGED
What model or Blackberry do you have? What os are you running on your phone? Check by going to settings/options then status.
Dec 14, 2008 | AT&T Blackberry Curve 8300 Smartphone
H500 won't pair with Blackberry Curve
It might already have been figured out but if you hold the answer button on the headset down until the light stays on steady, it is in pairing mode. You can then go to bluetooth setup on the Curve and it will find the headset.
Nov 08, 2007 | Motorola Mobility H500 Wireless Headset
RIM BlackBerry Curve 8310 Smartphone Logo
1,775 people viewed this question
Top RIM Computers & Internet Experts
Computer Repairing
Computer Repairing
Andrew Wright
David
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
