Question about Xerox Office Equipment & Supplies
Comunication error on xerox 470st - Xerox Office Equipment & Supplies
    Problem Solver:
  • 7 Answers
Xerox 470st showing print fault
Posted on Oct 31, 2011
Xerox WC 7655 host to host usb failure. comunnication error 7655
Try changin the usb connector of the cable that goes from the screen to the rear left of the machine. There are 4 connectors there.
Oct 01, 2014 | Xerox WorkCentre 7665 Copier
Epson PLQ20 Passbook printer Problem:"comunication Error"
Hi, Check your cable connection. Check for updates from Epson. Restart your computer . Good luck.
Jun 24, 2011 | Epson Passbook PLQ-20 Matrix Printer
Xerox 3535 error code 102 372
have a xerox 3535 with one blinking light and error code 102 372 on start up any ideas ?
Oct 15, 2009 | Xerox DocuColor 3535 Copier
Error communicating with kernel
try to instal the antivirus again there is some files corrupted
ok ;)
May 28, 2009 | Encore Computers & Internet
To resolve the problem, download and install the latest service pack for Microsoft .NET Framework 1.1. Use the Windows Update feature
Apr 21, 2009 | Computers & Internet
AIR CONDITIONER LG S18AN
The operating LED will be blinking 5 times, means that there is a
comunication error (serial comunication) between the outdoor and the indoor unit.
Dec 28, 2008 | LG LS-K1830CL Cool Mini Split Air...
Error 230 en Escaner NCR 7875
You need disable the scale scannig the bar codes for programing
Program mode
304
save and reset
301lbs to kg
302kg to lbs
303enable scale
304disable scale
305 Protocol comunication
306 Protocol comunication
307 Protocol comunication
Oct 08, 2008 | NCR 7875
Xerox printing problem
Is it asking for the fuser module to be replaced? The fusers have a fuse or a chip in them that turns them off after a certain number of impressions.
Jan 12, 2008 | Computers & Internet
Problem with xerox Doc Centre 470ST
uwasbisi... It is not un-common for the Xerographic modules for these models to be defective right out of the box. I myself experience about a 50% DOA rate. You may want to try another one.
Before you do that though, try this...
Remove the xero-module and the toner cartridge. Look into the now empty compartment area's (you may need a flashlight), and directly above and center to the magnetic developer roll/housing (under where the toner cart was, and directly left of where the xero-mod was), there is a photo-sensor mounted to the toner/developer housing that faces the (now removed) xero-module. It is rectangular in shape. About 3/4" tall and 4" long. Clean it off with a dry lint-free rag thoroughly. Do not remove toner/developer from the face of the magnetic roller that faces the xero-module. Only clean this sensor above it.
This is the sensor that "reads" the toner density produced on the module during set-up, and if it's dirty (and it DOES get dirty considering it's location), it can cause the type of problem you are experiencing.
All that being said, there are many other issues that may be the culprit as well (from a bad stapler safety gate on a sorter, to power supply board problems). Are you getting any service/error codes (you should be) in conjunction with the service message? You can look under the "error history" under "machine status" to the right of the touch screen.
Let me know.
Oct 08, 2007 | Office Equipment & Supplies
29 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
