Question about Mitsubishi Televison & Video
Burning out lamps on my 65inch dlp
Spent over $400 in less than 10 days!!!!!!! my warranty expired in sept 08
I have 65" Mits. lamp lasted about 2+ years and burned out. bought new on internet, that lasted about 5 months and went. Got free replacement and that lasted about 4 months. No more free replacements ...
Bought new from different source and it burned out in a week.
Note: These were ALL OSRAM original lamps from reputable suppliers.
They sent a new one but also cautioned about cleaning the "filter" on the lamp housing. NOT the large screens on either side, but the small rectangular one (about 3/4" x 2"). I did this with a shop vac pulling and pushing from every angle and it was really clogged almost solid. No way air was going across the bulb to cool it.
THIS IS CRUCIAL and I feel is the keys to the kingdom! I did this and voila - no more "plastic smell" when installing the new lamp and everything's great!
I feel that Mits should be held accountable for this for not recommending the lamp housing be cleaned periodically (maybe yearly). I really feel if this were done with my original one it would have last a lot longer.
Lou
Posted on Jun 15, 2009
  • 4,806 Answers
Extend the warranty, wait a couple of weeks and have the manufacturer sort the problem for you
kind regards and please don't forget to rate us
Posted on Dec 14, 2008
SOURCE:
Green light is blinking
because of poor quality electronic components that cost less than $10. Of course mitsubishi will replace the entire module, so that the repair without warranty would cost $700 to $900.
you're so lucky if your warranty did not expire yet
Good Luck
Jul 05, 2014 | Mitsubishi "WD-82840 DLP 3D HDTV"
Have a 65inch Mitsubishi DLP. acouple years old, just heard a loud pop,smelled like it was burning,it turns on but just sound????
hi,
Check the lamp of you tv. The lam is burned. that's why you heared a pop up sound and burning smell. Just check it and replace it. you will get the picture back.
ok
Apr 16, 2011 | Mitsubishi WD65737 65" DLP TV
Less than a year into ownership camera would not turn on and is non-responsive to charging. Never dropped or abused. Replaced battery but still wont turn on or accept charge. i don"t know warranty...
Go here for warranty look up:
http://support.en.kodak.com/app/answers/detail/a_id/19879
If by chance your warranty expired 10 days ago, try reasoning with Kodak about your issue and how the failure occurred 30 days ago and you just now got around to repairing the main unit, not battery. It happens to all of us, I'm sure they'll cut you some slack on the 10 days.
Now if your warranty expired months ago... :(
Jan 11, 2011 | Kodak Easyshare M341 12.2MP Digital Camera...
Does a Zenith Z44SZ80 DLP lamp quit after a set amout of hours
Lamps are only design to play 5,000-8,000 HRs you cannot leave them on day&night like projection ,they will burn Lamp out quick. For New Lamp go to E-Bay 85.00 and up.
Sep 16, 2009 | Zenith Z52SZ80 TV
My 56 inch Samsung DLP keeps shutting off. I have
Once before I had this same problem and FixYa gave me the solution. When you replace the lamp door, there is a switch inside so be sure the door is put in at an angle so to hold the switch up. It solved my problem after numerous repairmen missed it.
Sep 02, 2009 | Samsung DLP HL-P5663W 56" TV
DATE DIFERANCE BETWEEN SELECTED COLOUMN
Are you trying to figure the difference in days between these dates and one single date (Dec. 31, 2008 for example)?
Whatever you're trying to do, here is the formula, assuming you're starting in A1:
Put the first date in the format Day-Month-Year in numbers (Sept. 3 is 03-09-2008)
Then put your other date in B1, in Day-Mo-Yr format (31-12-2008 for Dec. 31, 2008)
In C1 put B1-A1 and that will give you the number of days between those two dates.
Dec 27, 2008 | Microsoft Excel for PC
Samsung HLS4266W 43" dlp
Power issues (Tv not turning on) were typically due to faulty ballast. While the TV reports a bad lamp it is the ballast itself causing the issue. Samsung is well aware and will replace both the ballast and the lamp (since the lamp can be prematurely aged but the bad ballast). After replacment most people stop having issues.
Dec 24, 2007 | Samsung DLP HL-P5663W 56" TV
Sony DLP KDF-E60A20
Has anyone experianced a problem with sony DLP mod# KDF-E60A2 blowing lamp every 30 days? we replaced balast and lamp, still blows every 30 days or less.
Nov 26, 2007 | TruTech PLV16260 Television
Samsung dlp
HLS4266W 43" dlp. In less than 1 yr whining grew worse, but did know what it was. Year passed with warranty and lamp went out. Replaced lamp. Worked for 3.5 hrs. Turned on next day and did not work. Got another lamp, but did not work. Figured out might be color wheel. Replaced it too. TV started up. Watched that night. Turned on next day, heard loud pop. Lamp never came on. Withdrew and reinstalled lamp a couple times to see if that worked. Did not. Currently, with new lamp and color wheel installed, lamp light blinks, but no lamp comes on. What now?
Sep 17, 2007 | Samsung HLN5065W 50" Rear Projection...
Televison & Video Logo
152 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
