Question about Compaq Presario R3000 Notebook
Can"t find function key
At the bottom of mu screen there is a 2 inch black border and I can"t get rid of this how do I solve this problem?
  • Lee Hodgson
    Lee Hodgson May 11, 2010
    can you please provide a better description of the problem
    regards
Well i have a 23 inch LG monitor and im using the recommended resolution of 1920 x 1080 and its not fitting the screen. therers 1 inch black border on tob and bottom and 3/4 inch black border right and...
Dear User,
Good Day!
Please use the auto button in you monitor then it will automatically adjust the resolution of your screen. Please feedback us what happen.
Thank you...
Apr 16, 2011 | Computers & Internet
My samsung 50 inch plasma tv has a black and white 2 inch stripe from top to bottom one third from the left side of tv our tv is about 1.2 years old is there a addjustment to be done ? thank you from mike
Image retention, Go to Menu and I believe pic settings go to the Burnin Scrolling feature..Will run white and black in full screen, run for an hour problem huold be solved..Happened to mine and the scrolling feature got rid of it.
Mar 15, 2011 | Samsung HP-R5072 50 in. Plasma HDTV
Black border with some channels
if you mean the left and right sides of screen, look for a button on remote might be labeled several things, like picture size, aspect etc.. the borders pop up when you go to a non high def channel. some chs put borders all around the picture in those cases you won't be able to get rid of those.
Apr 07, 2010 | Memorex MVDT2002 20" TV
Inspiron 1300 screen border 1 inch
Have you tried adjusting the screen resolution? If you are running windows, try right-clicking on the desktop, then going to properties>settings>screen resolution. Set it to maximum available (I think it's 1024x768 on your inspiron). This should sort it out.
Good luck,
Raf
Nov 09, 2009 | Dell Inspiron 1300 Notebook
I have a black border on top of my screen
There are two things which could have caused this. One, the Monitor settings have changed or the computers display settings have changed.
1. Resetting the monitor to default.
Push the 'MENU' button to open the OnScreedDisplay system and display the main features menu. Push the - and + buttons to move between the function icons
Use the buttons to highlight 'Factory Reset' (this returns the settings to the factory preset values for the selected group of functions)
Detailed instruction available at http://support.dell.com/support/edocs/monitors/E153fpb/En/controls.htm
2. Checking the desktop display settings.
Right click on the desktop and select properties, click on settings and make sure screen resolution is set to one of the following 640 x 480 or 800 x 600 or 1024 x 768. These are the only ones supported by the monitor
If both this fails. Then the monitor is nearing end of life
Mar 02, 2009 | Dell E153FP 15" LCD Monitor
Picture not centered on my philips 47'' lcd tv
NOTE:(Edited and copied from another thread on Fixya.com, c7carl)
Picture is not centered on monitor leaving a 2 1/2 inch; black border on Philips LCD
By dmorrow54 on Nov 13, 2007
Again, nothing in manual for Philips LCD will correct the fact that the picture in HD-D mode will not center. The picture runs off the monitor on the left (facing the monitor) with a 2 1/2" black border on the right (facing the monitor). Using the format button on the remote of directional arrows will not correct the issue. The wide-screen/ full-screen function with format does nothing. Moving into TV mode, the format function works to display screen in several ways 4:3, 19:2, super-zoom, wide-screen, full-screen. Help, please. posted 3 years ago
Guest
  • Rank: Guide
  • Rating: 0%, 0 Votes
I have a Philips 30 inch LCD and solved the problem by using the circular arrow button on the TV remote. Pointing it at the TV and clicking "right" (3 o'clock on the button), the picture moved right. Same thing on for "left". Worked for me.
Add a comment
    • c7carl
    • 5 minutes ago
    WOW! It works!! The picture on my Magnavox (aka Philips) 37MF321D had shifted to the right. I figured I had a big repair bill coming up soon. But hey! Just used the TV remote as described by "Guest', and re-centered the picture to the left. Wallah! Thanks ""Guest" whomever you are! Reply
    Posting advertisements, profanity, or personal attacks is prohibited. Click here to review our Terms of Use.
    Comment:
Feb 05, 2009 | Philips 47PFL5603D 47 in. LCD HDTV
Sometimes when I change the settings profile from "User" to "Graphics," a black border appears on the screen and some of the viewing window is off the screen. Usually when I click the "Graphics" profile...
All LCD displays have an "Auto" button press it and see if that fixs it. should be aparent what it does if it does it. but basicly it alines the picture with the screen. when you change back to user profile you may need to press it again.
Dec 21, 2008 | Acer AL1916W 19" LCD Monitor
I have a 1 inch on the left and right side how do I get full scre
if you hav a monitor separate from your computer(not a laptop)then just use your settings on the monitor untill it works again the way you like it..
or for laptops and monitors with no controls on them go 2 control panel>>>>appearance and themes>>>>display. then click on the tab that says settings. go 2 advanced and the dpi setting should be set at 96....and if nothing changes go 2 the appearance tab then 2 advanced. and at the bottom for the item look for active window border and the size should say 1. if it does then keepo trying to make the number bigger so your page doesnt have a black border
Nov 30, 2008 | Gateway Computers & Internet
Screen border
You are probably in the "3:2" ratio print setting. This is accessed through the "F" button, under image quality. The 3:2 is a ratio of height to width which corresponds to a 4x6 inch print. The other settings are approx. 4x5.33 inches in h to w ratio. Just change the quality setting to the larger megapixel settings and the bars will disappear.
Sep 21, 2008 | Fuji FinePix S700 Digital Camera
Picture is not centered on monitor leaving a 2 1/2" black border on Philips LCD
Nov 13, 2007 | Philips 37PF7320A 37 in. HD-Ready LCD...
Compaq Presario R3000 Notebook Logo
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
