HP w1907 monitor driver software will not load
I have a new HP a6644p computer that came with an HP w1907 LCD monitor. When I try to load the monitor driver software that came with the unit I get the following message, ''Windows encunterd a problem insstalling the driver software for your device. Access is denied''
  • louismcgure Dec 15, 2008
    I was also puzzled by the system comming with a disk with instructions to install the diriver. I was logged in as the administrator. Thanks very much for your comments and suggestions.
  • Anonymous Jan 09, 2009
    My issue is the same one. I also keep getting a notice
    from Windows Update telling me new updates are avail.
    and they are for the HP w1907 but when I try and install
    them it comes back and says Windows has encountered
    a problem etc.
    So far no luck.
  • 585 Answers
"Access is denied" is the key here. It sounds like your login in windows does not allow you the privileges for that installation. Try logging in as an administrator and re-installing. One thing bothers me though, if this was purchased as a system, why would you need to install drivers? that should have been pre-installed.
Posted on Dec 14, 2008
Vertical green line screen try
Have you tried to do a reset via the monitors menu options?
Jan 21, 2014 | HP w1907 LCD Monitor
Upper section of my HP w1907 LCD computer monitor is faint. How to fix it?
From the sound of it, you most likely have a blown CCFL bulb in your monitor (there is one on the top and one at the bottom).
You can either buy new bulbs for it and try to replace them (risky and difficult without experience as I had found) or you will need to buy a new monitor.
It is a common problem with them unfortunately.
May 11, 2011 | HP w1907 LCD Monitor
My HP W1907 monitor needs a driver update. Told access is denied
yes the monitor bad , which means your lcd lamps gone ....
May 09, 2010 | HP w1907 LCD Monitor
Monitor (hp w1907)
Pls power on your PC & press F8 button continously then you see last known good configuration option. select your option & press enter. i hope your problem will be solved.
Nov 13, 2009 | HP w1907 LCD Monitor
Monitor will not switch on
your monitor could possibly have a backlight problem.. the wires to the lights are known to come off the lights in the screen.. if you try to check it your self be careful the lcd screen and lights are very frigile, nad can brake easly..
Oct 08, 2009 | HP w1907 LCD Monitor
My hp w1907 monitor is constantly auto adjusting every 1 or 2 seconds. Make it stop.
Good morning! Auto adjustment occurs when resolution or refresh rate of the display changes. Check your display setings in OS. Set them properly according to product operations manual. Update your display adapters driver. Also check your VGA card or motherboard display port & try using a different cable. try pluging the monitor to a different computer or plug in a different monitor with your motherboard or VGA cards display port. best regards
May 03, 2009 | HP w1907 LCD Monitor
Need to change setting from 800x600 to 1440x900 on a hp w1907 monitor.
If your using vista right click on the desktop and click personalization--->click on display settings -----> there is a bar for resolution drag it over to 1400x900.
IF your computer cannot display that particular size then your video card probably cannot handle that resolution. Either that or try to download a new driver for your video card to see if the new drivers will support it.
Mar 29, 2009 | HP w1907 LCD Monitor
Stretched images
on your monitor there should be a auto resize. is it dvi? or hdmi or vga?
Jan 03, 2009 | HP w1907 LCD Monitor
HP W1907 Monitor
If it was working fine why install additional software? Try booting into safe mode and uninstalling the software or drivers.
Computers & Internet Logo
776 people viewed this question
David Payne
David Payne
