Question about Aprilaire 550 Humidifier
Aprilaire model 760
I have replaced the solenoid,cleaned the water feed line but the unit will not go on, any ideas?
    Problem Solver:
  • 12 Answers
It could be that the humidistat is not calling for humidity. Make sure that you have the dial turned up all the way (as far as it will go, just to test it) and that the blower on the furnace is running - if the unit is properly wired, the water will not run unless the blower on the furnace is running. This should do the trick. If not, the only other thing would be a bad humidistat. Good Luck!
Posted on Dec 16, 2008
760 aprilaire humidifier does not let water to the filter. I have cleaned and checked the lines in and out of solenoid.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Your Aprilaire Humidifier is designed to operate in conjunction with your furnace blower motor. Most installers wire a humidifier to operate when the furnace is calling for heat. To determine if your Aprilaire Humidifier is maintaining proper humidity, turn up the heat temperature 5 degrees above the current room temperature on your thermostat and set your humidifier control to call for humidity. The humidifier control is located on the cold air return duct. To set your humidifier control to call for humidity, turn the control dial to the off position and slowly rotate the dial until you hear a “click” on the control. You should also hear a click at the solenoid valve located on your Aprilaire unit. The humidifier control will have a click point at the current relative humidity level in your home. If the current relative humidity is 45% or the outdoor temperature is above 60F, the control will only operate the humidifier in the test mode.
  1. No click at the solenoid valve indicates an electrical problem. Contact your heating and air conditioning dealer to further check the electrical components of your Aprilaire Humidifier.
  1. The click sound at the solenoid valve indicates there is electricity to the solenoid valve. By turning the dial of your humidifier control to a setting above the “click point” you should see water coming out of the drain line within a few minutes which would indicate your humidifier is working.
  1. If the solenoid valve makes a click sound and there is no water draining from the unit, this would indicate the flow of water is being obstructed.
1. To determine if water flow is being obstructed, turn the dial of your humidifier control to the off position. The first location you would want to check for an obstruction would be at the saddle valve located on the water line supplying water to the humidifier. When checking the saddle valve, you want to make sure it is completely open. This can be done by turning the valve all the way to the left. If anything is clogged, it can be dislodged by turning the saddle valve all the way to the right and back to the left. Once this is done, turn the humidifier control dial above the click point and you should see water coming out the drain line.
If water is still not coming out of the drain, check the orifice and in-line strainer to make sure they are not clogged. The orifice is located in the tube on the discharge side of the solenoid valve and the in-line strainer is located on the inlet side of the solenoid valve. You may clear the orifice by inserting a needle through the small opening. Clean the strainer by running it under warm water to dislodge deposits or replace. After clearing and re-installing the orifice and strainer (be sure to double wrench all water connections), turn the humidifier control dial above the click point and you should see water coming out the drain line.
Mar 10, 2010 | Aprilaire Humidifiers
Solenoid on Aprilaire whole house humidifier
the solenoid allows water to flow to jet that then runs down the pad the solenoid is control by the stat
Feb 23, 2010 | Aprilaire 700 Humidifier
How do I know my aprilair 760 humidifier is working?
A simple check you can perform on your aprilaire 760 is the following:
1) locate the two brown wires coming out of the 760 (these wires will be wired to tell the 760 to turn on when the hvac bower is on and the humidistat is calling for moisture).
2) temprarily disconnect the two brown wires from the external wiring and then short the wires together. All you're doing here is bypassing the your thermostat and bower-on indicator.
With the 70 unit plugged in to the wall outlet and the two brown wires connected together, both the fan and the solenoid valve (water inlet valve) should both be activated.
Dec 13, 2009 | Aprilaire 700 Humidifier
When calling for heat and humidity I have 24v at the brown wires going to my Aprilaire, but the solenoid doesn't pick. Is it the control card or solenoid? Both are mounted on the Aprilaire unit. I have a...
If you have 24 volts to the solenoid, then it's not the control card. It's either the solenoid or there's an orifice in the water line at the solenoid that sometimes stops up. To check the solenoid you need to disconnect the power to the system and disconnect the solenoid wires (the two brown wires) and ohm the solenoid. If you get a low ohm reading around 50 ohms or then the solenoid is good and you need to check the orifice. If the ohm meter doesn't move when you ohm across both leads then it's the solenoid and it needs replaced.
Nov 24, 2009 | Humidifiers
Aprilaire Model 560bone dry, water is on, what can I check?
Yes, just check to see if you have 24 volts going into the solenoid. If you do and it is not opening its probably bad. Since you verified the water lines, filter, orifice and saddle valves are not obstructed. Change the solenoid valve. When you price the part. (it's not cheap) consider paying about 30% more and just change the whole unit.
Good luk
HVAC Teacher
Feb 18, 2009 | Aprilaire 600 Humidifier
Aprilaire 700 humidifier not adding any humidity
Thanks for your Question,
Sounds to me like you have a calcium build up in the Solenoid, which is restricting flow to the unit for proper operation, you might even have a bit of restriction in the copper line feeding the Solenoid, replacement of the solenoid would probably take care of your problem, one quick tip, in the spring and summer months, its a good idea to shut the water off to the unit, this should make the Solenoid last a little longer, hope this was helpful to ya, please let me know, thanks again,
mr.grzz
Jan 12, 2009 | Aprilaire 700 Humidifier
Water feed tube and nozzel seems to plug
What type of plumbing do you have? Galvanized, copper or pvc?
Dec 15, 2008 | Aprilaire 700 Humidifier
Aprilair model 760 does not go on
If you replaced the solenoid yourself make sure that is a 24VAC some solenoid are 120VAC and they look the same. to see if your humidifier is working you can short the 2 control wires coming from the humidifier I think the wires are brown or oa range. if you put then together the hum. should come on if is pluged in, if not then check your outlet see if you have 120AC plug in a lamp to check the outlet, if not your hum.may have a bad power supply you can get one at www.AppliancePartsPros.com/Parts
Dec 14, 2008 | Aprilaire 550 Humidifier
I hear to click of the relay, but no water is feeding into the unit
Sounds to me like the solenoid valve is your problem and it is likely stuck due to sediment. I beleive Aprilaire has superceeded all of their old valves to the part number 4040 (used on all models of aprilaire humidifiers) - anyone who services these units regularly likely has one in stock usually $60 - 100.
Nov 11, 2007 | Aprilaire 550 Humidifier
Aprilaire 760 Humidifier water continues to run
You need to determine whether the problem is in the solenoid or in the furnace electronics. You could put a voltmeter on the solenoid connection to see if the furnace is still holding the solenoid open after the blower stops. This will tell you whether it is the solenoid or not.
Feb 18, 2007 | Aprilaire 700 Humidifier
Aprilaire 550 Humidifier Logo
236 people viewed this question
Top Aprilaire Humidifiers Experts
Paul Carew
jdthefixer
Mack Baxter
Are you an Aprilaire Humidifier Expert? Answer questions, earn points and help others
