Question about Frigidaire GLER331A Electric Dryer
Dryer wont run
My dryer was running then shut off now it wont start back up?
  • tkh1381 Dec 17, 2008
    Replacer the fuse and its back working great! thanks!
  • Frigidaire Master
  • 8,220 Answers
The fuse is located on the rear bulkhead upper right hand side. Clean the dryer out open all vents check slides and rear bearing.
Posted on Dec 15, 2008
Dryer starts up runs for a second and stops a few minutes later starts up runs a second or two and stops
Dryer runs then shuts down wont start up for an hour:
Bad motor windings
Oct 05, 2014 | Amana Dryers
Dryer completely shuts off after about 15 minutes. Cannot turn the dryer back on for about an after
SORRY TO HAVE TO TELL YOU BUT Dryer runs then shuts down wont start up for an hour:
Bad motor windings
Aug 31, 2014 | Dryers
Dryer light stays on when door is shut nd wont run
check the door switch,i don't work on lg but on any other dryer if the wsitch is broke the dryer won't start and if the light is on the switch shuts off the light and dryer will start.if you send the model number i can look up the switch for you.open the door and look around the frame where the door closes into,there should be a push button switch or a little paddle that the door hits,when you push in on the switch it should make a clicking sound or i've seen the paddle broke off.hope this helps or if you removed any wires to the door switch you might of wired it wrong
Mar 30, 2013 | LG Dryers
Shut off and wont come back on. Dryer does nothing at all
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer is not Turning
Dryer Repair - The
heatman101
Feb 18, 2011 | Dryers
Amana DLE330RAW Elec Dryer starts then shuts off & wont turn on
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer2_bing.gif Repair ? The dryer2_bing.gif will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Jul 08, 2010 | Amana DLE330RAW Electric Dryer
Wont start after running all night without shutting off
Bad timer, When the machine just runs and runs and runs, or runs for a very short time and shows that it ran the whole cycle but the clothes are still wet then the timer has gone bad and needs to be replaced. IF you go to repairclinic.com. You can order the timer from there or your local appliance repair company. They are around 40 dollars and you can replace the part fairly easy
May 20, 2009 | Dryers
Maytag dryer timer keeps running
Your dryers timer contacts have fused to gether.
The only repair is to replace the timer.
Mar 25, 2009 | Dryers
Dryer wont run
sound more like a motor problem,, does it sometimes humm while trying to start ,,that first sign ,, repl motor
Dec 29, 2008 | Dryers
Whirpool dryer wont run
inside light on when door is closed??? that sounds like a bad door switch. it doesnt recognize the door shut so it wont start, replace the door switch
Mar 29, 2008 | Dryers
Frigidaire GLER331A Electric Dryer Logo
112 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
