Question about Brother HL 2140 Laser Printer
Brother HL-2140 printing black pages.
I just bought a new toner, so I am not sure what the problem is.
  • Anonymous Dec 17, 2008
    I have a HL-2140 and it prints a series of lines in about the middle of the page. If I am printing , say 20 copies, then the last 15 or 16 will be fine. If I wait a while the first copies always have such lines. It happens even if I use another frame, (container?) for the ink material.
    Ralph Ekwall ralphomaha@yahoo.com
    New Friend:
  • 9 Answers
You have a problem with the top electrode. It is possible that the wire is broken. The wire drum loads. If it is broken it doesn't load the drum and you have the black cards.
Posted on Mar 03, 2016
  • 66 Answers
Hi Nacardi,
Could be bad toner (toner sitting on shelf for too long). Or the drum could have been over exposed. The drum is light sensitive.
S88
Posted on Dec 17, 2008
Tip
Resetting Blinking Toner Light HL-2140
Here is the procedure for resetting the Toner flashing light on Brother HL-2140 (sources for other answers here and self testing - specific to HL-2140)
  • Open the front cover and leave open.
  • Turn the printer off.
  • Hold the "white button" while turning the printer on. (All panel lights should be on.)
  • Release the "white button".
  • Press the "white button" 2 times (Pause, wait for all lights to come on.)
  • Press the "white button" 5 times. (All lights to come on again, then go out.)
  • Cancel "maintenance driver" install, if prompted
  • Close cover.
  • Power cycle printer.
This will:
  • reset the toner light (stop blinking)
  • restore the printing darkness (when toner light flashes, printer prints lighter to save toner)
  • keeps the printed page counts and drum life info
on Mar 06, 2011 | Brother HL 2140 Laser Printer
Tip
Brother HL-2140 does not print even if toner is full
In the Brother HL-2140 printer, it shows the Toner led light is on. Even if there is plenty of toner on the cartridge. It just wont print anything after initiating a print job since the toner light is on.Here is a trick on what you need to do:
1. Turn off the Brother HL-2140 printer.
2. Open the front access door to take out the toner from the carriage.
3. Notice that on both sides of the toner, you will see a small hole which is most probably the sensor.
4. What you do is to cover the sensor holes with masking tape and color the tape with black marker. Or, you can also use an electrical tape to cover them.
5. Shake the toner so that the ink inside will redistribute evenly.
6. Return the toner to the carriage and try to initiate a print again.
That's it!
on Jan 13, 2010 | Office Equipment & Supplies
My Brother HL2140 printer was running fine and all of a sudden the toner light is on and it stopped printing. Just yesterday when i printed out the status for the drum and toner it showed more than 80 %...
636 is a lot of pages and depends on the toner coverage you may need to replace the toner.. 80 - 75% (is that used is remaining ??) any way check your waste toner basket first (see you manual for instructions) chances are its filled and needs cleaning or replacing (see your manual for instructions) If its fine then change your toner .. If you have the demo toner (toner shipped with machine) these contain less toner than a new cartridge and will finish faster ...
Jul 26, 2010 | Brother HL 2140 Laser Printer
HL 2140 page printing all black
Dear sir, I know what is problem? your toner cartridge is demage please change it also you re-install your old toner then quickly take a decission
Thanks
xptareq2000
wiz
all the best
Oct 02, 2009 | Brother HL 1440 Laser Printer
Hl-2140 noises
For a possible fix to the Brother HL-2140 squeal/squeak/noise problem open the printer at the other side from the paper tray and toner cartridge door. You should see a little black roller rod along with some white wheels.
The noise may be coming from the contact between the wheels/rollers which pull paper toward the output tray on top after it has been printed.
Check and clean/wipe the wheels and black rod, especially in the center area. Hopefully the noise will now be reduced/eliminated.
Cheers, Stephen
Sep 14, 2009 | Brother HL 2140 Laser Printer
Black pages
Look inside the printer and make sure none of the pins that contact the drum are bent down.
Jul 02, 2009 | Brother HL 2140 Laser Printer
Brother 2140 toner light on, won't even try to print.
To get every bit of toner powder out of the cartridge, first remove the toner unit from the drum assembly. Second, find the little circular window on the right-side of the toner cartridge. Third, place a piece of black electrical tape over the clear window, cannot be clear tape. Fourth, re-install the toner cartridge into the drum assembly. Last, put the complete unit back into your printer. This worked for me.
Apr 05, 2009 | Brother HL 2140 Laser Printer
Brother HL 2140 Laser Printer Logo
406 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
