Question about Kicker Solo-Baric L7 S12L7 Car Subwoofer
12" kicker solo-baric subwoofer
One of the red wired on the bottom of the subwoofer is very loose. how or where can i replace this, and how easy is it to do myself. thanks someone please help
I had the same issue...so I thought. The Red Wire connection was loose. It is threaded and can be tightened down ;)
Posted on Jun 18, 2008
  • 944 Answers
Here is the link to the technical support manual for the l7 http://www.kicker.com/06/tech-support/manuals/manuals/02SL7TechManualV2_0.pdf Page 17 and 18 show the wiring, if you can use a soldering iron then you should have no problem doing it yourself, but don't risk it unless you are sure. Hope this helps :)
Posted on Mar 16, 2007
I have a Kicker Solo-Baric, L7, 12 inch subwoofer making a scratching noise. The cone is fine but the inside is not. Can i get this repaired? Kicker said no. This is a $250-300 sub. I hate to just throw it...
The bad news is that your voice coils could be fried up, basically mechanical failure. Might as well buy a new sub because replacing a voice coil means you got to rip the whole sub apart, very complicating.
Oct 15, 2010 | Kicker Solo-Baric L7 S12L7 Car Subwoofer
Need An amp for 2, 4ohm Kicker 12" L5
i bought two Audiobahn A2300hcx on ebay for a little over 400. look around on ebay you can really score sometime dirt cheap........ Check out audiobahn amps, never did me any wrong...........
May 06, 2010 | Kicker Solo-Baric L5 Car Subwoofer
I cant remember how to install the kicker 12 l7
Your subwoofer is single or dual voicecoil? And what amplifier Make/model are you putting it on?
Thanks!
Nov 04, 2009 | Kicker (2) S12L7 12in Solo-Baric L7 + (1)...
Need new spider
go to Kicker.com...they should have what you need.
Jul 25, 2009 | Kicker Solo-Baric L7 S12L7 Car Subwoofer
What amp need to use for Kicker (2) S12L7 12in Solo Baric
you should use an amp with approx half the power of the speakers max output (i.e 1000 watt speaker use no more than 600 watt amp)
May 12, 2009 | Kicker (2) S12L7 12in Solo-Baric L7 + (1)...
Wire my kicker
This will help you :)
Below is a link to the subwoofers manual where is clearly states how to wire it all up, it includes both the 2ohm DVC and 4 ohm DVC models.
Click Here for the L7 Solo Baric Manual
Jan 23, 2009 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
Kicker L712 and rockford fosgate800a2 amp.weak prfmce
Is the box sealed air tight, leaking around speaker? plumbers putty works great. Amp may be good enough for the mtx but underpowered for the kicker. When kicker says 1000 watts that what it is (at a 14.4 volt input). Mtx is ok but may not tell the true watts. Check to see if the speakers are the same ohms also!
Jan 05, 2009 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
12" kicker l5
Series is +amp to +1, -1 to +2 , -2 to -amp . This way you have wired the two voice coils into one higher impedance voice coil.
Dec 11, 2008 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
Kicker solobaric l5 12''
how to wire a kicker solo baric l5 12'' 4ohm down 2 and 1 ohm
Sep 25, 2007 | Car Audio & Video
Kicker Solo-Baric L7 S12L7 Car Subwoofer Logo
117 people viewed this question
Top Kicker Car Audio & Video Experts
Morne Olivier
Marvin
Marvin
Mike Duncan
Mike Duncan
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
